Go Back   MitsuStyle > Hosted Support Forums > LSE Performance
Closed Thread
Old 03-06-2007   #1
Re: Finally getting stuff done on our cars
Gotta love the Weld-els!!!!
Halon is offline
Old 03-06-2007   #2
Man that looks like total crap, I'd tear that apart and re-do it. Let me know if you need me to show you how to actually weld.
....JBWeld that is.
scheides is offline
Old 03-06-2007   #3
....JBWeld that is.
JB welding is an aquired skill! I might have to hit you up for some lessons, as I haven't done it in years I might need a refresher course .
niterydr is offline
Old 03-06-2007   #4
Yea, it's all about not touching *anything* except what you are welding together, and then as soon as your finger leaves the welding surface doubling back and wiping it with a paper towel. Pretty tough to get it right, really. If you want to do some practice JB Welding I do *not* suggest masturbation!!!
scheides is offline
Old 03-06-2007   #5
Welding that IC was fun, inside/outside welded endtanks and in/out pipes. Then I used almost all the TIGs power to weld the endtank to the IC core, and about 4 24"x 1/8" alum. rod for one front weld. Chris came in the shop 2-3hours after I welded the IC and he said "hey you just get done welding that", It was a little hot. I will do some weld samples tonight and we will get pics up, it will be nice for the show floor anyways. So SS ic piping, Mild steel/chrome moly cage tube welds, Aluminum welding, and schedual 40 304 SS for the race tubular headers.
Pushit2.0 is offline
Old 03-07-2007   #6
Swifty1638
Unsure resident asshole
Swifty1638's Avatar
Yea, right. Try it! The goal is to get off, before the JB hardens!
-A. Swift
Black 1GB Mafia #1
744AWHP/526TQ-Shootout mode
639.6AWHP/452TQ-DB's dyno
I wanna go fast.
Swifty1638 is offline
Old 03-07-2007   #7
-A. Swift
That is enough!
/topic of JB weld on this thread.
niterydr is offline
Old 03-07-2007   #8
That is enough!
I just laughed so hard I think I woke my roommate up.
Matt D. is offline
Old 03-08-2007   #10
The digital camera does not want to take a good close up pick for the welds, sorry jakey. I did get some more work done tonight, pics should be up sometime tomorrow. IC pipe is done, down pipe just needs a vband, water to air is mounted now I just need to fab up the custom endtank on the intake manifold side, exhaust manifold is done minus waste gate, then the Intake manifold with a q45 TB is my next project.
Old 03-08-2007   #11
PSI2HI
Divided housing, or no?
PSI2HI is offline
Old 03-08-2007   #12
Yes.
How have you been?
niterydr is offline
Old 03-08-2007   #13
PSI2HI
Yes.
How have you been?
Running twin gates or single?
Not to bad, pluggin away waiting for winter to be done.
PSI2HI is offline
Old 03-08-2007   #14
I am going to try 1 Tial 38mm with a 1bar spring for pump then add another spring for 1.6bar then a MBC and turn it up untill the head blows off the block, switching fuel at about 35psi. The Tial will be just off the #2 and #3 collector just befor the turbo. If that is not enough then I will add a 2nd waste gate. Right now the manifold is divided with a divided flange and the primary runners are within 1" of equal length.
Old 03-08-2007   #15
PSI2HI
I think your cutting yourself short on wastegate on both boost control and being able to release enough backpressure. What AR turbine?
PSI2HI is offline
Old 03-08-2007   #16
Then I will look at a 44 or 46 Tial or similar.
Old 03-08-2007   #17
PSI2HI
Your just gonna have to trial and error w/ boost control and monitoring back pressure ratio's. Problem is if you set it up for single gate your kinda stuck w/ a single gate unless you kind find some way of cutting the wastegate runners off and salvaging the collector. Baller up and get a TIAL 60mm :-p
PSI2HI is offline
Old 03-08-2007   #18
"Boost control" is a realative term on this car.
Just want to keep it under 40psi.
Yeah same here. Go away snow!
niterydr is offline
Old 03-08-2007   #19
It should be easy to add another Tial off the #2/3 collector. It would just be re coating the manifold.
Old 03-08-2007   #20
92EvilTalon
3.1L v6 power...
92EvilTalon's Avatar
Pit Stop Challenge Champion!
Looks nice John hope to see that White Nissan running again.
Josh LaCroix
92EvilTalon is offline
Closed Thread
