Old 07-03-2009   #41
Swifty1638
Unsure resident asshole
Swifty1638's Avatar
Re: What weight oil do you use?
Ok, I am a bit lost on this. As you all know, I got the talon running/tuned this year, and 4 days later the turbo blew (keep the PTE comments in a different thread, and this one clean). I rebuilt it, and now it's all back on the car, all good again..so far. My concern is that I was running too much oil pressure for it, and that caused it to blow. PTE is of NO help in trying to sort this all out, so I'm guessing now as to what caused it. Besides running more boost (36 vs 26-28 it was before) the ONLY real difference is the oil. I WAS running 10w30, but now I'm running 15w40. I am curious as the oil psi has gone up, idle it was 25, now it's 50. cruising/pulls it was around 75ish, now it's over 85-90 psi! Could this "flood" the turbo? Keep in mind, it's a thrust bearing, p-trim. Feed is straight off the oil filter housing, NO balance shafts. it's a -4 an straight into the turbo. I have a oil filter for it on the way, but I dunno if I should also be running a restrictior, or go to a thinner weight oil..opinions?
Black 1GB Mafia #1
744AWHP/526TQ-Shootout mode
639.6AWHP/452TQ-DB's dyno
I wanna go fast.
Old 07-03-2009   #42
twack
It was a auto get over it
twack's Avatar
In some of my other DSM's I ran Rotella and Supertech (Walmart's brand).
No lie Ive ran walmart supertech 20w 40 plenty of times. Ive done it alot but that supertech filter is pretty small, but with my saturn alternator a small filter is awesome
what do you guys think about that mobil 1 clean 5000 in a daily driver (jeep), and actually doing it at every 5000
Old 07-03-2009   #43
Supertech oil and filters are both decent considering the cost. I'd run a supertech filter over a standard Fram anyday.
ANyhow, Swifty maybe consider putting an oil pressure gauge inline with your feedline so you can see the pressure that the turbo is seeing rather than the overall oil pressure. Just a thought.
I personally have never done anything special in regards to the pressure my turbo see's. I got my turbo from Bullseye, and I bought the feedline fitting (built in restrictor) that they recommended. That's about it. I've ran anything from 10W30 to 20W40 in my car, and I've never had an issue. I also never run an inline filter on my feedline. I remember the Sport Compact article from many years back where the guy from dsmporn.com was part of the Ultimate Challenge or whatever, and went through 2 turbos during the challenge, and turns out it was a clogged filter on his feedline causing the turbo to see not enough oil.
OK, I'm done rambling.
Old 07-03-2009   #44
Swifty1638
Swifty1638's Avatar
yea, I hear you gotta clean that filter every oil change..But, I dunno what to do here..arg.
Black 1GB Mafia #1
I wanna go fast.
Old 07-03-2009   #45
Get something other than PTE??? You can maybe just try a real Garrett, FP, Turbonetics, or also other non-Garrett based turbos maybe.
Old 07-03-2009   #46
x2, Frams are junk. The local O'Rielly's in St. Cloud did their own little oil filter analysis and found that out of what they stocked, FRAM was by far the worst. The WIX actually had the most filtering surface of all of them. I am not sure what else they tested, but I know it was about 7-8 different brands or so.
Old 07-03-2009   #47
Swifty1638
Swifty1638's Avatar
I'm PRETTY sure over winter I'll be doing a 4202 setup. Spools the same as this, but more power..that is..if I can sort this revving thing.
Black 1GB Mafia #1
I wanna go fast.
Old 07-03-2009   #48
SnoEclipse
Drives: 07 Eclipse GT
WIX makes the NAPA Gold line of filters. And NAPA gives a decent case discount too.
Old 07-03-2009   #49
4g63tcrazy
is Nashty
4g63tcrazy's Avatar
Drives: Cyborg from Japan
Anytime I get an oil filter I just make sure it has the anti-drain back valve and its not a fram. Then I'm good to go.
-1990 Mitsubishi Cyborg 4WD-
Old 07-03-2009   #50
-4 is too big of an oil feed line. Also, if you are feeding off the oil filter housing on a car without balance shafts, then you should run a restrictor or the FP Filter/Restrictor. It almost sounds like you are trying to blow your turbo seals with everything you are doing.
Old 07-07-2009   #51
I've got a FP red restrictor for journal bearings, and a -4 feed line, from the OFH. No balance shafts, unported relief valve hole. Seems to be working good for me.
Old 07-07-2009   #52
Swifty1638
Swifty1638's Avatar
I ordered that red FP oil restrictor yesterday. Should be here thurs.
Black 1GB Mafia #1
I wanna go fast.
Old 07-08-2009   #53
GnArKiLl
GnArKiLl's Avatar
so if your running no balance shafts or oil squirters and have the oil feed off the ofh. you should have a restrictor in the line?
Old 07-08-2009   #54
s1ngletracker
s1ngletracker's Avatar
Drives: A BMW
this has gone way off topic.
Style's automotive engineer
Old 07-10-2009   #55
awd-drifter
'2of9'
awd-drifter's Avatar
Drives: Racer Van V6
I've been using AMS oil full synthetic 10w-30 since i owned the galant. Car has been driving smoother since.
ლ(ಠ益ಠლ)
Old 07-10-2009   #56
4g63tcrazy
is Nashty
4g63tcrazy's Avatar
Yea I guess I'll try rotella 15w40 next or maybe like a 10w40. I don't think I'll need that thick of oil.
Old 07-12-2009   #57
s1ngletracker
Drives: A BMW
i think i'm gonna try 20w-50 to boost my oil pressure more. Is this a terrible idea?
Old 07-12-2009   #58
4g63tcrazy
is Nashty
4g63tcrazy's Avatar
What is your oil pressure at?
Old 07-12-2009   #59
20W-50 is a thick oil. What is your oil pressure currently at and how high do you want it?
Old 07-12-2009   #60
95talonracer
Finally Tuned...
95talonracer's Avatar
Drives: Spyder GSX
Great Choice!
Amsoil Dealer
