Old 03-05-2010   #41
Re: What are DSM people running for tranny fluid these days?
Originally Posted by CarPsyco84 View Post
If you wanna wreck diffs, use GM Syncromesh, otherwise if you want actual gear oil redline from map seems to be the cheapest option.
I have used Syncromesh for years and everything has been fine. I will be trying a different fluid this year.
2 blown up diffs??...
1998 Spyder AWD
567hp
490tq
Old 03-11-2010   #42
CarPsyco84
CarPsyco84's Avatar
2? try 3 just with me. When I was young and foolish I ran that junk in my AWD, and after 2 transmissions with numerous issues including wearing 2 center diffs out, and wearing a front diff so bad the wrist pin had lost more than half its diameter in wear before it snapped off and destroyed the trans case, and mutilating a ACT 2600 pressure plate.
The problem is its syncromesh is not gl-4 rated and doesn't have high enough pressure resistance to deal with even normal wear in our trannys let alone abuse.
-When in doubt, Moar RPM.
Old 03-11-2010   #43
Pretty sure Syncromesh is rated for GL4.
Old 03-22-2010   #44
s1ngletracker
s1ngletracker's Avatar
Drives: A BMW
My shifting is getting notchy again. I think this time i'm gonna run just MT90, no MTL. What do people think about that?
Style's automotive engineer
