Old 09-01-2010   #481
Re: 91 Galant VR4
Not yet, I am trying it get to Rock Falls on the 11th.
Old 09-01-2010   #482
Murlo26
Murlo26's Avatar
Drives: 17 Honda Accord
Re: 91 Galant VR4
Good luck, hopefully you get there...that was my goal too, ain't going to quite make it.
Old 09-02-2010   #483
Re: 91 Galant VR4
Very excite. The wiring looks pretty good. I have found that electrical tape is pretty crappy for higher heat, oily, dirty environments. Someone does make wiring harness tape which is different. I don't know where to get it off hand but I'm sure it's not too bad to find. Post up if you are going to RF on the 11th, I might like to go and see that.
Old 09-06-2010   #484
Re: 91 Galant VR4
I put 30 miles on the car yesterday and I have dyno time setup for this week. The car should be at the track sep 11th for some shake down runs.
Old 09-10-2010   #485
Re: 91 Galant VR4
I had to turn the boost controller up 1/4 turn to get it back to the boost it was running before. It looks like the clutch broke in a little sense the last dyno session. The car spools up about 400rpm sooner. The only things to changer were moving the 1600's to the stock location with a custom, but smaller fuel rail, the new AEM EMS, a green top CAS, and the new wiring harness. Other then that the plug gap was the same and the injector duty cycles are lower then before, but I did not want to push the setup any further until it hits the track.
I am heading to rock falls saturday, I am swapping the sticky tires on after work tomorrow and towing it out there.
I have good video of the car on the dyno, and I will be getting video at the track also. Then I just need to post it on Youtube.
Thanks Shane for another great tune.
Old 09-10-2010   #486
Re: 91 Galant VR4
Awesome that you have better spool and lower duty cycles while making more power. Nice power, can't wait to see the track results.
Old 09-10-2010   #487
awd-drifter
'2of9'
awd-drifter's Avatar
Drives: Racer Van V6
Re: 91 Galant VR4
Such nice numbers John. Crossing my fingers for you to hit 9s!
ლ(ಠ益ಠლ)
Old 09-10-2010   #488
Re: 91 Galant VR4
I sure hope I can make it to rock falls this saturday. Work sucks!
btw, my hoodie smells like 650 at the wheels.
Old 09-10-2010   #489
URV8SUX
URV8SUX's Avatar
Re: 91 Galant VR4
Good numbers I see Shane did another good tune!!! Good luch at the track.
Old 09-10-2010   #490
Re: 91 Galant VR4
Awesome dude! Weve been waiting a long time to see this beast do some work again!
Old 09-12-2010   #491
Re: 91 Galant VR4
The car made it threw the shake down runs at Rock Falls. Due to towing issues I was late to the track but did get 2 runs in.
.069 away from the single digit club.
The first run I spun a little in 1st with a little wheel hop, 2.1 60', for the first launch with this setup I think it was ok. Then I shifted to 2nd gear at 9500rpm, and the car planted and just took off straight as an arrow, I nailed the 2/3 shift at 9500rpm and ran out 3rd before the 1/8th mile. I tapped the rev limiter before the 3/4 shift and drove it home, I had 1 hand on the wheel and the other was fist pumping with joy as I crossed the line at 9200rpm in 4th. Then the only scary part of running this fast at Rock Falls, I had to stop, in a hurry.
The 2nd run I was in the spectator lane, and they just finished track prep about 10 cars in front of me. I noticed a lot more traction in the burn out box. So I upped the launch rpm and did a little more clutch slip, 1.8 60' time, I short shifted into 2nd and then it did its thing just like the first run. And I may have lifted just a hair early to get slowed down.
The track official came over to have a talk at the end of the run, he started asking about all the safety stuff, neck brace, gloves, pants, shoes, certified chassis, etc. I said I just wanted to run fast enough first, and he said well you are fast enough, this is your one and only warning.
Then heading back to the pit the car just died, I think the aem dumped the tune and I forgot to make a copy, so I will get the tune from Shane and load it back in there.
If I can get the 60' down to a 1.4-1.5 that would put me in the mid to low 9s @148mph. For the shake down runs the car was amazing. I have video of the runs and I will try to get them up soon.
This was only the 2nd time I tried to launch the car. It is running E-85 and 38psi, the drag radials had 30psi all around. If we were able to get more runs we would have started to lower the tire pressure.
Here is the time slip, my car number was 1219:
Old 09-12-2010   #492
Re: 91 Galant VR4
way to go.
Old 09-12-2010   #493
awd-drifter
'2of9'
Re: 91 Galant VR4
congrats. that low 9 will make you have the fastest gvr4 in the world! great job john!
ლ(ಠ益ಠლ)
Old 09-12-2010   #494
Re: 91 Galant VR4
Congrats John!!
Old 09-12-2010   #495
428gt
Re: 91 Galant VR4
Nice job! Looks like you are making good progress! Have you weighed the car yet?
428gt is offline   Reply With Quote
Old 09-12-2010   #496
Re: 91 Galant VR4
2400 w/o driver.
Old 09-12-2010   #497
428gt
Re: 91 Galant VR4
2400 w/o driver.
I suppose I could have read that in your sig.
Old 09-12-2010   #498
Speedfreak
Drives: four tires
Re: 91 Galant VR4
Congrats John. That's gotta be a great feeling after all the time and effort you've put into your car.
Old 09-12-2010   #499
EVOMR05
Mommy
Re: 91 Galant VR4
congrats son!
EVOMR05 is offline   Reply With Quote
Old 09-12-2010   #500
Re: 91 Galant VR4
Awesome!!!
