Old 01-24-2010   #41
Re: Im a dsmer again!
yeah sorry i was thinking assembly lube, but also need the moly lube. But first and foremost, after looking at the rods and starting to grind the gouge, i rotated the crank and something looked funny.... the connecting rod is tweaked. so looks like i have to try and source one connecting rod. If anyone knows who would sell me just one rod that would be great. they are manley I beam rods.
Old 01-24-2010   #42
So you have to take the head off and everything now? At least you'll be able to inspect everything closer, make sure nothing else is damaged.
Old 01-24-2010   #43
At this point,space permitting, I would recommend a yank and full teardown then. A clean motor after a catastrophe is a happy motor.
Old 01-24-2010   #44
yeah its kind of a blessing in disguise. I want to make sure im fully aware of any issues that may come up, make sure everything is clean and within spec. The bottoms of the pistons look good, the crank looks good. I dont want to have to pull the entire motor if i dont have to. Im going to check torque on everything.
Swanny, Do you know off hand if shops such as MAP can order individual connecting rods from manley?
Old 01-24-2010   #45
Project2G
Semper Fidelis
Project2G's Avatar
Drives: 1997 Eclipse GST
Might as well perform routine maintenance ie head gasket...
Old 01-24-2010   #46
Im' pretty sure MAP can order individual rods. They got me an individual piston when I needed one. And I ended up getting a rod somewhere else, but I'm pretty sure MAP said they could get me one.
Old 01-24-2010   #47
The motor has 300 miles on it. not much routine maint. to do.
Old 01-24-2010   #48
That sucks dude. I'm sure you can get just one rod but...ouch, sounds like a lot more than you were hoping for.
Old 01-24-2010   #49
That sucks.
Old 01-24-2010   #50
1g's ftw. yay.
Didn't Brandon buy 1 new rod?
Old 01-24-2010   #51
I got my rod off the Link forums, but MAP got me 1 piston, and pretty sure they said they could have gotten me 1 rod but ended up finding a good deal on the Link forums.
Old 01-25-2010   #52
slowbubblecar
Big Turbo Monster
slowbubblecar's Avatar
Drives: GTS and E55
Looks like another example of why he should not be building motors....
7/25/09
Old 01-25-2010   #53
I'm in favor of Swanny's advice. Pull the motor, tear it all apart, inspect everything. That way you don't run into more problems later. Do it once the right way, rather than half ass it the first time, then end up doing it all over again.
Old 01-25-2010   #54
Constant_Project21
Constant_Project21's Avatar
Drives: E36
X2. That's pretty much what I'm doing with my entire car this year. Save yourself some time in the future, and do everything right the first time.
Old 01-30-2010   #55
