Build the X 17 56.67%
Old 05-07-2010   #1
Murlo26
Murlo26's Avatar
Drives: 17 Honda Accord
Re: Dave's Evo X Build
Well my temp car as of now is my buddy's Dodge stratus (hes the guy that was with us Lomker with the G8). I just spoke with him about arranging a rental for it, probably a few hundred bucks for the whole time i have it or monthly like 50 or something.
So if i can use his stratus, i am in business.
SIDE NOTE: UPDATE....
I have thought about this every way possible...logically, mathematically, financially and emotionally...the two options that were narrowed down were make my car stock, part it out and drive it that way or build the bastard. Since I obviously wasn't happen with the car at stock levels and I don't want to loss thousands of dollars... i have landed on this..
Keep it and build it! So now the fun begins...going to try and tow it somewhere next week and figure out a final parts list and who will do the work and what is still good on the car. I love both MAP and DB and it will be hard to choose between the two and I will feel bad for who I don't chose since they both gave me very solid quotes and I try to spread my love equally.
Also I will probably be selling my Fpred (assuming it is still good)to help fund the project since I will need all the funds i can get. So yes I will have a fully built motor capable of like 650-700whp no problem running the stock turbo for a while
Old 05-07-2010   #2
rose0529
Who has my man-card?
rose0529's Avatar
Drives: a red car
YAY!!! Can't wait to see this beast when your done!! Very interested to see what the cause is when you rip into it! I would have ripped into it by now to have a look around!
Old 05-07-2010   #3
Murlo26
Murlo26's Avatar
Tomorrow I am going to start cleaning it up and taking the undertray off to see the carnage more closely. I got it up on jackstands already.
Old 05-07-2010   #4
^Give me a shout if you want a hand or something.
Old 05-07-2010   #5
Murlo26
Murlo26's Avatar
Will do, thanks for the offer.
I don't want to get too crazy since the car will be moving, hopefully soon so don't want to take all sorts of crap off.
But thanks again and if I see something i want to investigate and need some help i will post up.
Old 05-07-2010   #6
t-revzr
FLOSSEN
t-revzr's Avatar
Drives: 2011 corolla turbo S
Awesome Dave glad you are keepin it! I wanna stop over tomorrow and take a look at it if you dont care?
t-revzr is offline   Reply With Quote
Old 05-07-2010   #7
Good to hear. Let us know when you need a hand.
Old 05-07-2010   #8
Murlo26
Murlo26's Avatar
Sure thing, toss me a text, 651-269-4715.
I will hopefully be up sometime kind of early. Tomorrow yard work needs to happen since all of my yard repair money is going into the car now.
After some yard work I will take a crack at cleaning the X engine bay a bit and pulling the undertray off to look at the air vent i created.
Old 05-07-2010   #9
mlomker
*Resting In Peace*
mlomker's Avatar
I would have had the head off by now, myself...no doubt. Can't hurt it anymore at this point.
Old 05-07-2010   #10
Murlo26
Murlo26's Avatar
True, but I have been pretty bummed this last week so i haven't felt like doing anything with it.
Old 05-10-2010   #11
Murlo26
Murlo26's Avatar
Well i am going to tow my car up to DB this saturday during the dyno day. I will be up there anyway so figured i would kill two birds with one stone.
I spoke with Danny again and he made a lot of sense and seems very direct and honest about why he suggested what he did.
I feel like Chris may be mad at me a bit since I didn't chose MAP but the way that danny quoted the build made more sense to me.
MAP's labor costs were considerably higher because they were factoring in a bore and hone of the block. If i went with a used core that would make sense, but Danny suggested we just go with a new OEM shortblock and then Mitsubishi does all that Machine work anyway. He said he would check clearances and file down the rings and everything so we should be good to go.
I don't think MAP's way was bad just unnecessary if you have a new block. Otherwise no one would be able to do drop in's ever if they had to bore/hone the motor.
Regardless, I spoke with another Mechanic, one of my best friends who has an SR20det'ed 240 which is very similar to the 4b11t and he said the stock shortblock that is new would work perfect and that is what he would recommend.
So it is decided. I apologized to Chris for any nonsense I created but I have given them a lot of business already, as well as DB, so now it is time to get down to business and start this project up.
I will probably get my diff pins upgrading while the motor is out too as a side note.
Also talked with my bank on friday and they are going to give me a loan based on the car as collateral. since with my super low interest rate on the X a refinance wouldn't make sense.
Lets do eeetttt.
Old 05-10-2010   #12
v8klla
v8klla's Avatar
I'm not mad sir lol, the truth is we're months out on labor anyways I just wanted to get another Evo X build under our belt so we could further the market those services on a national and international level.
To clear things up, we were also open to using a new stock block to avoid the machining costs. I simply had to warn you that aftermarket pistons generally run larger piston to wall clearances and that we wouldn't know for sure that no additional hone would be necessary until we had all of the parts spec'd out. If you recall you were the one that didn't want any additional charges popping up down the line
Chris Carey, President
Modern Automotive Performance
P: 763-545-3800
E: chris@maperformance.com
Old 05-10-2010   #13
Murlo26
Murlo26's Avatar
Well thanks for clearing it up, it honestly wasn't an easy decision for me and I respect your honesty. I think truly the reason I ended up at DB was simply because I have Shane tune the car, so it would be easier to have one shop do the work and if something went wrong it wasn't a who's to blame thing.
I am happy that you don't hold a grudge, thank you for that. As I had said before, I like both shops very much. I guess it seemed through our emails/talks that you guys would've preferred to play it safe and bore/hone the motor. Obviously there is significant cost associated with that.
Regardless, thank you for your time Chris, i really do appreciate it.
Old 05-10-2010   #14
Well, game on then! Getting the head ported while its off?
Old 05-10-2010   #15
Judging by the powercurves i've seen it looks like those heads flow amazingly well bone stock.
Old 05-10-2010   #16
Badass, you going to tear it apart before hand?
Don't worry about who u picked to do the work, its a nature of the business, but you got your point across about being a thoughtful customer.
Congrats on your decision to keep the car hopefully you won't try to push it this time and get to enjoy it a lot longer.
Old 05-10-2010   #17
Murlo26
Murlo26's Avatar
Pictures and a wtf happened will ensue yes.
Old 05-10-2010   #18
^Cool, like i always say man, I'm local and willing to lend a hand.
Of course unless you don't want some lowly DSM hack touching your X. lol
Old 05-10-2010   #19
Murlo26
Murlo26's Avatar
I am always done for having a helping hand...plus you DSM guys are sneaky, you guys know all sorts of neat tricks.
But honestly, aside from possibly needing some help pushing my car onto a trailer, I don't think I will need anything any time soon. But I will post up if I do
Old 05-10-2010   #20
They do, but knowing how these X guys spend $$$
Tags
