Old 04-16-2009   #501
Re: My Winter Upgrades
Well to battle my miss-firing issues, I threw in some brand new BPR6ES's in. Car was miss-firing worse then ever. Cranked the boost down WG pressure, still bucking... OH SHIT what's that, the gas light? DOH!!! Filled it up with gas. Car is running great, no miss-firing. I only got it up to 25psi so far as I was slowly upping the boost to ensure it's running ok at lower boost levels. Tomorrow I'll keep cranking it up, hopefully to 35 again and have no miss-firing issues. If I do, I'll just turn it down to the highest level I can where it doesn't miss-fire.
Annoying...
Old 04-16-2009   #502
haha Paying attention to the gas gauge = win.
Old 04-17-2009   #503
My gas gauge stops going down at about 1/3 or so. The dual pumps get in the way of the Float I think. But the gas light still works, but it's sorta blocked by my boost gauge.
Anyhow, I cranked it up a little over lunch today, and I'm at 30psi now and no miss-firing. I'll crank it up a little bit more after lunch and hope for the best
Old 04-17-2009   #504
lol, I hope for the best too. Don't blow it before I get that ride!
Old 04-18-2009   #505
MustGoFaster
MustGoFaster's Avatar
Drives: A big dirty V8
That's what she said.
Old 04-20-2009   #506
I finally got a ride in this beast over the weekend! Big turbo fun woot! Under 5k the car seems very nice and tame. As soon as you cross over 5k zzzzzoomg woot! Pulls nice and hard up to 8k. Definitely a fast car! I can't wait to give the little blue a run against this, down on power or not!
Also, props to brandon for a nice, clean, good running 1G. Very nice car dude, I really really like what you've done with it.
Old 04-20-2009   #507
Excuses already?
I need a ride before i leave for TX.
Old 04-20-2009   #508
Thanks Scheides!!
I was extremely happy with how well it ran, and how it never overheated. I think the cool weather was partially responsible though. But considering how hard I beat on it this weekend, at 30psi, I am really happy with how well it held together (other then the tire issue after getting some air at a pretty high rate of speed). I just need to get the coolant pushing issue worked out. Other then that, man it ran like a champ, never had a single issue with it the whole time!!
Old 04-20-2009   #509
Did you get some other car besides a DSM?
Old 04-23-2009   #510
Ha!
OK well the new front mount should be here early next week.
The L19 headstuds arrived and are sitting in the garage. One of these days when it looks like we're going to have a lot of rain, I think I'm going to take the head off, and go have the surface remachined. The shop that did it was pretty cheap and not sure how good of a machine job they did on it. Hopefully having it resurfaced will make it smoother, and that combined with the new L19's will hopefully take care of my "pushing coolant" issues.
Old 04-23-2009   #511
Ha!
Remember, having a flat BLOCK surface is key too...
I had a freshly decked head, with a copper sprayed (lol) OEM metal HG that pushed coolant.
Old 04-23-2009   #512
Considering the whole new block has maybe 10k on it, I'd hope it's fairly flat. I would expect the head would warp well before the block would. I will check it though when I pull the head. My roommate has one of those "certified straight edge's" up in his room that I could use.
And if my block isn't perfectly flat, well right now there really isn't much I can do about that. I'm not pulling it out. (waiting for a "that's what she said" remark)
Old 04-23-2009   #513
Yea I'm guessing that head was fairly warped. I blew the headgasket on it and still drove it a few times because I was a dumbass noob at the time, plus it overheated a few times before all that happened. It got to at least 260-270 probably half a dozen times.
Old 04-25-2009   #514
Brandon, what clutch setup are you running?
Old 04-25-2009   #515
Stock Flywheel, Fidanza 4.3 clutch.
Old 04-25-2009   #516
Very light Light cuts on the head. Sometimes by pushing coolant it isn't a non-flat head, but more of the head material compressing and allowing coolant to flow by. The lack of aluminum in my head is what caused my heads to "lift" and push coolant on the stealth in 2005-2006. The higher tensile strength headstuds should help keep it down as well.
Old 04-25-2009   #517
I didn't completely follow those first two sentances. Are you saying I should put very light cuts on my head?
Old 04-25-2009   #518
I'm guessing no. lol. I think he means when you have heads resurfaced a bunch it takes away metal that would otherwise contribute to rigidity.
By very very light, he means take off as little as possible.
Old 04-25-2009   #519
MustGoFaster
Originally Posted by fattyboombatty View Post
i'm guessing no. Lol. I think he means when you have heads resurfaced a bunch it takes away metal that would otherwise contribute to rigidity.
+1
Old 04-28-2009   #520
Well the car decided to leave me stranded on Hwy 96 today. I was sitting there waiting to make a right turn, just idling, and it shut off on me.
Huge thanks to Nick (munchgsx) for coming and towing her home for me.
Car is turning over great, sounds like it has heathy compression, but won't fire up. Won't even come close to firing up, just cranks and cranks. My first thought was it wasn't getting fuel. So while sitting on the shoulder, I checked the ignition and MPI fuses. Both checked out good. I turned the fuel pump on via DSMLink, checked the fuel pressure and it was good, and I could feel the fuel running through the lines. So there went that theory. Got her towed home, and decided to check if I was getting spark. Kinda hard to do with just me and no helper. I unplugged the wires from the plugs, and set them right next to grounded parts of the car, figuring that when I cranked it over, if I have spark I'd hear some arcing. Well, I didn't hear a damn thing. So right now, it's looking like I lost my spark, somehow... I'll have to find someone to help me to verify that though. I'm thinking somehow either my coilpack or transistor died. Which might go hand in hand with my intermittent missfiring I was running into.
Put up a WTB add, so if anyone has a transistor, or coil pack, that I can borrow to see if it fixes the issue. please let me know ASAP!!!!!
