Old 01-19-2014   #1
Re: Mark's 1G Winter Projects
Dayum, shiny!! What's the purpose of the rear cover, more fluid, higher fill hole, more bling? Strength? Either way, hotness.
Old 01-19-2014   #2
Strength I believe.
Old 01-19-2014   #3
Fejery4491
Fejery4491's Avatar
Drives: 97 Mitsubishi Eclipse GSX
Its for strength. But definitely offers a touch more of the bling factor than a factory cover haha
Fejery4491 is offline   Reply With Quote
Old 01-19-2014   #4
b00sted_spyder
The stud keeps the differential caps from backing out if it ever happens.
Old 01-19-2014   #5
Mark Leasure
Mark Leasure's Avatar
It helps avoid bearing cap deflection on the ring gear. It keeps the ring & pinion mated properly, that's the theory. I broke a rear end last year, I'm hoping this will help.
www.maperformance.com
Old 01-19-2014   #6
Did you break it on the launch? What was the 60' or estimated 60'?
Old 01-27-2014   #7
Mark Leasure
I suspect I hurt the rearend launching it, it broke right after shifting into second.
I picked up a couple of vibrant clamshell clamps. I keep bending ic pipe with over torquing t-bolt clamps, causing boost leaks. These should solve that issue.
Old 01-28-2014   #8
Murlo26
Murlo26's Avatar
Drives: 17 Honda Accord
How much are those? I bent my AMS IC pipes a bunch as they were aluminum with my tbolts.
I didn't have as many issues, none really, with SS piping. But maybe these are on option.
Old 01-28-2014   #9
URV8SUX
URV8SUX's Avatar
Originally Posted by bramagedained View Post
I never lost a coupler with the big setup the evo had.
Maybe Mark is useing paper thin piping for weight savings so he couldn't tighten T-bolts as much as you!
They are cheap for a BAller like you.
I paid 210 for three 3inch a few years ago.
I have 3 of those clamps on my car and work great. Only advice I'd give is Just make sure to use a little oil on the rubber O-rings so it's easier to put together and they don't dry out and crack or break. That's what I did and no leaks or pop offs in 3 years!
Old 01-28-2014   #10
bramagedained
bramagedained's Avatar
Drives: EVO IX SSL
That's probably 100% true. I forgot all the piping on my car was stainless.
Old 01-28-2014   #11
Makes me want stainless piping again. Electric impact on IC pipes FTW!
Old 01-28-2014   #12
I've always preferred aluminum to save the weight plus dissipate a little extra heat. Use a 1/4" driver and don't go gorilla-mode.
Old 01-28-2014   #13
That doesn't always work when you're running Leasure boost though haha
Old 01-28-2014   #14
bramagedained
Drives: EVO IX SSL
I'm kind of surprised Mark didn't do this earlier since it seems everything he does is an engineering masterpiece it seems.
Old 01-28-2014   #15
Although I don't run the same boost levels as these guys, I've never popped one either.
Old 01-28-2014   #16
Murlo26
Murlo26's Avatar
I popped my UICP a few times before I had tbolts, running ~38psi.
But once I had the tbolts it stayed together. I think what Mark is saying is that the tbolts worked fine they are just easy to dent the piping with...which is what I did too. It's easy to over tighten.
Old 01-28-2014   #17
cmspaz
Walls need hugs too
cmspaz's Avatar
I've had the stock woven piping blow off before, but never a silicone coupler.
Originally Posted by Trogdor
Old 01-28-2014   #18
Probably time for a set of these, or Wiggins clamps to handle Leasure boost without torquing the t-bolts to 100 ft/lbs.
Old 01-28-2014   #19
Or just use SS pipes?
Old 01-28-2014   #20
I was going to post the same thing Steve. If I ever get to the point where I keep blowing pipes apart at the coupler, I'm just going to make a homemade boost brace setup.
Either way, looking good man.
