Old 04-07-2013   #41
Re: Goodhart's budget beater 1g
Looks good! If youre cheap and dont want to buy a plug you could put the tape on the inside and use touch up paint to paint it white. Did that on my 2g and didnt look the best but didnt look horrible
Old 04-07-2013   #42
LingLing
AznKraut
LingLing's Avatar
I went with the Home Depot household black plug. Some RTV from the underside and you're all set to go.
Old 04-07-2013   #43
bramagedained
bramagedained's Avatar
Drives: EVO IX SSL
FYI your car needs to look as clean under the hood as Leisure's does when you're done with it...
Old 04-07-2013   #44
Speedfreak
Drives: four tires
Hmmm, I can't remember if I can get that condenser to fit with my FMIC. If someone knows that it will fit, I'm interested in the AC stuff.
I have a 4" FP core and all the AC stuff still in place.
NSX - S480/Built motor
GSX - 571whp/490wtq
Sienna
Old 04-07-2013   #45
bah, DSMs don't need AC.
Old 04-08-2013   #46
Steve, you can have the A/C stuff if you want. I wasn't really expecting to get anything for it, and it fan be used by someone that's cool.
Old 04-08-2013   #47
After looking around for different options, this may be the route I go. Looks like the 2g ones are 25mm.
Old 04-08-2013   #48
I forgot what I did.
I took a body plug and it fit perfect. that with some weatherstripping adhesive and its perfect.
Old 04-14-2013   #49
Shitty weather this weekend, so I just putzed around with my motor mount inserts I got for xmas. Well 3 or them anyways, I didn't want to take the wheel off outside to get the passenger side one off the car. I will do that once weather is nicer outside.
The sawzall made pretty quick work of getting the rubber junk out as well as the metal rings that need to be cut out.
Rear motor mount, rubber cut out:
Got the ring out, ready for paint and insert:
Big giant Drivers' side mount, ring and rubber out, ready to be cut down and finished:
Finished product of all three.
Front:
(This one was a bit of a whore because it isn't two pieces, and it has to be pressed in. I eventually got it with lots of lube (TWSS) and the bench vice.)
Rear:
Drivers' Side:
Old 04-15-2013   #50
evotuner
evotuner's Avatar
Drives: 2004 Evo 8
NIIIIICCCCCEEEEE
2006 WW IX RS 396/404 - SOLD
Old 04-15-2013   #51
Motor mounts look awesome!
Old 04-17-2013   #52
I had some days off this week and finally went and picked up my brothers' engine hoist. When I got it back I got it on the stand and started tearing shit apart.
Prepare for carnage!!
Getting the engine from hoist to stand. Didn't really plan this pic at all, and didn't notice till I got some funny faceboook comments. haha 4g63 Allis!
Got the intake manifold off and found this...Where is the rest of the valve? You can just faintly see the cracked valve guide as well. Phone didn't want to focus very well down the runner like that.
Got the junk ass crank pulley and water pump pulley off along with the timing cover. The water pump bolts were just a tiny bit more than finger tight. I'm not sure that has anything to do with the failure though. The timing belt was loose as hell too.
Ahh! There's the problem! Think it'll buff out?
This is Cyl #1:
Cyl #2:
Cyl #3:
Cyl #4:
So the head is junk, I figured it would be, so that is not a surprise at all which is why I picked up the 2g head last summer.
On the the pistons.
#1:
Nice pile of aluminum shavings there, my guess is that happened when I was turning it over and over while trying to get it running before I discovered the beat up spark plug. What's weird is that the engine didn't make any noises until I cranked it probably 15 times and I stopped and checked the plugs.
#2:
#3:
#4:
Pic of all 4, in order from left to right, 4-3-2-1:
Old 04-17-2013   #53
4seasons69
4seasons69's Avatar
That looks awfully familiar! Lol. When mine went it didn't make any noise either. Mine would even fire up and run like crap lol.
Old 04-17-2013   #54
So, after the cruise and my trip to TX I'll be in the market for some 2g pistons on 1g rods. Amazingly enough, the cylinder walls looked damn good. No cross hatching obviously as I'm sure this motor has a million miles on it, it's glazed pretty good. But no major scratches! Nothing I could feel with my fingernails anyways. I'm sure I'll be able to check it out better once I get it further apart.
Next time I get up there to work on it I plan on flipping the engine and pulling the oil pan to see how beat up the bearings are. I'm not expecting much, hopefully at least the crank and block are usable though, otherwise it might get expensive quick.
Old 04-18-2013   #55
evotuner
evotuner's Avatar
Drives: 2004 Evo 8
LOL at #1 piston, are you planning to do a 2.0 rebuild or 2.3? Whats the plan for this bish?
Old 04-18-2013   #56
Stock 2.0
Old 04-18-2013   #57
I have 3 good looking rods if you are interested. Just throwing it out there
Old 04-18-2013   #58
evotuner
evotuner's Avatar
Drives: 2004 Evo 8
Stock 2.0
300whp? more?
Old 04-18-2013   #59
600whp
Old 04-18-2013   #60
Lol idk how many hp ill have. Gonna stick stock appearing for now, maybe like an SCM61 for fwd traction lolz some day. No matter what this combo will hold whatever power I ever give it. More power= more problems
