Old 03-18-2013   #81
CornFed2.4
CornFed2.4's Avatar
Drives: You crazy!
Re: 2G auto S/A daily
Originally Posted by 19TsiAwd90 View Post
i know james pretty well i talked to him for a bit, i posted what it was but i edited it and just put "found it =)" i figured you didnt say what it was for a reason so i i wont post it.
I don't really care if people know. I more or less just want to keep the na-sayers out.
I just wanted to post what it was after I see dyno results as I to am a little skeptical of what of what it will make.
Old 03-19-2013   #82
CornFed2.4
CornFed2.4's Avatar
Drives: You crazy!
FMIC fits nicely now behind my bumper
Mounted the radiator to make sure the ic pipe didn't hit.
Cleaned up the engine bay
Old 03-19-2013   #83
19TsiAwd90
2stepadepaaadepaaadep
19TsiAwd90's Avatar
Drives: myself crazy
understandable, well i can tell you right now the jpipe housing will restrict the flow a bit compaired to a down firing housing. but im very interested in what it will make.
Originally Posted by 311evo
Old 03-19-2013   #84
CornFed2.4
CornFed2.4's Avatar
Drives: You crazy!
This is what I ordered and hopefully will get a tracking # today.
Machined 16G j-pipe housing
Billet 11 blade 3076 comp wheel
td06h4 turbine wheel
Upgraded shaft
FP 8cm hotside
Holset wastegate
Crossing fingers it will do well. If the j pipe housing does become a huge restriction then ill just throw on a downfacing comp cover to help it out. Someone said Tachyon runs a downfacing in SA/U so ill just run that class instead.
My main goal for the car is to run a low 11 high 10. I think it's pretty doable to after seeing what the ef1 has done in carltalons full weight 2G last yr.
Old 03-19-2013   #85
4seasons69
4seasons69's Avatar
Looking good! I'm looking forward to seeing what that turbo can do!
Old 03-19-2013   #86
Tachyon
Tachyon's Avatar
Drives: Icarus
Upgraded shaft
FP 8cm hotside
Holset wastegate
I'm super interested to see what the 11 blade 3076 comp wheel does in a correct housing. You should just join me in SA/U... that field could use some more cars
-Sebastian Vettel
Old 03-19-2013   #87
CornFed2.4
CornFed2.4's Avatar
Drives: You crazy!
So you are down firing than. I was gonna ask after goodhart said you were. Ill contact TL and have them machine one for me so I have it on hand if the 16G just won't cut it. Its obviously not a huge deal what class I'm in just thought it he cool to do it with a true SA cover.
Old 03-19-2013   #88
blackawdtsi
Drives: 2G DSM
I'll run SA/U if you need more cars.
Old 03-19-2013   #89
4seasons69
4seasons69's Avatar
Lol if you're running sa/u can I get in on that too? Hahaha
Old 03-19-2013   #90
CornFed2.4
CornFed2.4's Avatar
Drives: You crazy!
You still have the blue auto?
Old 03-19-2013   #91
Tachyon
Tachyon's Avatar
Drives: Icarus
I am... actually our turbo specs are going to be identical, except for compressor wheel. I am going to see how far I can push a cast OEM 20g wheel this year.
What I am really afraid of is MAP changing the SA-SA/U rules on us as we both appear to be down the critical path of our builds.
-Sebastian Vettel
Old 03-19-2013   #92
CornFed2.4
CornFed2.4's Avatar
Drives: You crazy!
Cool! 99gsxjoel is doing a 20G on his 5 speed but I think he's going billet extended tip.
Yeah that's why I'm holding out on tires still. If I'm in SA I'm gonna run nittos. SA/U gonna run QTPs.
Map said on Facebook that the rules should be posted by the weekend.
Old 03-19-2013   #93
Tachyon
Tachyon's Avatar
Drives: Icarus
Nice looking forward to seeing the rules. You going to be doing any road course at the PG?
-Sebastian Vettel
Old 03-19-2013   #94
CornFed2.4
CornFed2.4's Avatar
Drives: You crazy!
Probably not. Not to sure it would be the same in an auto.
Old 03-19-2013   #95
Awesome progress!
Old 03-21-2013   #96
CornFed2.4
CornFed2.4's Avatar
Drives: You crazy!
Installed the 255 walbro hp. ran a -6an line up front.
Finished taking off all the sound crap that is glued to the floor.
This weekend I will be swapping in an LSD rear end.
Ill post pics tonight
Old 03-22-2013   #97
CornFed2.4
CornFed2.4's Avatar
Drives: You crazy!
0 mile non turbo cluster
Sound detening gone
Black carpet
Black rear seats in
No more grey
Old 03-22-2013   #98
99gsxjoel
Drives: 1999 GSX
Looking good.
99gsxjoel is offline   Reply With Quote
Old 03-22-2013   #99
That looks awesome with the all black interior!
Old 03-22-2013   #100
Damn dude you are doing some serious work!
How did you remove that sound deadening stuff?
