Old 08-07-2011   #1
99gsxjoel
Drives: 1999 GSX
Re: my slow project...
How much?
99gsxjoel is offline   Reply With Quote
Old 09-01-2011   #2
99gsxjoel
Drives: 1999 GSX
so now i am confused. went to the track today and did about 6 passes and could not brake 14.1
what is weird i got a tune picked up 30hp and got launch control and when I was at proving grounds I was not tuned and just pedaled it out of the hole and ran a 14.0
Old 09-01-2011   #3
What were the mphs? ET is depends a lot on track prep, driver, tires, etc. You might see car with the same power to weight that run 110mph in the 1/4, but the ETs are anywhere from 12.0 to 14.0.
Old 09-01-2011   #4
99gsxjoel
Drives: 1999 GSX
before tune
1.9 60'
1/8 8.9 @ 76.8 MPH
1/2 14.08 @ 94.5 MPH
my best after.
1.8 60'
1/8 8.99 @76.20
1/4 14.17 @94.24
I guess i figured 30hp and launch control would crack the 13s
Old 09-01-2011   #5
93gtpeater
Drives: cbr 1000rr repsol
you would think 30hp would of helped. Mabe you have a boost leak or something happened to where you lost that extra power. Your mph should of went up with the extra power.
Old 09-01-2011   #6
99gsxjoel
Drives: 1999 GSX
Thats what i was thinking also... I have had some check engine codes for the last week or so and have never check it out. oh well i will have to make it to rockfalls again.
Old 09-01-2011   #7
Something isn't right there.
Old 09-01-2011   #8
Your mph should have went up like 3-4 mph.
Old 09-01-2011   #9
hippiekiller
hippiekiller's Avatar
What about track temps? Could make the difference I would think. Maybe not that big of a difference, but if it were stupid hot one day and mild another...enough to drop it some anyway.
Old 09-04-2011   #10
99gsxjoel
Drives: 1999 GSX
That might be the case. sun proving grounds in the morning if i remember was cooler and wed. was humid. I am going to get the codes cleared and put in new sensors where it is needed.
then going to rock falls on the 17th to try it again.
Old 09-05-2011   #11
99gsxjoel
Drives: 1999 GSX
well i got my codes on my car.
p0125
p0126
I am guessing it is my coolant sensor.
And
p0136
I think it would be my O2 sensor. going to replace both and see if they come back.
