Old 06-03-2011   #1001
Re: the evo 3 swap parts are coming
got the engine harness cut shorter by 2.5 feet. it is all soldered back together and ready to go back in the car. just have to add the wideband, egt,gm mas wires to the engine harness. Then I can loom the harness from the fire wall out. Still have to wire the mas and the plug to the fuse box in the car when the harness in.
Old 06-03-2011   #1002
Wow, Lots of stuff goin on with this! Too bad we work different schedules and I can't stop by to help out. Sucks about the rust! That wasn't there when we first did the swap.
Old 06-06-2011   #1003
came home from work to new parts
new oil cooler the stock evo one went into the trash can
jmf coil bracket just have to get the jay's alt relocate kit now
Old 06-06-2011   #1004
hippiekiller
hippiekiller's Avatar
Is that a fluidyne oil cooler? I have one much like that for my 2g. Should work quite well.
Old 06-08-2011   #1005
got the engine harness loomed and put it the car. still have to add to the brake and wiper wires. Not much is going to show at all still have to pull it tight behind the engine and make a few brackets to hold them to the back of the block.
left the harness to come out the stock spot since the washer bottle covers it up
all the wiring behind the engine now
wires that will show a bit. cas,2 on the t.stat,the o2 plug,tranny back up lights,tps,and isc. they will be pulled tight and hidden as much as they can be
cant see the injector plugs any more, going to plug the 3 vac. nipples on the smim and run a vac block with all s.s. an lines to every thing
got the new oil cooler put on. use 1 of the stock brackets that was on the car and made one out of some titanium I have laying around
Also got all the heater boxes back in the car.
Old 06-09-2011   #1006
wiring is all done now
got the mas plug and the fuse box (engine bay) plug wired back to the engine harness. You can also see the hole going into the engine bay that was for the drain on the a/c box. I cut the bottom of the box off and made a plug for it. I will use the hole for the Alt. wiring,starter wiring,wide band,boost,egt gauge wires
The gm translator box is now next to the engine bay fuse box also will be putting the fuse block up there for the power from the battery
starting to look like a car a little bit
Tomorrow going to do the rear end and battery box and a few other things. I am running out of things to do that are free.
Old 06-11-2011   #1007
Work on it yesterday with my dad he came over to give me a hand. Started to take the rear end apart. It was a huge pain in the ass. When we put the rear end in the car it was all together still so we left it alone. Broke bolts,had to cut out arms from bolts being frozen in the bushings,ect
Cut open the frame rails to reinforce them more. When I had the 2.0 in it i riped the bolts throught the frame rail on the left side. I don't want to deal with it pulling back out with the 2.4
As the rear end is right now lower arms out,megan toe arms are out also.
The stock rear lca had to be cut out the camber bolts were froze in the bushings and 1 of the sway bar links had to be cut off as well
This realy pissed me off the megan tow arms the bolts were also frozen in the bushings and they have not been in for that long under 2years. Going to bring them to work and make some new bushings for them and a set for the camber arms when I order them.
Old 06-12-2011   #1008
19TsiAwd90
2stepadepaaadepaaadep
19TsiAwd90's Avatar
Drives: myself crazy
anti seize is a great product, not trying to be a smart ass or anything just saying, otherwise looks to be it coming along nicely. I like!!
Originally Posted by 311evo
Old 06-12-2011   #1009
The Megan arms were anti seized the rest of the rear sub frame was never taken apart. But after a few winters slat just rusted everything anyway
Old 06-12-2011   #1010
19TsiAwd90
19TsiAwd90's Avatar
yeah salt just is one mean bastard to cars makes me sad sometimes =(
Old 06-18-2011   #1011
woo. sold a bunch of my paintball gear I dont use any more last few nights and it is back to the 50's weekend car show. So there is a ton of venders and over 14000 car 1964 and old.
my dad got me the bendable s.s. heater hoses to match my radiator hoses that I got for the car last year. (traded my dad a halo hopper for them )
with the money I got for the other p.b. gear I got
x2 -10an 45's
x1 -10an 90
x1 -10an straight
x1 -8an 90
x2 -10an 90 bulk head fittings with jam nuts (they had to order them will have to pick them up on wed)
7ft -10an s.s. line
2ft -8an s.s. line
also bird at work made me some alum bushings for the megen toe and camber arms. just have to press them in now
Old 06-19-2011   #1012
Got today at back to the 50's
-an ajustable wrench my dad got it for me. they also gave us all hat's for all the stuff I got from them this week end
Ordered the last 2 fittings I needed for the ofh forgot yeaterday
Ordered the alum blocks for the vice to put the an fittings together
Got paint for the inside and fender wells eats and stops the rust. KBS-COATINGS.com
my dad got 2 QT cans of satin black for 60.00 and gave me one
Got a 80a realy to replace the 30a one on the bosh -044 fuel pump
got a 3 in and 4 out fuse block for power for alt,starter,ect
also got 4 20a fuses for the gauges and smaller stuff to run power to
everything in the pic was 15.00 love cheap
Old 06-21-2011   #1013
painted a few parts today since I have to stay of my right foot for a while. I ripped almost all the tendons in 1/2 in the right side of ankle.
Old 06-28-2011   #1014
Got the rest of the an fitting today
Also got an alum blocks for the vice.
Old 06-29-2011   #1015
started on the lines today
10an for the oil cooler
new 8an line for the fuel rail. I am going to get a extra 90 fitting for the afpr to make the line shorter
also drilled the baffles out of the valve cover so I can put the 2 90 10an fittings in. going to tap and put in s.s. alan screws to hold the baffles back in
the baffles are soaking in degreaser right now
Old 06-29-2011   #1016
DSMINMN
Mitsus for days!
DSMINMN's Avatar
Drives: '08 Chrysler 300C
Sick looking project. I'm loving the progress.
Also, I love Hella super tones
Old 07-01-2011   #1017
got the last of the big AN lines done.
taped the breather tube to m8 1.25 and put in a alan plug in it
retaped the pvc hole to 1/8 pipe and plug it with a alan plug
got the hole drilled for the 10an fittings in the valve cover
also got 3 1/4in pipe thread alan plugs for the intake manifold since I will be running a vacuum block and all 4an lines for every thing that needs vac. Took off the smim and went after it with some heavy cut and the buffer.
the new 10an lines for the catch can
how the engine bay looks right now. Now that I got it all done I can take out the bare block and head and then clean and paint the tranny
Old 07-01-2011   #1018
Fancy!
Old 07-01-2011   #1019
Thanks chris
Just brought the the hood out side and put it on the car to make sure I have room still. Got over an 1in on the front one and well over 2pm on the back one and the heat shields are right there and are 1/2 from the hood any way
Old 07-04-2011   #1020
surensm
Drives: Getting ready to drive a evo 6
Nice project dude, i might start my own soon, 98 mirage to evo 6 TME. I found all the parts, just gotta get the car and buy the parts. I have a $15k budget and one month to finish it. Cant wait to start
surensm is offline   Reply With Quote
