Old 11-27-2008   #41
Re: just got a new winter car 95 mirage coupe
Nice! That thing should rip pretty good if it can ever get traction.
Old 11-27-2008   #42
it will be worse than the talon. One of the mirage guys just weight his with a 4g63 in it and it was 2055lbs
Old 04-23-2009   #43
wow it has been a long time for me to work on the 2door. But I did get alot done with it today.
a few months ago dad and I went through the engine and head. It got new bearings rods and mains. 1 new valve out of a diffrent head I had. all new valve seals. all new gaskets and timing belt.
Old 04-23-2009   #44
as for today. I took the 90 awd parts tranny the rest away apart and just used the tranny case to make it easy and light. I got them motor in the car with the tranny case for mock up for the front and rear roll stop mounts for the 1g tranny. 2g tranny is a bolt in the car.
I had to cut up the roll stop brace and mod the hell out of it to clear the awd tranny. Also put the evo III knuckles with 1g dsm hubs on the car. It will be rolling on my 98 spyder rims.
Old 04-23-2009   #45
spyder rims and front 5lug swap
the roll stop brace
Old 04-23-2009   #46
the mounts upper is all 2g block and mount. the upper tranny is evo 1-3 bolted to the tranny. the tranny mount on the frame rail is the 1.8 auto mount flipped 180.
The front roll stop is moved over alittle bit to mate up the the 1g tranny. the front and rear mounts are awd. the front ard rear roll stops are mirage 1.8 auto.
also had to redrill the front awd mount to line up with the roll stop mount. upper holes are the new ones
Old 04-23-2009   #47
motor all bolted in on the 3 mounts. I still have to make the rear roll stop mount.
Old 04-23-2009   #48
Nice. It's awesome how much custom stuff you do to make everything fit.
Old 04-24-2009   #49
dark_vr4
dark_vr4's Avatar
damn nice project mark, i cant wait to see the end process.
dark_vr4 is offline   Reply With Quote
Old 04-24-2009   #50
I can't wait to see the other mirage get painted.
Old 05-13-2009   #51
worked on the car some more today and a little last thurs.
last week got the rear motor mount built and a rebuilt the full front to back brace so it sits under the tranny so it was not were the t.c. would sit if it was goint to be awd.
as for today
pulled out the engine and the empty tranny case. then put the rear main seal on, awd oem fly wheel, act 2100 P.P. with a oem mitsu disk. the locked awd to fwd tranny. got the engine back in with the real tranny and got the wiring on the engine taken care of. Now I just have to wire the mirage to dsm dash harness.
the rear awd mount cut down and redrilled so it would clear the rack
all back in
Old 05-13-2009   #52
4g63tcrazy
is Nashty
4g63tcrazy's Avatar
Drives: Cyborg from Japan
Lookin good!
-1990 Mitsubishi Cyborg 4WD-
Old 05-13-2009   #53
sweeeeet, now get a 2G MAS, E3 16g, and evo 560's (sorry I just sold mine) and don't swap it out for anything less than super super reliable
Old 05-14-2009   #54
Haha that would be a sweet setup Scheides, but this thing is gonna be nuts as it is with the 14b.
Old 11-05-2009   #55
here is how it sits right now. it is almost ready to leave my place for good
reused alot of my evo III parts on this to save cash on finishing it up. Put the evo III fmic on and rebuilt the oem evo fmic piping,evo a/c fan will be used for the main fan now.
also used a 1g bov and 1g battery tray I had laying around
timming side all together
evo 8 booster,brake master,clutch master
1g dsm front seats
dash shot with the piller going in and tach going on the piller also
front and rear 5lug. 2pistion front brakes,rear disk swap
and the huge 5in glass pack tip I had laying around
Old 11-05-2009   #56
Damn this thing should rip pretty good!
Now dyno bitch better take care of it!!
Old 11-06-2009   #57
Constant_Project21
Constant_Project21's Avatar
Drives: E36
Sweet!!!
Old 11-06-2009   #58
Badass I hope to be doing stuff like this one day.
