Old 08-06-2005   #21
Re: crazy studdering while Reving
Try a new coil pack, but first try a good set of wires- stock NGK or taylors or something that is good. Wires can make a big difference.
Everyone needs to settle down geez...
Old 08-06-2005   #22
Pimpin Dsmstyle
Br0k3N
Pimpin Dsmstyle's Avatar
Electrical is anything but my thing. I dont have one nor would I know how to use one. Every coil is sparking, I just dont know if it is sparking right. I'm going to try and buy more new wires and plugs. The reasons these ones suck, is because the ends break off everytime you disconnect them from the coil pack and the spark plug. 2/4 are trashed.
- Josh L.P.
Old 08-06-2005   #23
Pimpin Dsmstyle
Br0k3N
Well I took craigs ass hole advise and it got me in the right direction Thanks fucker!
The problem is still not fixed but I have a good feeling I know what it is. Since I put in NICE wires, NEW plugs gapped at .031, and checked out the coil pack; I realized sparks PERFECT. So what does that tell me? I air or fuel.. So I popped the clips off the injectors and pulled them one by one while the car was running. This is what I got
#4 - almost killed car
#3 - almost killed car
#2 - almost killed car
#1 - no change in how it ran
The car was already running weird and getting horrible gas mileage prior to this "tune up". So its likely that the injector was starting to get clogged and it finally had its own.
Problem is, I just sold my 450s and dont have anymore. I could use some good help if anyone feels like turning some advice over. Im up for any ideas.
Thanks in advance!
- Josh L.P.
Old 08-06-2005   #24
I'll check to see if I have a single 450 left. I won't break up a set if I just have sets left though.
Old 08-06-2005   #25
Pimpin Dsmstyle
Br0k3N
Thanks anyways jet, Mike already got me covered. I am not putting it in tomorrow, I will post results like I was instructed.
- Josh L.P.
Old 08-07-2005   #26
Pimpin Dsmstyle
Br0k3N
I installed a couple injectors in #1. No improvement. Its still not firing. We put #2 clip on #1 and it was firing, but obviously out of order.
How can I fix the sensor / electrical problem? Can I just splice a new clip that attatches to the injector in there?
- Josh L.P.
Old 08-07-2005   #27
Yeah, be sure to solder it and shrink wrap it. You don't want to ghetto something up there where it is going to get wet a lot.
Old 08-07-2005   #28
Pimpin Dsmstyle
Br0k3N
im talking about the clip which nothing but electrical current goes through.
I guess its a bit more complicated. I guess I have to use a DVOM and find where the signal is being lost and cut / solder there. I really dont know how to use that DVOM meter but I have one I can use.
ERIC FUCKING METZGER COULD BE SOME HELP HERE. Too bad he's horrible at answering the phone. EDIT * notice the sarcasim now?
- Josh L.P.
Old 08-07-2005   #29
I wouldn't answer the damn phone either for someone who acts like you.
Old 08-07-2005   #30
Pimpin Dsmstyle
Br0k3N
Are you kidding me? We treat eachother like this. Bah - So much for a tech thread. PPL just keep whoring it up.
- Josh L.P.
Old 08-07-2005   #31
Alpine TSi
Banana Hammock!
Alpine TSi's Avatar
Drives: Shitbox
LOL, if you are still having problems on Tuesday with this and haven't gotten a hold of Eric, I am pretty handy when It comes to electrical and can help. Let me know.
1992 Eagle Talon TSi AWD
320awhp/320lb-ft tq
12.772 @ 108.57
1992 Mitsubishi Galant VR-4
678/1000
Old 08-08-2005   #32
KcGsXrated
KcGsXrated's Avatar
Drives: 93 Talon Tsi
Send a message via AIM to KcGsXrated
Talking Re: crazy studdering while Reving
Why not just use a DVM and check the coils? Wouldn't that be simpler?
This is my car, just so you all know.
First were going to check and see if there is a short in the ecu. I'd much rather it be somthing like that than deep into the wiring harness, that's just a headache...
That is the next option that we are going to try out. I belive i have a DVM somwhere in the garage..
As far as the baggering goes, theres no point
~~DSK~~
Casey
93 Eagle talon Tsi fwd auto
KcGsXrated is offline   Reply With Quote
Old 08-09-2005   #33
Pimpin Dsmstyle
Br0k3N
Matt ( alpine TSI) went through the trouble to come down and figure out the problem. I'm glad he did because it was quite a bit beyond my electrical knowledge. If he feels the need to chime in and add detail, you can get more specs but until then, this is what I can tell you.
Basically one of the 2 wires going into the injector clip located on the top of injector number 1, was shorted somewhere. He ran a line to another source of signal or power ( cant remember with already lol) and now it works.
Bad thing - Check engine light pops on while at idle, and while no gas is applied. My guess is that the ecu thinks the injector isnt getting a signal but im not sure. It runs fine.
It wasnt very EASY to figure out, as he had to test a lot of crap with minimal tooling. However he did a great job and if for some reason he wanted to and someone needed help with electrical, I'd recommend him.
- Josh L.P.
Old 08-10-2005   #34
Alpine TSi
Banana Hammock!
Alpine TSi's Avatar
Drives: Shitbox
Thanks, now get that ECU taken care of! Unless you enjoy the smell of dead fish
320awhp/320lb-ft tq
12.772 @ 108.57
678/1000
Old 08-14-2005   #35
Pimpin Dsmstyle
Br0k3N
BUMP -
Would kind of like to know why the engine light comes on while at idle.. I dont have a scanner to check the code. I think its the way we wired it..
- Josh L.P.
Old 08-17-2005   #36
KcGsXrated
KcGsXrated's Avatar
Bump, it's my car ~ I'd like to know aswell.
~~DSK~~
Casey
Old 08-17-2005   #37
EclipseGST
EclipseGST's Avatar
Drives: Short Bus
BUMP -
Well get one and find out. Thats the only way to check. Cant tell whats wrong with your car by looking at it, go to autozone or find someone that has a pocketlogger and pull the code.
Originally Posted by shoutbox
Old 08-17-2005   #38
Alpine TSi
Banana Hammock!
Alpine TSi's Avatar
Drives: Shitbox
Get the caps done, then worry about the CEL. Seriously, that damage to the board can't be doing any good.
If needed I have a logger and a cable that is now functioning correctly if you wanted to get the code figured out.
Matt
320awhp/320lb-ft tq
12.772 @ 108.57
678/1000
