Old 05-08-2011   #621
Re: 91 Galant VR4
I want to drive the car to the dyno day, if its tuned I will put it up for some numbers. We will be putting in a full week in the garage to get it ready.
The down pipe is 4", and the turbo is a GT4202.
Old 05-08-2011   #622
OMFGeofffff
OMFGeofffff's Avatar
Drives: '90 Talon Tsi AWD
Re: 91 Galant VR4
What kind of numbers are you shootin for?
OMFGeofffff is offline   Reply With Quote
Old 05-08-2011   #623
Re: 91 Galant VR4
Last year the setup made 650awhp with 38psi and E-85. This year I plan to run E98 and I want to turn the boost up until we find the bottle neck in the setup. I think at 50psi on E98 the car could make 850ish, we will see though.
Old 05-09-2011   #624
Re: 91 Galant VR4
Candidate for 'Name Dat Powa'?!?!?!
Old 05-09-2011   #625
Re: 91 Galant VR4
Fucking Beast Mode right here.
Old 05-09-2011   #626
19TsiAwd90
2stepadepaaadepaaadep
19TsiAwd90's Avatar
Drives: myself crazy
Re: 91 Galant VR4
and if you blow you head gasket you gonna oring the block and push 80psi lol!! but seriously 50psi!! WOOAHHHHH!!!!!
Originally Posted by 311evo
Old 05-10-2011   #627
Re: 91 Galant VR4
Perma torque head gasket, head is within .0015" of flat, and the block was decked in a $150,000 dollar Sunnen V30, torqued down with A1 Technology head studs. It should handle what ever the turbo can throw at it.
Old 05-10-2011   #628
Re: 91 Galant VR4
1 Step closer.
Tranny and most of the under side is done.
Just a few more things under the car to finish.
Inter cooler, hear exchanger, radiator, and a few other items to finish this up.
FIC Blue Max 2150 Injectors installed, I just shortened the fuel rail mounts and removed the plastic spacers, then added studs to bold the rail down.
So after the car makes 850 some AWHP and takes the fastest Galant VR4 record I plan to enjoy this with the friends and family that helped make this car possible.
So just a few more things to finish up, I hope to start the car up tomorrow.
Old 05-12-2011   #629
Re: 91 Galant VR4
The car started last night, now I just need to do an oil change and go do some vacuum pulls to break in the motor.
Old 05-12-2011   #630
Re: 91 Galant VR4
AWESOME!!
Old 05-12-2011   #631
awd-drifter
'2of9'
awd-drifter's Avatar
Drives: Racer Van V6
Re: 91 Galant VR4
amazing! You definitely need that johnny walker right there lol.
ლ(ಠ益ಠლ)
Old 05-12-2011   #632
Re: 91 Galant VR4
You better not kill me tonight
Old 05-12-2011   #633
Re: 91 Galant VR4
Wahoo! Be careful guys! See you (and the car I hope) saturday!
Old 05-12-2011   #634
95talonracer
Finally Tuned...
95talonracer's Avatar
Drives: Spyder GSX
Re: 91 Galant VR4
Testing in the rain tonight?
Amsoil Dealer
Old 05-12-2011   #635
Re: 91 Galant VR4
It would have been for drivability, but the weather got the best of us, the car has no blower motor, window defrost, or wipers.
On a plus the car should be up at DB saturday if its not raining hard.
Old 05-12-2011   #636
Re: 91 Galant VR4
Awesome!!
Old 05-13-2011   #637
OMFGeofffff
Re: 91 Galant VR4
Don't Dyno before 12:30. I want to see this thing rip.
Old 05-15-2011   #638
Re: 91 Galant VR4
I was able to drive the car up to the MitsuStyle dyno day for some motor break in miles. Its about a 16mile round trip and the car drove it with out a hitch. My friend Ryan was able to ride with me for the cars first drive this year.
A few things I learned on this drive, the cold can be an issue, as I do not have a blower motor or heater core.
The coolant temps do not stay above 180 while driving down the road at high way speed, and if I turn the radiator fan an the coolant temps drop quick.
The oil temps even with running about 30psi less oil pressure then last year are up around 30-40 deg F while driving around, it was about 200 deg driving home, which any good synthetic oil can handle with out an issue. So we can see a big change in adding this much hard block to the motor, the oil is doing a lot more cooling then last year. And if the oil temps get hotter then 220 while dynoing I will just add an oil cooler and that should take care of the oil temps.
I will have some dyno time setup for later this week, then there are a few days at Grove Creek before the end of the month, I want to get the 60' working before we head back to Rock Falls, which there is a day on June 4th at the Rock I would like to get to, but we will see.
Old 05-15-2011   #639
awd-drifter
'2of9'
Re: 91 Galant VR4
awesome man. keep it up! i wanna hear this beast
ლ(ಠ益ಠლ)
Old 05-18-2011   #640
Re: 91 Galant VR4
Dyno time is setup, so if it goes well I will be heading to the track Saturday for 60' testing.
