Old 01-30-2012   #61
wants to be sideways...
123abc's Avatar
Drives: Loud cars
Re: 1945/2000 is mine!
Yay, more pics.
Went for an 80 mile drive yesterday with a couple friends. Car behaved like it should. Made some mudflaps for it Saturday and they worked well too. I have to trim the rears though, the suspension really settled a lot. Transmission is still holding up. I suppose if it were to break, it would've already. I was surprised it didn't break when I used the Galant to pull the Talon shell onto the trailer yesterday so we could take it to a new spot.
Originally Posted by Matt D.
Originally Posted by 93GSX5SD
Old 02-20-2012   #62
123abc's Avatar
Drives: Loud cars
I bought myself a different intercooler from a friend of mine. It's about 28in wide, 10.5in tall, and 3.5in thick garret core. It was off his low 10 second 90 Talon, put down a little over 700 something to the wheels. I was very lucky as I didn't have to cut anything to get it to fit. Only had to drill two holes to mount it.
Only real issue is both the inlet and outlet are 3in in diameter, but the couplers solved that. Put it together, test drove it and it pulled harder than it ever has at 22 psi with that on it. When boost hits, I actually get planted in my seat.
Old 02-20-2012   #63
Nice.
Old 02-26-2012   #64
123abc's Avatar
Drives: Loud cars
Sick of this so called "winter" season, and wasting my snow tires on dry pavement every day so I put the summer wheels on. I like the 18's on the Galant, I'm curious what others think. My guess is the general vote will be too big:
Yes, car is filthy. I'm now working back at my old quick-lube car wash job so I'm going to wash it really good, wax it, and clean the inside tomorrow after work.
Old 02-26-2012   #65
I like 18's in general, I think they look a little big because they're sticking out (at least it appears so from the second pic). 17's with a slightly higher offset I think would look better.
That's a pretty sweet FMIC.
Old 02-27-2012   #66
123abc's Avatar
Drives: Loud cars
That's kind of a problem with my current brake setup, it spaces the front wheels out further than I'd like for sure. In the rear, it's pretty damn even from the top of the wheel well to the top of the wheel. I'll need to modify either the knuckles to move the calipers further towards the center of the car or find a different rotor combination.
The intercooler is working really well. Spool is very quick and it pulls harder at every psi of boost than before. Now I need some 650's and cams.
Old 03-14-2012   #67
123abc's Avatar
Drives: Loud cars
Took a couple pics after washing it at work. Finally had a chance to clean my garage up a bit with the nice weather.
I'm really needing DSMlink. I'm so damn sick of my knock sensor picking up every stupid little thing thats going on. That, and I need bigger injectors and don't want to tune with the translator anymore.
Old 03-14-2012   #68
Looks nice!
Old 03-14-2012   #69
awd-drifter
'2of9'
awd-drifter's Avatar
Drives: Racer Van V6
18s! I remember putting 17s on my old gvr4...from a distance, it looked big maybe because it wasn't lowered.
ლ(ಠ益ಠლ)
Old 04-14-2012   #70
123abc's Avatar
Drives: Loud cars
I'm going to try rocking out my stealth tt wheels that I painted once I can get the tires swapped over. They should look a bit better and not stick out so much I's think.
Took a couple more pics the other day after washing it:
The transmission I assembled is almost to 3000 miles but is making noises. Luckily I found a good trans/t-case combo for 125 so I'm just waiting on some Diaqueen trans fluid to arrive and then I'll swap it. Car is running okay, knock sensor still sucks. I'm rocking 20-22 psi but I'm running out of fuel at 22. A friend of mine has some 750's that I'll put in to take care of that issue. If not, then I'll have to get a 255 wally.
Old 04-14-2012   #71
Sign it up for the dyno day!
Old 04-14-2012   #72
123abc's Avatar
Drives: Loud cars
I would seriously consider it, but it hits fuel cut due to the IDC's being so high at 23 psi. With my e3 16g internaly gated, the boost creeps sometimes to 25 psi so I gotta be careful. I know it pulls decent, but I do want numbers for once.
Old 04-14-2012   #73
turn down the MBC a notch.
Old 04-14-2012   #74
awd-drifter
'2of9'
Awesome! Makes me want another GVR4 :/ haha. You have an idea of what you think you'll get at the dyno?
ლ(ಠ益ಠლ)
Old 04-14-2012   #75
123abc's Avatar
Drives: Loud cars
I've tried. Turned it down to 15 psi and it just climbs as rpm's climb. lol
I'd like to thiunk I'd be close to 300 awhp, but I have no clue.
Old 04-14-2012   #76
Sounds like you just need to run E85 and embrace the higher boost!
Old 04-14-2012   #77
123abc's Avatar
Drives: Loud cars
I am really intrigued by E85, but for now I'm stickin with 93 octane. All I need is a little bit more fuel and I'll be very happy.
Old 04-29-2012   #78
123abc's Avatar
Drives: Loud cars
Was able to mount the tires I bought off of Cam, Nitto 555zr's 235/45/R17. Mounted them on my stealth TT rims that I just finished painting black. I like the new look, not nearly as flashy as the 18's and better grip.
Old 09-30-2012   #79
123abc's Avatar
Drives: Loud cars
I just thought I'd post in my thread that I finally broke the transmission that I assembled. Happened last night, cracked the case. I'm very happy that it lasted for 10k hard miles though.
Old 10-01-2012   #80
Swanny
Swanny's Avatar
Drives: 2G Talon
Sorry to hear about your transmission!
Did you ever get your oil pan leak fixed?
Swanny is offline   Reply With Quote
