Old 04-09-2010   #421
95talonracer
Finally Tuned...
95talonracer's Avatar
Drives: Spyder GSX
Re: Swifty's never-ending project thread!
Also are you going air filterless too? Or just a really skinny mo fo to fit in between your radiator hose and turbo?
Amsoil Dealer
Old 04-09-2010   #422
Swifty1638
Unsure resident asshole
Swifty1638's Avatar
Thanks guys. Hopefully it will be more then just a collection of crap, but something that actually DOES something.
I thought of smaller wg, but why bother when this one works.
As for the exhaust, it actually has more room then the pic shows, but it will be a feat for john, that's for sure.
Air filter-less for now, yes. The upper rad hose still sorta comes in the way of it all, so when/if I get a filter setup, it will need to be notched. For now though, I got enough "screen" and a clamp to run my own "custom" air filter, with enough extra to be able to change my "screen" out at every oil change/tire rotate/maint. point
Black 1GB Mafia #1
744AWHP/526TQ-Shootout mode
639.6AWHP/452TQ-DB's dyno
I wanna go fast.
Old 04-09-2010   #423
santa
Boost Spike
santa's Avatar
Not, trying to knock his work but that wastegate placement for the exhaust couldn't be in a worse spot lol.
Old 04-09-2010   #424
So whats left, Lower IC pipe, exhaust and oil lines?
Old 04-09-2010   #425
Swifty1638
Swifty1638's Avatar
oil return, lower ic pipe, exhaust, wg dump, and fluids.
Black 1GB Mafia #1
I wanna go fast.
Old 04-10-2010   #426
I'm gonna be cutting my front motor mount and reinforcing it to make more room for my oil return!
There really is less room for you I bet!
Old 04-10-2010   #427
Swifty1638
Swifty1638's Avatar
Lots less room. I have no idea how I'm going to route this shit.
Black 1GB Mafia #1
I wanna go fast.
Old 04-10-2010   #428
tehehodi
Braaaaaaaap!
tehehodi's Avatar
Drives: '09 Silveraydo
Good Luck! It's looking Hot!
Old 04-10-2010   #429
Why risk engine damage by not running a filter? You've put an awful lot of time and money into this setup to be basically sandblasting your combustion chamber and turbo with every revolution. The screen will keep bugs, rocks, and birds (yes I have a friend who sucked a baby bird into his filterless turbo hatch), but it won't keep out the smaller particles that can really do damage over time.
Old 04-10-2010   #430
I say extend the upper rad hose a bit so it has a bump up to it, and put a nice big foam filter from Uni and keep it safe: http://www.unifilter.com/onlinecatalog.html
The guy I sold my 35r to off of my 2g ran it filterless w/ a maf-t setup (he put some nice mesh stuff over it). I saw the setup about 3000 miles later and the compressor wheel was absolutely fuct.
Old 04-10-2010   #431
looks good, but man I thought my engine bay was tight to get the dump tubes,exhaust in there. looks like this has a lot less room than mine
Old 04-10-2010   #432
You should get one of those flexible rad hoses like mark runs
Old 04-10-2010   #433
How much longer until it's running?
Old 04-10-2010   #434
Swifty1638
Swifty1638's Avatar
Gotta make the lower ic pipe, exhaust dump, wg, and then fluids. I hope not much longer, but we will see.
You guys must remember, the turbo is on TOP, not down lower, where it's more prone to debris. Yea, A filter/intake would be a nice option, but as of right now, I dunno how that's going to be possible.
Black 1GB Mafia #1
I wanna go fast.
Old 04-10-2010   #435
Want to see how prone any part of an engine bay is to debris? Just look under my hood sometime. Don't be dumb, protect your investment.
Old 04-10-2010   #436
At-Least-It's-An-Evo
At-Least-It's-White-Again
At-Least-It's-An-Evo's Avatar
Drives: 98 iVTEC
Hopefully you're revving to 10k+. The 61 kinda wanted to spool, the 67 sorta did by 6.5k,
...how's a 70 suppose to?
'04 Honda Ricer: stock
Old 04-10-2010   #437
Swifty1638
Swifty1638's Avatar
71mm,
Black 1GB Mafia #1
I wanna go fast.
Old 04-10-2010   #438
tehehodi
Braaaaaaaap!
tehehodi's Avatar
Spool? whats spool?
LOL, I hope you have that revving bug fixed!
Old 04-10-2010   #439
Swifty1638
Swifty1638's Avatar
Me too. We shall see. If not, this will be the most expensive bonfire I've ever lit up.
Black 1GB Mafia #1
I wanna go fast.
Old 04-10-2010   #440
Topmount manifolds are also usually horribly laggy.
You have to run a filter, they don't hurt power. It's going to suck in every piece of dirt in that engine bay. Your turbo will be destroyed and motor full of dirt in no time. Right behind the radiator is also a terrible place to suck in air, you should try to run a pipe(with a filter on the end of it) down into a fender well or atleast behind one of the headlights and pull the headlight at the track. 80 degree air is much better than 120 degree+ air.
