Old 09-25-2009   #1
slo6oh
Drives: vehicles with 6.0 liters
Re: My Talon
sell it!!! its time for something new, and even if you paint it you will still want to sell it. Turbo 6.0 or 5.3 ftw!
slo6oh is offline   Reply With Quote
Old 09-25-2009   #2
Re: My Talon
Well this is kinda old news now, I'm on my THIRD brand new Holset. It's already on the car. About 2 weeks ago, the turbine shaft sheared right in half = gay.
The car is fixed 100% but I'm putting the finishing touches on my bumper cover with a friend's help.
Still for sale
Old 09-26-2009   #3
slo6oh
Re: My Talon
Still for sale
Yeah I know im helping you with it, and no I dont want the car back lol
Old 09-27-2009   #4
Re: My Talon
Still for sale
Geez, bad luck with turbos...bring this beast to the dyno day!
Old 09-27-2009   #5
Re: My Talon
Ok, so $7250 with small dent in hood. Or $7750 with a carbon fiber one!
Old 09-27-2009   #6
Constant_Project21
Constant_Project21's Avatar
Drives: E36
Re: My Talon
I'm planning on winning the lottery here pretty soon, I'll come get it after that lol
Old 09-27-2009   #7
Swifty1638
Unsure resident asshole
Swifty1638's Avatar
Re: My Talon
geez! Now I don't feel so bad about my turbo lol..
Black 1GB Mafia #1
744AWHP/526TQ-Shootout mode
639.6AWHP/452TQ-DB's dyno
I wanna go fast.
Old 10-02-2009   #8
Re: My Talon
Yeah, I'll probably go to something different over winter/spring, but we'll see. It's just too bad, b/c that turbo is awesome, and it's only just getting warmed up at 29psi.
Old 01-02-2010   #9
Re: My Talon
So as some remember my tranny blew up. I paid like $50 for a piece of shit tranny and drove it into storage. I will be getting a shep rebuild AGAIN and will most likely be putting the car up for sale in the spring lol.
Old 01-02-2010   #10
Re: My Talon
That sucks to go through all that hard work to have that tranny issue happen. Good luck with getting that shep rebuild and good luck selling it. I can't believe it never sold, thing is beyond clean!
Old 01-12-2010   #11
Re: My Talon
I might just have twin walbros, bulkhead fittings out of sender to a y block, -8 to rail.
I can't find 1/2" hardline anywhere. wtf?
Old 01-12-2010   #12
Swifty1638
Swifty1638's Avatar
Re: My Talon
twin 255's or 310's?
Hardline shit I got from jegs or summit. With the fittings. It's aluminum.
Black 1GB Mafia #1
I wanna go fast.
Old 01-12-2010   #13
Re: My Talon
You dont need to upgrade the line, plenty have made more power on E85 without changing the lines.
Old 01-12-2010   #14
Constant_Project21
Drives: E36
Re: My Talon
Are you doing anything different turbo wise this year? I recall at the dyno day, you mentioning something about changing it up a bit.
Old 01-12-2010   #15
Re: My Talon
Hey Kevin, what do you think is causing the turbo to keep going to poop?
Old 01-13-2010   #16
Re: My Talon
I don't know. Lots of people on tuners have a theory of too small of oil drain, but I think that is bs. It's -10an. thats 5/8". And it's not from lack of oil, no signs when disected.
I might just have to get goat blowers 3575. But then I'd need a new 02 housing, change my IC pipe, intake, etc.
I will do some investigating. I'm getting a -4 inline with an 1/8npt fitting for an oil pressure gauge. I will also just make a much larger drain with like copper pipe or something.
Old 01-13-2010   #17
Re: My Talon
Let me know what kind of fitting you end up getting, I want to run an oil pressure sender off the feed of my new turbo also. I am feeding off the head, but I still want to be able to know what it is.
Old 01-14-2010   #18
At-Least-It's-An-Evo
At-Least-It's-White-Again
At-Least-It's-An-Evo's Avatar
Drives: 98 iVTEC
Re: My Talon
Just buy Steves turbo. It's a helluva deal imo. Screw those holset junk turbos.
'04 Honda Ricer: stock
Old 03-19-2010   #19
wheelhop
Holset's Sex Bitch
wheelhop's Avatar
Drives: 1990 Eclipse, 1991 Eclipse with a little Holset Sex
Re: My Talon
Holset repair manual itself calls for a 19mm drain line as a MINIMUM. calling the manufacturers requirements bull shit? -10an = 10/16 = less than 16mm diamete. About an . . .
Whats your oil pressure at idle 3K and redline?
Matt
Bolton Holset H1C w/ external gate, fp2X cams, DSMLink, 3" exhaust, FMIC, water injection
"There is nothing better for man than to eat, drink, and see good for all his hard work." Solomon
wheelhop is offline   Reply With Quote
Old 01-13-2010   #20
4g63tcrazy
is Nashty
4g63tcrazy's Avatar
Drives: Cyborg from Japan
Re: My Talon
Posted it before and I'll post it again! Seeing what your oil pressure is that's entering the turbo is a very good idea.
Originally Posted by wheelhop View Post
This is your answer. Don't guess. DSMs kill SO many journal bearing garrett, BW, holset turbos. Because they are all more sensitive to oil changes and especially over oiling. And DSMs change their oil pressure per setup, rpm, motor build, oil pump age, Bshafts, oil pump years, oil cooling, hair part, shoe lace orientation, etc. FAR more than any other engine on the planet. PTE has a bad rep because of sh!tty DSM oiling problems. Its DSM oiling that sucks, not PTE (AKA garrett center sections). It's not the manufacturers fault. Its the haphazard, random oil pressures that dsms run on various setups.
Use any gauge: oil gauge, old fuel pressure gauge, old air compressor gauge, old water pressure gauge for home water feed lines, who cares. Get SOMETHING on there after the lines and restrictions to actually see what your oil pressure is. Rev the motor in neutral and find out the oil pressurea at idle, theoretical spool up rpm, and peak oil pressure (should be at redline). Per the holset repair manual for the hx35/hx40: Warmed up, the oil pressure for the hx35 and hx40 should be no less than 10psi at idle, and no more than 72 psi. It should be no less than 30psi at spooling time and after. A bolton hx35 sees 20psi at about 3700rpms and spools damn early so you had better have 30 psi at 2K or you could be eating turbo bearings. An bolton hx40 sess 20 psi as early as 4K on a 2.0L motor. Check your oil pressure. As stated, you MUST have 30psi during spooling up conditions with these turbos. And you cannot have more than 72 psi pressure at full song.
-1990 Mitsubishi Cyborg 4WD-
