Old 08-15-2012   #461
Re: Big Brown's Automagic - The last episode in my DSM story.
Turn the motor, 2 speed powerglide. Oh wait, Buschur did that in the 90s.
Old 08-15-2012   #462
Sounds like Brown has some work to do!
Old 08-15-2012   #463
munchgsx
munchgsx's Avatar
Drives: 2004 Corvette M6 F45
The solenoid only have one 4-wire plug and are very easy to ohm. Check out Kigglys site and match the wire colors, I believe a is yellow and b is orange. Its the single four pin plug that goes into the front of the transmission.
Converted to LS
Old 08-15-2012   #464
munchgsx
munchgsx's Avatar
I think I still have a solenoid too.
Converted to LS
Old 08-15-2012   #465
tehehodi
Braaaaaaaap!
tehehodi's Avatar
Drives: '09 Silveraydo
15 speed mack truck son! Hi and lo gear for racering and hwy cruise. Great gas mileage.
Old 08-15-2012   #466
CVT.
Old 08-15-2012   #467
munchgsx
munchgsx's Avatar
Ahh airplane propeller out the front.
Converted to LS
Old 08-15-2012   #468
SOld. VB is out of the car, I'm failing somewhere testing it though.
Old 08-16-2012   #469
So far everything points to the shift solenoid A being bad, I picked up some replacements that ohm'd out good so hopefully this will do the trick.
I also increased my pressures manually since I had the VB out, sadly the trans fluid was pretty dirty and did have some debris in the pan.
Looks like this winter I may have to send out the trans to get built instead of a motor.
Also no-one appears to stock the pan gasket I need so I'm updating this instead of testing the new solenoids.
Old 08-16-2012   #470
RTV is your friend in times like this.
Old 08-16-2012   #471
No thanks, I'll either do it late tonight or get up early and do it in the am. I'd rather do it right. OF course unless anyone in here has RTV'd their transmission pans in a upped pressured car.
Old 08-16-2012   #472
blackrosenova400
blackrosenova400's Avatar
Upped control pressure should not pressurize the trans case, just the control main used for your hydraulic circuits.
Ultra grey would work fine if it was allowed to be cured, but I think the trans does use a gasket from the factory.
I use full main pressure after 9 psi of boost, but I am using a gasket.
20g Mafia
Old 08-16-2012   #473
Murlo26
Murlo26's Avatar
Drives: 17 Honda Accord
New Evo's don't even use oil pan gaskets, its all RTV...but I am not sure the pressure seen there vs a trans one.
Old 08-16-2012   #474
blackrosenova400
The only way the transmission pan will see pressure is if the breather is plugged while the fluid heats up.
20g Mafia
Old 08-16-2012   #475
munchgsx
munchgsx's Avatar
If I see RTV on that pan I'm gonna kick you. Buy a filter it comes with a gasket.
Converted to LS
Old 08-16-2012   #476
carltalon
carltalon's Avatar
Drives: 98 Eclipse GSX Auto
I used black oil resistant RTV on both of my transmission pans with no problems. None of my local parts stores ever had gaskets in stock.
11.35 @ 120mph
Old 08-16-2012   #477
Lol you guys are silly. RTV seals better than a gasket IMO.
Old 08-16-2012   #478
munchgsx
munchgsx's Avatar
Comes from the factory with a gasket, should remain a gasket.
Converted to LS
Old 08-16-2012   #479
Tell that to human trannys.
Old 08-16-2012   #480
Murlo26
Murlo26's Avatar
Is it trannys or trannies?
