Old 05-03-2012   #1121
Re: beaterX project thread
Originally Posted by simulatedwood View Post
Are the Cobb and nisei setups one piece construction or welded together aluminum pieces to form a single piece?
One solid piece, no welds.
Old 05-03-2012   #1122
That transition coupler is really nice, I like it! No mounting brackets on the UICP though?
Old 05-03-2012   #1123
Glad to see you have gotten your shit straight! Can't wait to see it on the dyno. I'll let you max the EF4, I am going to play it safe
Hah don't expect anything crazy, I don't plan on pushing it...I'll be running my usual 30psi as my fuel system is at its limit anyways.
Nice, that reducer coupler has a nice transition who made it?
Dunno, it was just in the box.
Yup it's a nice piece! I'm actually not even using it on my car yet b/c my car came with a modified turbo outlet pipe that transitions to 2.5" on its own. It's not very smooth but it doesn't appear to be holding me back yet I'll probably sell it with my (soon to be) fixed old UICP.
No brackets, that would just add cost I guess and I don't really think they are necessary. I kinda like not having them actually, lets the pipe move more when the engine rocks. It would definitely 100% eliminate blown I/C pipes but other than last night (forgot to fully tighten t-bolt on intercooler) it has never ever been a problem for me on this car.
That being said, this car drives *amazingly well* with a blown I/C pipe. On a DSM/CT9A maf-based evo you would be hard pressed to make it anywhere...I actually drove several miles back to my house and just fixed the car in the garage, no issue...just light throttle.
Oh, and in other news, my LTFT's decided to start working again! Checked this morning, right at 1.5%
Old 05-03-2012   #1124
Is the car SD?
Old 05-03-2012   #1125
Is the car SD?
Partially...sorta.
Old 05-03-2012   #1126
Partially...sorta.
lol, well i guess that explains it.
Old 05-03-2012   #1127
Partially...sorta.
The ECU uses both an SD and MAF calculation and depending on conditions, makes fueling adjustments based on both.
Old 05-03-2012   #1128
polishmafia
Smells like cat poop
polishmafia's Avatar
When I got back, I ordered up the Hyundai 4b11 pulleys that apparently fit....and are METAL NOT PLASTIC! Effing plastic pulleys, seriously mitsubishi?
You coulda borrowed mine!
Old 05-03-2012   #1129
LOL! I'd love to see how they're routed on your car actually, mine is just redonk....8.5' belt!
Old 05-03-2012   #1130
New pipe looks nice. I always use hump couplers at the very ends now a days as well to allow for some flex.
Old 05-06-2012   #1131
Well, the car is missing about 25-30whp IMHO but that's how my luck rolls with cars I'm fairly certain I have gunk on my intake valves again, need to run some pump gas/injector cleaner through this thing and see if it improves...should have done it before yesterday but meh, life's busy.
MitsuStyle.com spring dyno day yesterday! We were a little down on car count so we put my car on last and Shane @ DB Performance tweaked it a bit since it's been a year since it's been really dyno tuned. First pull was 467whp, final pull was 499.7:
This is a 1.0CF Dyno Dynamics dyno.
Walbro 400 + BAP + boomba rail + FIC 1680's are doing their job pretty well!
Still some taper, but we had some odd fueling issues so just left boost like so:
and dynojet/shootout numbers:
Got it on the road and afrs went a little leaner....so I realized last night that I need to really finish/re-engineer my air filter heat shield situation. I have a small shield that I made temporarily out of my stock exhaust manifold shield but the stock snorkel bypasses this and blows right on the filter....I have the primo intake and the maf sensor is placed right by the air filter, at the end of the pipe...I haven't looked at other manufacturers, but IMHO they should be moving the sensor back a good 6-10" from the filter inlet to avoid what I'm seeing.
I love having fresh air blow right to the intake but I guess it's causing problems. On the dyno afrs are rock-steady in the 11's, but I hit 13's on the street. Last night I had a eureka moment with all of this and I temporarily blocked the snorkel with my temporary shield and AFRs instantly dropped to where they were on the dyno.
So I ordered one of these:
http://www.ebay.com/itm/370609679924
We'll see how well it fits and how functional it is...if it's all good then I will get it and my new UICP powdercoated wrinkle black.
Old 05-06-2012   #1132
Revobasher
Revobasher's Avatar
Drives: 14 Evo X GSR
^^ nice.. plus engine bling blang!!
2014 CB Evo X GSR - 323/324 @ 26lbs (Mustang Dyno)
2012 IS250 F Sport - TOTALLED
2006 Evo IX MR - ​SOLD
Revobasher is offline   Reply With Quote
Old 05-07-2012   #1133
Murlo26
Murlo26's Avatar
Drives: 17 Honda Accord
Looking very solid there, great numbers bud! Congrats.
Old 05-07-2012   #1134
Mark Leasure
Mark Leasure's Avatar
Good idea on the air filter heat shield. Let me know if it works out. I need to do something similar, as I had the same kind of AFR situation from dyno to street a while back on the silver car.
Old 05-07-2012   #1135
Nice numbers! Car was looking good on Saturday too!
Old 05-07-2012   #1136
Great numbers for a killer street setup, and still kick some ass at the track. Must be a blast to drive.
Old 05-09-2012   #1137
Thanks guys!
Got the shield in tonight, $30 shipped from summit via ebay, hell yea! I tried a few different clamping techniques but ended up clamping it under the clamp for the air filter itself....the lip to clamp it down onto is really NOT very wide so I HOPE it doesn't rattle off...we'll see tomorrow I guess!
Fits nicely but not perfectly around the 3.5" inlet filter:
Blocks air from a/c fan as well as snorkel:
But still lets the snorkel dump fresh air into the engine bay, I like that!
Fingers crossed, seems to fit nicely!
Old 05-10-2012   #1138
Not a bad garage-rigged solution! You could probably cut it down a bit to allow some of the fresh snorkel air to the filter, but while still blocking the A/C fan air.
Old 05-10-2012   #1139
Not a bad solution, I need to cover my filters as well, link?
Old 05-10-2012   #1140
awd-drifter
'2of9'
awd-drifter's Avatar
Drives: Racer Van V6
wow, those numbers are hella killer! haha. looks good with all that bling lol
ლ(ಠ益ಠლ)
