Old 10-14-2013   #41
Re: head fused to the block ?
This thread is making me pound my fucking head on a wall.
Old 10-14-2013   #42
dsmghost
dsmghost's Avatar
Drives: 1gb Talon TSi AWD
Buy a different engine?
Old 10-14-2013   #43
If they're the reverse bolting nuts, you probably have to double stud it and hammer it out in an opposite forward direction.
Old 10-14-2013   #44
gsxvince
the dsm mechanic!
Drives: 1991 talon tsi 1ga
The washers should come out with a needle nose pliers thats how i pull mine out after that the head ahould just pull up even if the studs are in
they would have to be bent or the head has to be hella warped
or stuck on the dowl things
gsxvince is offline   Reply With Quote
Old 10-14-2013   #45
gsxvince
the dsm mechanic!
Take a sawzall and cut between the head and block haha!
Old 10-14-2013   #46
b00sted_spyder
Give some heat by the dowel pin. That will help loosen up the corrosion if any.
Old 10-14-2013   #47
4seasons69
4seasons69's Avatar
I'm pretty sure he had his head off this summer so corrosion shouldn't be an issue. I would get all the head studs out first to make sure those are causing/adding to the problem
Old 10-14-2013   #48
dsmreck
dsmreck's Avatar
Drives: 98 gsx
hook an engine hoist to the head and pull that motha off. how hard can it be.
or ask cornfed for that bfh.
Old 10-14-2013   #49
Alpha D
Got Boost o_O'' m
Alpha D's Avatar
Take a torchto it and head up the all around the block a little cool it down rinse and repeat shock it a little bit, and wiggle wiggle wiggle yeah...worked for my head the wiggle part ha! You got this!
Old 10-15-2013   #50
Probably not much point, if the engine got that hot it is junk anyway. How long did you wait to put coolant in it? If it wasn't 2+ hours then you cracked the block on it if it wasn't already cracked.
Old 10-15-2013   #51
dsmreck
dsmreck's Avatar
Drives: 98 gsx
<iframe width="640" height="360" src="http://www.liveleak.com/ll_embed?f=6d1a734a9fad" frameborder="0" allowfullscreen></iframe>
Old 10-15-2013   #52
dsmreck
dsmreck's Avatar
Drives: 98 gsx
wtf supposed to be a tannerite vid
Old 10-15-2013   #53
M1L3S
M1L3S's Avatar
Drives: 99Gst
I just had this one rebuilt this summer. With 2.4 crank , eagle rods and cp pistons and head work
I hopping to salvage as much as possible.
In all honestly im thinking of using a engine life on it.
If anyone is in the Zimmerman area and wants to give it a whack let me know :/
M1L3S is offline   Reply With Quote
Old 10-15-2013   #54
M1L3S
M1L3S's Avatar
Drives: 99Gst
I used hot water. Kind of counter intuitive. But I figured it wouldnt crack the block......
Old 10-15-2013   #55
dsmreck
dsmreck's Avatar
Drives: 98 gsx
bummer man. yes we are teasing because it's not ours so naturally we don't care like its ours and we could blow it up no worries. but seriously I would try an engine hoist and big rubber mallet as u lift.
Old 10-15-2013   #56
Fixed that for you.
Old 10-15-2013   #57
dsmreck
dsmreck's Avatar
Drives: 98 gsx
lol ^
Old 10-15-2013   #58
So you had 130* water going in a 300*+ block. See my last post.
Old 10-16-2013   #59
M1L3S
M1L3S's Avatar
Drives: 99Gst
Well my first issue is getting the head off. Realistically as long as the internals are fine. Im not too upset. Shit happens I guess.
Just more money down the pit I guess :/
Old 10-16-2013   #60
The car is in Zimmerman? I could come give you a hand on Sunday possibly.
