Old 08-17-2011   #1
Re: the evo 3 swap parts are coming
I have not really worked on it to much. I was working on the evo 1 swap pulling it all back apart and putting all the stock mirage panels back on it since I sold it as a rolling shell last week
but any way I did get a few parts sandblasted and painted
Old 08-17-2011   #2
score
evo 2 engine harness, evo 2 ecu, evo 2 cas. all going to be spare parts. got them all local for a steal of 40.00 for it all
also went after the polly mount with the belt sander at work since it was just a little to big to fit nice in the mount on the car now it does not need a hammer to get it in
Old 11-21-2011   #3
got the alum rear lca's modded to work with the sway bar. My buddy big bird (mike) made and welded the brackets on them for me. The brackets are copy's of the oem ones on the factory steel arms.
Old 01-07-2012   #4
Well it has been a really long time since I worked on the evo. so today I pushed the spyder out side to work in it.
Put the suspention back together,fenders,and rims back in the front. On the rear I got the new plates welded in the car so I dont pull the rear end out of the frame a 2nd time. I got the alum bushings pressed into megan toe arms. Put the ltt alum lower lca's in the car. I still need to get new sway bar link's. The car is now back in the ground from being on jack stands for a year.
Old 01-08-2012   #5
the laptop died last night up loading pics/
so here it is back on the ground
and both of the projects
Old 01-08-2012   #6
Looks like one fun garage!
Old 08-30-2016   #7
Holly shit someing is going to happen to the Evo. It has been siting for years apart. It is now going back together. Stock 7 bolt bottom end,rebuilt head with Evo 8 valves and springs,fp2 cams, and a mitsu 20g.
The Spyder is going back in to storage since it is giving up its parts for the Evo till I fix the 2.4 for the Spyder.
Engine,fly,clutch,fmic,afpr,fuel pump,SD set up
Had a 95 mirage I was going to fix up. But decided to part/scrap it. Kevin came over and we took off the roof skin and the glass. The skin is send and rust free. This year it will be to get it back on the road then over the winter get the paint ect to be ready when it gets warm to spray it.
Also took off the parts car.
Un rusted trunk
Mint head liner
And a few other spare parts that will go in the the bins of Evo stuff.
Had some other helpers on the parts car also
