Old 01-04-2009   #41
Re: My poopy conquest and it's cracked block
Well, I'm taking it in tomorrow to get hot tanked and magnafluxed, so today would be the day for checking it ourselves. Otherwise I might have the shop check it since it's there anyway. We'll see and I'll let you know.
Old 01-04-2009   #42
Got the anchor out today.
This is a good pic of the crack going toward the back of the engine.
I really don't want to get new ARP studs, but I might have to since I used 'em to hoist the engine out, lol.
Old 01-04-2009   #43
Shotgun!
Totenritt
Shotgun!'s Avatar
Please take pictures of your pistons ring lands.
Old 01-04-2009   #44
MustGoFaster
MustGoFaster's Avatar
Drives: A big dirty V8
G54B cam gear holder > all. That little tab is the best part of the motor.
Old 01-05-2009   #45
I will.
Yeah, they knew we'd be taking them apart sooner or later. That's why they put such wide tool trays on the inner fenders.
Old 01-08-2009   #46
Nice guess! This is a major bummer:
Only one piston was cracked, but they all have varying degrees of wear on the thrust sides. Enough that I am concerned. But I have already made up my mind to get new pistons. Sad. Plus one of my rods is all discolored on the small end like it was torched. I had one rod "repaired" or refreshed or something when I had it all machined, so I don't know if it's from that or not.
Also, the #1 rod bearing chamfered itself on the rearward edge by rubbing on the crank. My guess there is that when they machined the crank, they kindof forgot to go all the way to the end of the journal. I now have to get the crank checked out. I had seen some metal flecks in the oil a time or two before and didn't worry, but now I know what was doing it. Lame.
This is going to cost way more and take way longer than I thought.
Old 01-08-2009   #47
Which piston was that? A little less timing on pump gas next time, that sucks.
Old 01-08-2009   #48
Number 4. And yeah, I will definately take out timing, and this build is going to be done much more competently than the last one.
Old 01-08-2009   #49
MustGoFaster
4G6X time.
Old 01-08-2009   #50
I could probably make money on a 4g63 swap.
Old 01-09-2009   #51
Yep, time to switch motors.
Old 01-09-2009   #52
too soon though. I have to make a lot of power on this setup for this year. Next winter maybe I'll switch to another engine if any problems arise.
A good tune is all it will take.
Old 01-09-2009   #53
Shotgun!
Totenritt
Shotgun!'s Avatar
sounds good man, i wish you all the best!
P.S. Go forged!
Old 01-09-2009   #54
I need 500 bucks for a set 'o forged pistons. Pretty steep. I might go the broke route with Hypers again, and run like 12 degrees instead of 17. *oops*
Old 01-09-2009   #55
mx3twinturbo
mx3twinturbo's Avatar
Drives: StarQuests>>>>>>
Hey man,
I have a built 2.6L here at the shop we need to sell it,
has about 5000 on it, asking 600 firm,
let me know,
Jesse-
1987 Conquest- 2.1 project started...
1986 Dodge D-50- S.C. truck 2.6 turbo swap started
1992 Mazda Mx-3- Rear mount twins in progress
1989 Suburban- Project for too Long!!!
"Just Remember, I HATE Drama"
mx3twinturbo is offline   Reply With Quote
Old 01-09-2009   #56
mx3twinturbo
It has forged pistons, shot peened rods, new bearings etc. also has a crank trigger set up off of a 83 crankpully,
Old 01-09-2009   #57
Wow, most convenient deal ever? Fatty you got lucky.
Old 01-09-2009   #58
Agreed!
Old 01-09-2009   #59
Thats a great deal. Also consider less timing then that until it sees a dyno just to be safe. Did you sync the ignition timing?
Old 01-09-2009   #60
Fuck yeah, and 17* timing? you been away too long.
Good luck and be uber safe this time.
