Old 07-09-2013   #441
Re: 2G auto S/A daily
Nice, glad it was an easy fix!
Old 07-10-2013   #442
CornFed2.4
CornFed2.4's Avatar
Drives: You crazy!
Shift box is in and works awesome!
Next thing I have to do is a knock sensor.
Old 07-10-2013   #443
4seasons69
4seasons69's Avatar
nice! you going to run this thing this weekend? or do you still need more tuning?
Old 07-10-2013   #444
blackawdtsi
Drives: 2G DSM
Needs tuning, period. It's up to him when it happens, though.
Old 07-10-2013   #445
4seasons69
4seasons69's Avatar
gotcha!
Old 07-10-2013   #446
CornFed2.4
CornFed2.4's Avatar
Drives: You crazy!
Yeah more tuning. Tom should have time Friday of you wanna go out.
Old 07-13-2013   #447
blackawdtsi
Drives: 2G DSM
Nick, download and unzip this.
The attached files should do what you're looking for.
Just save them into the following directory:
Windows XP:
C:\Documents and Settings\<username>\ecmlink\resources\records
Windows Vista/Windows 7:
C:\Users\<username>\ecmlink\resources\records
The directory should already exist, so if it doesn't, you may be looking in the wrong place.
Once you have one of the files installed, bring up or restart the ECMLink application. When you connect to your ECU, you'll have a new direct access entry call KnockDisable or something along those lines.
Instructions for usage are at the bottom of the KnockDisable tab. You can always revert back to stock by clicking on the "stock" button in direct access while viewing that tab and then hitting Save to ECU.
Old 07-14-2013   #448
CornFed2.4
CornFed2.4's Avatar
Drives: You crazy!
So trying to stall my car and seeing if I can build boost. It kinda works but can only build 6 before pushing threw the brakes.
Here's what happening.
When I hold the brakes down and give it gas the brake pedal pushes up like there's no vacuum.
I have a 1g intake and tom said there is a check valve on 1G brake boosters. Well mines a 2G and I don't see that on mine.
Wondering if anyone has had this issue and what to do to fix it.
I've read toucan pump the brakes while the car is off to relief vacuum pressure in the line.
Thanks
Old 07-14-2013   #449
93gtpeater
Drives: cbr 1000rr repsol
Maybe put in a check valve?
Old 07-14-2013   #450
I'd put in a check valve if it doesn't have one.
Old 07-14-2013   #451
CornFed2.4
CornFed2.4's Avatar
Drives: You crazy!
Yeah I will I'm gonna look at the 2g mani when I get home see if there's one on there.
Old 07-14-2013   #452
EclipseGST
EclipseGST's Avatar
Drives: Short Bus
There should be a factory check valve on the booster (2g)... Right were the vacuum line attaches to the booster. Even with the check valve I'm sure you will blow through the brakes.
I'd just buy a electric vacuum pump from Summit and wire it to the brake switch. Thats what we are doing with Vassils car. Get rid of the line on the manifold and every time you hit the brake pedal, the vacuum pump comes on and creates awesome vacuum for the booster.
Originally Posted by shoutbox
Old 07-14-2013   #453
CornFed2.4
CornFed2.4's Avatar
Drives: You crazy!
Fixed. Just had to put a stock line in.
Old 07-14-2013   #454
CornFed2.4
CornFed2.4's Avatar
Drives: You crazy!
Ok jake ill look into that. I know people use vw pumps?
Old 07-14-2013   #455
carltalon
carltalon's Avatar
Drives: 98 Eclipse GSX Auto
I have the VW pump it works Awesome. Have you done any more tuning?
11.35 @ 120mph
Old 07-14-2013   #456
CornFed2.4
CornFed2.4's Avatar
Drives: You crazy!
Gonna try to get out tomorrow.
What V-dub pump did you use?
Old 07-15-2013   #457
Nice, glad to hear it was easy fix.
Old 07-15-2013   #458
tehehodi
Braaaaaaaap!
tehehodi's Avatar
Drives: '09 Silveraydo
Audi also has vacuum pumps, they use them to lock the doors.
Old 07-16-2013   #459
CornFed2.4
CornFed2.4's Avatar
Drives: You crazy!
Dropped off a turbo to Aaron and went out to test the stall.
Kinda showed me a few tricks and they worked pretty well. Got the car to stall up pretty good and didn't move an inch. Then as I let go I quickly ran out of first with no shiftbox in hand so I got out.
Ended up doing so knock sensor logging to and only are seeing .04 degrees of knock so all is well there. Car is running around 11afr and timing is safe so hoping Shane can squeeze every last hp out of this setup.
Also looking at the logs we found that the turbo is moving 55lbs/min of air at 25psi. So at 30+ I'm hoping it will run me into the tens.
A couple more street outings and a tune date set for the 24th and I should be ready to make my first pass in the auto. Now I just need to check some schedules.
Old 07-17-2013   #460
4seasons69
4seasons69's Avatar
Awesome! can't wait to see the final results!!!!
