Old 02-12-2006   #41
Re: Study says ethanol not worth the energy
Originally Posted by Jakey
I have never heard of this before.
This is why E85 can't be run in "normal" cars no matter how you tune them. It will destroy the aluminum and rubber components.
Old 02-12-2006   #42
Most new cars are E85 capable... older cars that dont use the different materials for lines, rubber seals, etc can not use E85 because of what Hughes is talking about. Not so much "normal cars" but old cars are not capable of using e85 safely unless you redo the fuel system, engine gaskets...etc.
Old 02-12-2006   #43
Ethanol is the same as any other alchohol based chemical. It contains water.
For those of us who run s/s valves, bronze guides, etc. it's not that big of a deal, but we still run cast iron cylinders, steel shim headgaskets, cast or moly rings. The long term effects are the problem.
Old 02-13-2006   #44
fusion
Ethanol fuel is a stopgap technology until hydrogen powered cars become mainstream, however long that may take.
fusion is offline   Reply With Quote
Old 02-13-2006   #45
Emcee gsxtc
Emcee gsxtc's Avatar
Talking Re: Study says ethanol not worth the energy
Originally Posted by S2kracka
E85 equates to lower MPG, not higher.
Well since I am the one driving my van getting 30mpg on ethanol and you are ignorantly spouting off on the internet your knowledge, with no facts of your own, I will maintain that I get better mpg with ethanol.
Run your car not your mouth!
Pick Two: FAST CHEAP RELIABLE
Old 02-13-2006   #46
I'll believe you once you explain how it is possible. Ethanol contains less energy per gallon that gasoline.
