Old 06-22-2007   #41
carltalon
carltalon's Avatar
Drives: 98 Eclipse GSX Auto
Re: Drilling thermostat
Originally Posted by ExTREME View Post
^^ Ahh Very nice idea! I think I will try that with the scraps I got laying around. Any clearance issues carltalon?
I dont actually run one on my car. All my cooling problems are gone after switching to E-85 and installing Brandons old radiator.
Might be a long shot but are your fans blowing in the right direction? If they were blowing the wrong way they would still work fine at idle and slow cruse. But at high speed the fans and the incoming air flow would cancel each other out.
11.35 @ 120mph
Old 06-22-2007   #42
Ya I have checked this as well, the are pulling. I do have a small exhaust leak between the turbo and manifold. Bolts are tightened and gasket is installed, but something must not be flat. Could that exhaust escaping there be so hot to actually have an affect on anything? I'm really digging for anything here as I'm still pretty confused. I may just swap the headgasket even though no tests have shown it to be bad. But I'm just really digging and starting to run out of ideas.
Old 06-25-2007   #43
Swifty1638
Unsure resident asshole
Swifty1638's Avatar
http://www.dsmtuners.com/classifieds...ct=61726&cat=7
get that hood?
-A. Swift
Black 1GB Mafia #1
744AWHP/526TQ-Shootout mode
639.6AWHP/452TQ-DB's dyno
I wanna go fast.
Old 06-25-2007   #44
I have the invader style hood on my car and it has a vent right over the exhaust manifold. I really didn't notice a difference with it. Are you still running E85? If so, there has to be something seriously wrong, I can't imagine what it would do on gas. The AC condensor does inhibit the air flow quite a bit, I got rid of my cooling problems with I ditched the AC.
Old 06-25-2007   #45
I really don't want to ditch my A/C. I am going to be putting on a new headgasket. Going back to an OEM composite one. At the same time, I will be putting in a new water pump, and also replacing that o ring seal on the water pipe. This problem did start showing up right after that whole incident in the Menards parking lot. I'm wondering if it isn't as sealed as it should be, and we didn't see it on the pressure test because it's so tucked away.
I love how the invader hoods look on the 92's, but not so much on the 91's, so I will just be getting one of those vents from Carbon Trix.
Old 06-25-2007   #46
I've also been reading on some other boards, and it seems I am far from alone when it comes to phantom running hot issues.. Tons of people are having cooling issues. I will just keep working at it until it's fixed. About all I can do.
Old 06-25-2007   #47
xveganxcowboyx
Wanker
xveganxcowboyx's Avatar
Drives: 95 M3
Do you have any ducting at all? I seem to remember your fmic piping running just around the radiator. If so you probably have room to put a couple small scoops on either side of the fmic. I added some on mine just between the fmic and the fogs and it helped cruising temps quite a bit.
Old 06-26-2007   #48
Ducting would be a bit difficult, as my FMIC is now the Victory one with the backdoor style endtanks. Really not much room for anything there anymore. But I may try adding a little baffle below, like what Carl had put a picture up of. I'm almost willing to try anything at this point! I even seen one guy on another forum with a 2nd small radiator in the fender well. I'm definately not the only one dealing with this crap.
Old 06-26-2007   #49
x-pride
x-pride's Avatar
I think your problem is your AC condesor with your big radiator. It is stopping alot of air flow. Before you go through tearing your car apart. What about sticking a stock radiator back in. I was going to buy a big radiator but after reading a bit on the effects I went with a stock one again. I no longer have the AC condensor and only running one fan and I don't have an over heating problem. I am also running the same head gasket.
Old 07-23-2007   #50
dragonforce
Make sure you don't have combustion leak into coolant passage. you might have a small leak.
Old 07-23-2007   #51
I actually just bought one of those testers that is supposed to check for combustion gases in your coolant system. It doesn't work worth a damn though because it keeps sucking in coolant. I did put the vent in the hood, and that didn't do much
Old 08-23-2007   #52
OK, replaced the old Cometic head gasket with a OEM composite one, headstuds torqued to 100lbs using ARP Moly Lube. Also installed new water pump (the better design) and new O-ring.
She is still running hot. Time to make some baffles to help more air get through the radiator.
One other thing I was thinking about since I really want to retain my A/C. I was going to try and find a smaller profile condensor since I don't use my A/C that much, and it would block less air going into the radiator.
Old 08-23-2007   #53
Swifty1638
Swifty1638's Avatar
You sure the gauge just isn't off? Have you tried running an aftermarket one? That was the issue with mine.
-A. Swift
Black 1GB Mafia #1
I wanna go fast.
Old 08-23-2007   #54
Can you read the temp of the ECU for comparison?
Old 08-23-2007   #55
Have you tried wiring your fans to a relay yet? I had this same issue with my 2G, and the fans were simply turning off, no idea why!
Old 08-23-2007   #56
I can log my Coolant temp through DSMLink, and this is not just the gauge. The temp gets above 200, and has reached 220 in the past (which is when I have DSMLink turn on my check engine light).
One thing I suppose I haven't done, is to actually replace the temp sensor. Because if it's off, well then everything is going to read wrong. Anyone ever heard of those going out of calibration?
Scheides, I have both fans, hard wired to be running whenever the key is in the ON position.
Old 08-23-2007   #57
I would get stronger fans. Does it overheat on teh freeway at high speeds or just when putzing around town?
My gsx was always fine on the freeway 200 degrees or so, then climbed to 215 on side streets and such. My fans werent strong enough...
Old 08-23-2007   #58
A bad sensor could do it. What radiator do you have and how old?
Old 08-23-2007   #59
It also could be that radiator you bought, isnt it just a knock off aluminum?
Old 08-23-2007   #60
the evo had a bad temp sensor in it the first time I had it running for 5 min it said it was over 300 new sensor in it now it works fine.
