Old 01-31-2004   #41
Yeah, it must be burned into your memory by now! Maybe this will be a little incentive for you and you will get that thing done this winter/spring. Show him some progress pictures and make him jealous, Vicious.
Old 01-31-2004   #42
Come on Shane, put those other 3 pistons in that block and let's go. :3gears:
Old 01-31-2004   #43
At-Least-It's-An-Evo
At-Least-It's-White-Again
At-Least-It's-An-Evo's Avatar
Drives: 98 iVTEC
Originally posted by ecoli@Jan 31 2004, 09:34 PM
God, that second pic looks all too familar to me.
HAHAHAHA Get yours running shane. :cheers:
'04 Honda Ricer: stock
Old 02-11-2004   #44
HKS 272/272 cams have been degreed in and I should be putting this bad boy between the frame rails Saturday. For anybody wondering about how far off the 2.0L cam gears are compared to the 2.4L gears, it is about 4.5-5 deg. I dialed the cams in and then made a new alignment mark on each gear with an engraver at the adjustable timing marks. I also took a straight edge across both gears and engraved new alignment marks where the gears come close together for future timing belt replacements.
Old 02-11-2004   #45
ACRucrazy
Badass!
Slow stuff
Old 02-12-2004   #46
Raptor
ConArtist
Raptor's Avatar
Looks great Mike! Are you going create some form of timing cover for it or run it open? Just curious.
Quick Precision Racing, Inc.
"Always Raising the Bar!"
651-488-7774
Old 02-12-2004   #47
v8klla
v8klla's Avatar
Looks sweet, what turbo will you be running on that thing?
Chris
Chris Carey, President
Modern Automotive Performance
P: 763-545-3800
E: chris@maperformance.com
Old 02-12-2004   #48
I actually plan on running the timing belt & gears fully covered. With my luck something would eventually fall down in there if I left it open. Might remove the top section for car shows, maybe. I like the black 2g covers better than the new grey 1g covers I bought, but I was told the 2g covers wouldn't fit the 1g design.
Old 02-12-2004   #49
Chris
I'm going to be using my VPE GT3056W (TO4E/.56trim/GT30/7cm) turbo. Should get full boost with it by 2600rpm on this engine. If I decide I need a bigger turbo I will probably get the FP3065.
Old 02-12-2004   #50
Raptor
ConArtist
Raptor's Avatar
Hmmm, I was pretty sure that you couldn't use either since the block moves the head up 6MM, If they were used they would probably at least need to be extended a bit I think. That was why I was asking, and because I didn't see any on there at the moment. I knew you were smart enough to run something rather than going without.
651-488-7774
Old 02-12-2004   #51
Time for a custom QPR timing cover :woowoo:
Old 02-12-2004   #52
I think it will be ok. The seperation point of the top and bottom half meet at the deck level. I'll let you know tonight after I try to put them on.
Old 02-12-2004   #53
Originally posted by Jakey+Feb 12 2004, 11:28 AM--></div><table border='0' align='center' width='95%' cellpadding='3' cellspacing='1'><tr><td>QUOTE (Jakey @ Feb 12 2004, 11:28 AM)</td></tr><tr><td id='QUOTE'> <!--QuoteBegin-Raptor@Feb 12 2004, 10:33 AM
Time for a custom QPR timing cover :woowoo: [/b][/quote]
Yeah, maybe an upper cover with a clear window in it to show off them inner workings and gears? :idea:
Old 02-12-2004   #54
The 1g cover works great, all I did was to enlarge the holes on the upper plates that attach to each side of the head so they would drop down a little bit and I was able to get all the bolts in.
Here's where the difference really shows with just a little gap.
Now that's the good news, the bad news is that shortly after taking the pics, I tried to improve the way it lined up on the p/s pump side of the head and cracked the lower cover. :uh: So tomorrow I'm going to try the 2g covers, should work just as well since everything seems to line up great. I'll let you know how it works out.
Old 02-12-2004   #55
Mike I may have missed this, but what are you going to be running for a transmission, Shepherd Racing?
Old 02-12-2004   #56
Trade ya shops?
Old 02-12-2004   #57
Satan's finest
Stock for now.
Old 02-12-2004   #58
I would run some crappy tires if I were you Vicious. That center diff is really going to be put to the test with all that torque you will be making! Especially if spool up is anywhere close to what you think it will be. If you don't launch it too hard you might get by with the stocker, but I would definately have that on the to-do list.
Old 02-13-2004   #59
Oh trust me, it's on the ta do list.
Old 02-13-2004   #60
Nice work. It looks like leaving the top cover off will fool 99% of the fools out there. Guess I need to start shopping for a block and build me one of them bad boys.
