Old 05-26-2005   #21
Steeltwo
CompUSA Whore
Drives: 07 Civic Si, 06 IS 350 and I own a dsm
Send a message via ICQ to Steeltwo
Re: tire discount?
Originally Posted by S2kracka
G-Force KDW tires will DESTROY Traction T/A tires in the dry, the KDW uses a specialized tread compound meant for warmer weather whereas the T T/A's don't. Please don't confuse yourself thinking good (even great) all-seasons will even compare to real performance tires. The T T/A tires are great for general driving, if you insist on using an all-season as a performance tire get the KDWS's and just drive carefully in the snow.
my dsm uses gforce kdw tires
my svt tour uses traction t/a rubber.
so I talk from experience.
and I said "cornering stability". the KDWs do not like to hit bumps going into a corner.
The grip of the kdw's on a nice day is more than enough to make your face tingle(a step in front of the bfg zr4). And when the kdw's let go, they do not give up.
The T/A's will keep grip until you are against your door panel, then let go. When they give way, they pretty much give up completely.
91 tsi awd
07 Civic Si
06 IS 350
Steeltwo is offline   Reply With Quote
