Old 07-24-2013   #481
97gsexx
97gsexx's Avatar
Drives: 97 talon
Re: 2G auto S/A daily
From what I have read, brp7es with a .024 gap are the way to go. I currently have br7es plugs and have tried different gaps and I get knock every time. I am going to pick up some bpr's tonight and see if it changes anything.
Good luck with the tune, mine is scheduled for the 31st!
97 gsx (sold)
97 talon tsi awd 🐼
Old 07-24-2013   #482
4seasons69
4seasons69's Avatar
I'm on bpr8es gapped to .18. My old talon was bpr7es and when Shane tuned it he gapped them to .20
Old 07-25-2013   #483
CornFed2.4
CornFed2.4's Avatar
Drives: You crazy!
So made it to the dyno. No ill effects minus running out if fuel. Which is fine I surpassed my hp goal with the car with at least 8 lbs of boost left on the table.
So here is a quick run down of the setup.
2.4 fully built
1G head
S2 cams
Gsc beehives
1100 high z
255 hp rewired
Bolt on 3076 8cm fp hotside tdo6h4 turbine
These #s were through an auto at 22-23 lbs of boost and 17-18 peak timing
Shootout
Uncorrected
Plan as of right now is to get to the track and see what it runs.
In the meantime ill be looking for some 2150s and a walbro 450.
Huge thanks to Shane @ DB. I know I was shocked at the #s and the fact I ran out of fuel but I don't think I was the only one.
Next update should be a timeslip
Old 07-25-2013   #484
CornFed2.4
CornFed2.4's Avatar
Drives: You crazy!
Sweet DP
Old 07-25-2013   #485
carltalon
carltalon's Avatar
Drives: 98 Eclipse GSX Auto
I cant wait to see what this thing is going to do at the track. If it doesn't go 10's on the first pass I'll be very surprised. I am regretting not sticking around long enuf to get a ride after the tune. Did you do any pulls on your way home?
11.35 @ 120mph
Old 07-25-2013   #486
CornFed2.4
CornFed2.4's Avatar
Drives: You crazy!
I had to go to chaska after so I sat in a lot if traffic.
I didn't get to play till I got on 65 by Aaron's but glad I waiting car just pulls and pulls.
Old 07-25-2013   #487
Damn, wish I could have stayed longer! Made another 50whp after I left.
Old 07-25-2013   #488
Congrats I'll be expecting 125+ trap. (closer to 130 though)
This really makes me rethink a T4 setup.
Old 07-25-2013   #489
Old 07-25-2013   #490
CornFed2.4
CornFed2.4's Avatar
Drives: You crazy!
I'm at 118 @7100-7200 so ill have to bump the rev limiter to 8k. Which should be fine
Old 07-25-2013   #491
Tachyon
Tachyon's Avatar
Drives: Icarus
Good numbers. Looks like the turbo has a bit left in her since boost is still hard as a rock. What was your IDC on those 1100's?
-Sebastian Vettel
Old 07-25-2013   #492
CornFed2.4
CornFed2.4's Avatar
Drives: You crazy!
100%
Old 07-27-2013   #493
CornFed2.4
CornFed2.4's Avatar
Drives: You crazy!
Car broke last night. I think it's just the crank bolts but still sucks as my schedule might not let me touch the car till I'm back from Iowa.
Old 07-27-2013   #494
mark4g63t
mark4g63t's Avatar
Drives: 95 Talon TSI
No0o. Is it bad?
BW8776, e-85
Old 07-27-2013   #495
CornFed2.4
CornFed2.4's Avatar
Drives: You crazy!
Crossing fingers that's all it is and not a broken crank.
Still plan on going to BIR on Wednesday. Just gonna be some long days...
Old 07-28-2013   #496
CornFed2.4
CornFed2.4's Avatar
Drives: You crazy!
Gonna start pulling the trans text if you wanna come out.
651-269-2314
Old 07-28-2013   #497
CornFed2.4
CornFed2.4's Avatar
Drives: You crazy!
Cars apart. Thanks Mr. Woo and Carl through his text message diagnosis and trouble shooting.
So when doing the routine stuff to actually take the trans out this happened.
This came out with the tcase.
Looks like something is missing
So I went searching for the clip. I pulled the center diff and found nothing. No shavings either. Did the person who put the trans together forget this clip? No clue
So now can I get a new clip and just pop it back on?
Also got some decals coming in the mail. Got bored so I had high altitude decals do some up.
Screen name on here
If it runs a ten
Had him do carbon instead of black and red instead of green
I like how it tuned out and the dripping blood is kinda fitting since Tom and I were both bleeding after tonight.
Hope to have it together by Tuesday so I can still make Wednesday night drags at BIR.
Old 07-29-2013   #498
19TsiAwd90
2stepadepaaadepaaadep
19TsiAwd90's Avatar
Drives: myself crazy
well hopefully that was the only issue, and all it takes is a clip!
Originally Posted by 311evo
Old 07-29-2013   #499
4seasons69
4seasons69's Avatar
Project snow white posted those on fb last night. I wondered if they were for you lol. Hopefully you get the car back together soon!
Old 07-29-2013   #500
Good luck.
