Old 09-03-2009   #41
Re: Yep..another one.
You can put a bolt in that bs hole, just be liberal with the thread locker or thread sealer.
Old 09-03-2009   #42
tehehodi
Braaaaaaaap!
tehehodi's Avatar
Drives: '09 Silveraydo
Originally Posted by jhaan_dude View Post
damn tehehodi i must have just missed you! by like 10 minutes!
i pulled up as you were pulling out.
Old 09-03-2009   #43
jhaan_dude
jhaan_dude's Avatar
Art of War Champion! Yeti 1 Greece Champion! Mario Tetris 3 Champion!
Drives: a car
oh damn! wish i could have said hi, but oh well...
Old 09-03-2009   #44
Constant_Project21
Constant_Project21's Avatar
Drives: E36
Thats what I ended up doing, problem solved.
Old 09-03-2009   #45
Constant_Project21
Drives: E36
Seems to be one thing after another, nothing big but still. Timing belt is still rubbing, in a different spot. So will tear it down again, and figure it out. Hoping brakes will be here tomorrow, picked up rear rotors today.
Old 09-03-2009   #46
Missing a bolt.... Was there a BS belt on there or was it elimintated by someone? Odd that the car went from running to these timing issues... Had a ton of DSMs apart and never had the timing belt rubbing issue...
Old 09-04-2009   #47
Constant_Project21
Drives: E36
I have a feeling the cover is rubbing somewhere, and there was no balance shaft belt or pulley.
Old 09-05-2009   #48
Constant_Project21
Drives: E36
Fixed the rubbing issue, installed brakes, and got her moving today!!!! Big thanks to julian for helping out us SAFC challenged folks with the tuning, and getting her running great. Pulled awesome, so awesome that we blew a whole in one of the couplers...hahaha. Very nice to have a running dsm again.
Old 09-05-2009   #49
jhaan_dude
jhaan_dude's Avatar
Drives: a car
no problem, just a few more things to go and she might beat 14's!
Old 09-05-2009   #50
I would hope so...
Old 09-06-2009   #51
Constant_Project21
Drives: E36
Haha, Im positive it's faster than a 14
Old 09-06-2009   #52
viridionplague
did you still need brakes, and the shifter cables and stuff, i cant seem to find the datalogging software unfortunatly
Old 09-06-2009   #53
Constant_Project21
Drives: E36
I have a full brake set on the way, found a set of rear rotors.
Old 09-06-2009   #54
Constant_Project21
Drives: E36
Ran into a little issue, after the initial test and tune (which was very sucessful) the car was running great and idling well. Shut it off, and go to start it again a little later, and the safc wouldnt turn on. Fixed that issue, but then it keeps blowing a fuse. I will get which fuse it is, and more details, just kind of frustrating.
Old 09-06-2009   #55
Constant_Project21
Drives: E36
It's the mpi 20a fuse that keeps blowing, which isn't allowing my ignition to turn on.
Old 09-06-2009   #56
Maybe check the connections on the SAFC for the fuel wires? They are the only 2 wires which are cut and not tapped.
If I remember correctly the MPI fuse is for the fuel system. I think you pull that during a compression test so it doesn't spray fuel. I could be wrong, it has been a long time.
Old 09-06-2009   #57
Constant_Project21
Drives: E36
If we link the two, it gets hot and blows the fuse. Without the mpi fuse installed the ignition will not engage.
Old 09-06-2009   #58
Sounds like you have a short somewhere. I'd check the wiring to the SAFC again to make sure something isn't touching the chassis or that something isn't wired correctly.
Old 09-07-2009   #59
Constant_Project21
Drives: E36
We found the short!! Thanks again to julian for retuning the car, we actually got 2 dsms running and tuned hahaha.
Old 09-07-2009   #60
tehehodi
Braaaaaaaap!
tehehodi's Avatar
congrats! glad you got a dsm running right! lol
