Old 05-21-2008   #541
Re: the evo 3 swap parts are coming
here is some more
pics of the other knuckle and the one that has been ground down to make the brembo brackets fit. Pic was before I did the final clean up on it and did the other knuckle.
Old 05-21-2008   #542
with all the clearness for the brackets first knuckle I did before final clean up
Old 05-21-2008   #543
also got the H&R longer studs put in
Old 05-21-2008   #544
Nice. I'm taking Friday off from work, so if you need a hand with anything, I could probably swing by during the day some time.
Old 05-22-2008   #545
So you're gonna hack off half the bolt head of the caliper brackets to make room for the calipers?
Old 05-22-2008   #546
that was for mock up the hardwear store did not have the right size alen head's in stock so I used the bolts for it
Old 05-22-2008   #547
How are wooden brackets going to hold up? What if you get termites and your brakes fall off? Will you be using Thompson deck sealant?
Old 05-22-2008   #548
thompson wood sealant ftmfw
Old 05-22-2008   #549
the smim just showed up
Old 05-22-2008   #550
Wow, thats nice!
Old 05-22-2008   #551
311evo
311evo's Avatar
slick, looks nice!
Old 05-22-2008   #552
DSM_421
How much did you pay for that thing if you don't mind me asking.
Old 05-22-2008   #553
wants to be sideways...
123abc's Avatar
Drives: Loud cars
That smim is a work of art.
Originally Posted by Matt D.
Originally Posted by 93GSX5SD
Old 05-22-2008   #554
For a knockoff, that's pretty damn nice!
Old 05-22-2008   #555
it is a copy of a hks smim I got it for 250.00 +139.00 for shipping from japan on a great buy they are now up to 480.00+the shipping cost
Old 05-22-2008   #556
I have to thank my dad Ken for doing the coil pack bracket. he made it from a extra 90 dsm coil bracket and some angel iron I had at the house. it is now mounted on to of the A/C pump. I also drilled out the mount hole on a 91+ ignitor and put it were the oem intake bracket was. Dad also made an alum bracket to move the throttle cable so it would work and not bind up. We did a mini wire tuck also. I just have to get a longer hose for the PVC. We also had to redo the fmic piping with a 45 bend and cut the lower pipe shorter. On the smim we had to drill out the bolt holes a bit to get it to fit the bigger studs. But that was the only thing we had to do to it.
now to the pics
Old 05-22-2008   #557
Old 05-22-2008   #558
Old 05-22-2008   #559
also got the autometer cage mounts and got them installed also and cut the cage foam out to put them in and used some 3m spray glue and trimmed the foam to fit back on it all
Old 05-22-2008   #560
HiImBrian
HiImBrian's Avatar
Drives: the girls crazy
wow that is lookin really nice. Sweet pick up with that smim too!
pics or gtfo
