Old 05-20-2011   #981
Re: the evo 3 swap parts are coming
That stuff you used sounds way better than normal paint for a daily driver or something that will see some abuse. The way if it gets a scratch all you have to do is touch it up and it will blend it by itself sounds super nice. Painted engine bays look nice when freshly done but if scratch/dirty they look worse than this paint will.
Looks nice dude!
Old 05-20-2011   #982
NI did paint it the first time with ppg paint gloss black it held up for a while chipped up ect in a few years this way I can easly repair it
Old 05-20-2011   #983
just after the 3rd coat of paint it is still wet at the pics
Old 05-20-2011   #984
Woo hoo! Looks good!
Old 05-25-2011   #985
worked on the car put some of the stuff back in the engine bay. Cleaned the front cusco zero r2 coilovers and oiled the crap out of the camber plates. Use some of the fuel line holders that I brought home for the return line and the fuel filter. Also put the ce9a data plate in the car. I had the cd9a one from the evo 1 front clip. Got the hid boxs hidden and the hella super tones back on.
now I just have to wait for the ltt rear control arms to show up and all the braided nylon wire loom to get here
Old 05-26-2011   #986
got the radiator in and bolted the fmic back on.
the wire loom was shipped out today so I will good to go next wed for the start of the rewire. also thinking of putting in a mock up engine and the tranny so I can do the engine harness so I can make every thing as short as I can
Old 05-26-2011   #987
Pardon my ignorance, but what are those huge red ufo looking things?
Old 05-26-2011   #988
they are hella super tone horns they are 118db
Old 05-28-2011   #989
Wire loom showed up today
Old 05-30-2011   #990
Got the new battery box made last night at work. It will hold a yellow top. The box it self is 304 1/2 hard s.s.
It will be going inbetween the frame rail and 1/4 panel on the right side of the trunk. It will be sunk in to floor and bolted in flush so the trunk will not loose any space
Old 06-01-2011   #991
took out the seats and carpet and found this going to have to get some dry ice to get the sound deadner and fix the rust now.
also rewired the engine bay. got it all hooked up and tested it out to make sure it all works and passed with flying colors
lest side just has a few wires that had to be extended
the right side all the wires needed to be extended into the car
where the fuse box is now going to sit. just have to make a bracket for it
tomorrow I will take it all back out and loom it all
Old 06-01-2011   #992
God I hate wiring...
Old 06-01-2011   #993
cmspaz
Walls need hugs too
cmspaz's Avatar
I'd rather wire than deal with rust...
Originally Posted by Trogdor
Old 06-01-2011   #994
Old 06-02-2011   #995
got it loomed today
back in all the wiring out of the fuse box is behind the firewall pad
just have to plug the wires in the the fuse box and put it back up were it goes
all the wiring back up were it ran to start with and all zipped tied down
all the wiring that is going to be in the engine bay from the engine bay harness. 2 sets of wires. 1 set for the city lights and 1 set for the hid lights
also my parents stopped by and he gave me a hand putting in the tranny,bare block and scrap head so I can do the engine harness now.
the engine harness that will be taken care of tomorrow
also UPS dropped of some parts. 10an s.s. lines. 1. has a 90 and a straight and the other has 2 swivel 90's on them. going to get a 90 for the straight and put a swivel 90 on the other line. They are getting used for the new oil cooler set up.
Also the best part they are going to buy the mirage evo 1 swap from me so they can have a 2nd car so the truck can sit. My mom just wants it with the stock panels and the evo x wing on it so. I am going to sell the evo 1 front bumper and skirts
Old 06-02-2011   #996
I think that wiring is gunna look really clean!
Old 06-02-2011   #997
Thanks Brandon. The engine bay harness was not as bad as I thought it would be. There is so little wires in the evo harness over a Dsm it is crazy.
Old 06-02-2011   #998
95talonracer
Finally Tuned...
95talonracer's Avatar
Drives: Spyder GSX
Are you cleaning up the engine or tranny at all?
Amsoil Dealer
Old 06-02-2011   #999
The block and head in it are just for doing the engine harness it is not the 2.4. It is just one of the few blocks and heads I have laying around. I will be cleaning the tranny up after I get the harness done and pull it all back out.
Old 06-03-2011   #1000
Started on the engine harness. Took out the 2 plugs that are not needed. Also moved the wiring for the mas and the plug for the fuse box to the in side of the car.
Marked and cut the harness in 1/2 to shorten it all up.
Also fedex droped of the new rear ltt lca's
