Old 01-03-2006   #21
Re: Megasquirt Vs. DSMlink
I think he got bit by the "detonation monster". Or didn't torque a rod bolt correctly.
I liked how they were picking up the pieces thinking they wouldn't be hot.
Old 01-06-2006   #22
CarPsyco84
CarPsyco84's Avatar
Came across this... sounds intersesting... I might be doing this, just cause of the fast I have a handle on a free MS 1 that my buddy bought and has no use for, and I need to get an intake senser other than a 1G one...
-When in doubt, Moar RPM.
Old 01-06-2006   #23
CarPsyco84
CarPsyco84's Avatar
http://www.diyautotune.com/tech_arti...alon_laser.htm
Old 01-06-2006   #24
EclipseGST
EclipseGST's Avatar
Drives: Short Bus
Originally Posted by ecoli
I have no idea why it takes 35psi to make only 450whp on a turbo that big, and then somehow manage to blow up the motor. Even weak 7-bolts can handle over 500whp and back when I had my 7-bolt 2.0l and a little 54-trim stage 2 turbo, it made 450whp at 25psi.
This is what the guy said... Ran 11.9 @ 119 on this turbo.
Originally Posted by squeak10686
Ran it on a pte scm60... the car blew up on the dyno, but all is well because next year will have MUCH more in store
shit happens, the car wasnt meant to run the 500WHP that day
that and that turbo shouldnt make peak power at 6200 RPMS I need an intake manifold BADLY!!!!!
the car will be 500 off the bottle hopefully come soon!
I guess he has a GT35r now.
Originally Posted by shoutbox
Old 01-06-2006   #25
It's free until it cost you an engine. Go buy DSMLink and save yourself some money.
Old 01-07-2006   #26
zxdude
I thought someone would have mentioned ecu+... cheaper than dsmlink and no need for a eprom ecu. hell you can even run blow thru on a gm sensor without having the gm maft... I suggest you guys check it out...
http://ecuplus.com
zxdude is offline   Reply With Quote
Old 01-07-2006   #27
ECUPlus is a piggyback system like an S-AFC or E-Manage. It isn't in the same league as a standalone system like Megasquirt or stock ECU manipulation like DSMLink.
Old 01-07-2006   #28
CarPsyco84
CarPsyco84's Avatar
I don't think "IT" costs people engines, I think its the people tuning em.... cause its not user friendly and they dont know what the hell their doing, so they just guess....
