Old 05-13-2005   #21
Speedfreak
Drives: four tires
Re: acf and tuning
VC swap(AWD guys) - $150
Tuning - $140/hr, time would depend on your setup...
Old 05-13-2005   #22
Re: acf and tuning
When installing the AFC, you don't need to solder the wires. I always used aligator clamps or whatever they're called and had no problems. I've also installed AFC's in others' cars with the clamps and not one has every given trouble.
Old 05-13-2005   #23
Re: acf and tuning
You can use the little crimps that come with the AFC. Just don't use those plastic quick connect/vampire T's that just tap into the wire. They are just a problem waiting to happen and I have to fix them on cars all the time. They are fine something trivial like the light bulb on your boost gauge, but I would want a good solid connection for something as important as your fueling. I usually solder the wires when doing an AFC.
Old 05-13-2005   #24
Alpine TSi
Banana Hammock!
Alpine TSi's Avatar
Drives: Shitbox
Re: acf and tuning
Well the considering a certain amount of voltage or signal could be lost by a bad crimp or other horsecock connection, I would ALWAYS solder those wires. Especially since it is something as important as an AFC.
Now I know people have done it with those shitty crimp style connectors, and it works, but you never know. And why not spend an extra two minutes and solder it.
I work in mobile electronics, going on my fourth year, and I have seen countless malfunctions from poor connections, always crimp style. With solder all you have to worry about is getting a cold joint, and that can be easy to find if you have touched a soldering iron before.
And on the real topic, if you are very confident in your tuning abilities you may just want to save money and go to RS motors. Otherwise just have Shane do it, he won't blow up your motor and can offer a lot of great advice and help.
And about the dyno thing, I put down 313hp at RS motors, and maybe a month later with no changes to the setup I put down 321hp at Elite. Sure sounds like thsoe corrections are right on to me. And yes Ron always asks for the weight of the car before dynoing, but that mainly will effect where the turbo will spool due to load. But it can also effect total hp.
1992 Eagle Talon TSi AWD
320awhp/320lb-ft tq
12.772 @ 108.57
1992 Mitsubishi Galant VR-4
678/1000
Old 05-13-2005   #25
1slowdsm
Now 1 second.....slower!
1slowdsm's Avatar
Drives: 1993 Talon AWD
Re: acf and tuning
So it's $150 just for the swap itself and another $140/hr for the tuning? WOW.....
Aww man! My car is getting $$$$$$$$$$$$$.....Anyone wanna plan a bank heist? Hehe...j/k!!!
Old 05-13-2005   #26
At-Least-It's-An-Evo
At-Least-It's-White-Again
At-Least-It's-An-Evo's Avatar
Drives: 98 iVTEC
Re: acf and tuning
You can do the swap yourself and save the $150!
'04 Honda Ricer: stock
Old 05-13-2005   #27
1slowdsm
1slowdsm's Avatar
Re: acf and tuning
Yeah I know. Only problem is....I have no idea how to do it or even know where it goes...haha. Tried to look for pics of it installed and couldnt find any. Is it a permanent mod or Temporary?
Old 05-13-2005   #28
Re: acf and tuning
Temporary.
Old 05-13-2005   #29
EclipseGST
EclipseGST's Avatar
Drives: Short Bus
Re: acf and tuning
Temporary... Just so you can dyno the car in FWD mode.
Originally Posted by shoutbox
Old 05-16-2005   #30
1slowdsm
1slowdsm's Avatar
Re: acf and tuning
Would I be able to drive it like that for like 15-20 Mins to Elite and then back after the dyno and all?
Old 05-16-2005   #31
EclipseGST
EclipseGST's Avatar
Drives: Short Bus
Re: acf and tuning
Yes.
Old 05-17-2005   #32
CarPsyco84
CarPsyco84's Avatar
Re: acf and tuning
Just make sure you don't drive it with a welded VC in AWD, I've never done it, but im sure it isn't good
-When in doubt, Moar RPM.
Old 05-17-2005   #33
Re: acf and tuning
A lot of people do, helps you get better traction on the lauch. Its not exactly good for the car though.
Old 05-17-2005   #34
Nash
Nash's Avatar
Re: acf and tuning
I've been driving with one in my AWD for the last couple years with no problems.
Old 05-17-2005   #35
Re: acf and tuning
Yeah its not bad when you have power steering either.
CRAIG
And as far as the AFC goes. When I installed mine I soldered all the wires and then insulated them. I had some quick connect but I don't really trust them. Like Shane said on something trivial I would use them but not with a tuning device. It took a little more time but I think its worth it and it will never fail due to a lose connection.
Old 05-17-2005   #36
1slowdsm
1slowdsm's Avatar
Re: acf and tuning
Sounds like I'll be soldering them together. We'll see how well this works, I've never been the best at soldering small things together. Always ends up in one big clump, haha. I guess I could use heat shrink also, just incase anything breaks apart.
(edit)Is there an adapter that I have to buy for my S-AFC I? This one was off of an early '90's 240sx and I was just making sure I have everything I need before I install it?
Old 05-19-2005   #37
Re: acf and tuning
You could always use a weatherpack connecter(s) or a Deutsch connector(s) instead of the alligator connectors or whatever you want to call them.
Old 05-20-2005   #38
Re: acf and tuning
I use butt connectors on the majority of wiring that doesnt take alot of load. Its pretty hard for a butt connector to loosen unless there is some serious tugging on each end of the cables.
