Old 01-05-2006   #21
Re: Gt35r
Originally Posted by ther1pper
same question for me
YES, YES, & YES.
Old 01-05-2006   #22
Re: Gt35r
Joe, don't worry about a bigger turbo yet. Get the other stuff you need to run a bigger turbo first. Unless you're gonna just let it sit on a shelf, in that case go ahead so I can come over and steal it.
Old 01-05-2006   #23
ther1pper
ther1pper's Avatar
Send a message via AIM to ther1pper
Re: Gt35r
just wondering for future preferences kevin
ther1pper is offline   Reply With Quote
Old 01-06-2006   #24
zxdude
Re: Gt35r
Originally Posted by SlowWhite
exactly My turbo doesn't hit full spool till about 5800rpms starts building boost at about 4K
My Dyno chart is located here:
http://www.scottbarton.net/Brian/Eclipse%20Test%20Page/
Im assuming that its not a dual ball bearing?... I have a freind with what I believe is this turbo and he sees about 30 psi between 4 - 4.5k rpms.. I'll double check and see what turbo he actaully has.
zxdude is offline   Reply With Quote
Old 01-06-2006   #25
zxdude
Re: Gt35r
I found out he has a fp3065... and he was seeing about 30 psi at 4500 rpms ( This is on a completely built engine.)
Old 01-06-2006   #26
Re: Gt35r
look below
Old 01-06-2006   #27
Re: Gt35r
So could FP build me, basically, a tun of the mill GT35R but using their exhaust housing?
Old 01-06-2006   #28
Re: Gt35r
That would be an FP3565.
Old 01-06-2006   #29
slowbubblecar
Big Turbo Monster
slowbubblecar's Avatar
Drives: GTS and E55
Re: Gt35r
Originally Posted by zxdude
the gt35r will see 30 psi around 4000 rpms, much less than 30 psi means you picked the wrong turbo. a 60-1 will perform about the same but it will take longer to spool back up between shifts.
Defenitely not. On a stock 6 bolt, I would guess it would spool 25psi by close to 5000 with the 82 ar hot side. THe last turbo I used had the same 82 ar hot side and it was around that on a stock 6 bolt. I have a new 82 ar GT35R waiting to go on my car now but if you are really interested in getting one, PM me before you buy one. I'd sell mine for cheaper than you can find them new.
7/25/09
Old 01-07-2006   #30
Re: Gt35r
Jesus you guys have everything. And it's all for sale haha.
