View Poll Results: What motor
LQ9, iron motor, $800ish 187lbs 14 58.33%
LS2, aluminum motor, $2k-3kish 87lbs 10 41.67%
Voters: 24. You may not vote on this poll
Old 02-23-2009   #101
rose0529
Who has my man-card?
rose0529's Avatar
Drives: a red car
Re: What motor would you choose? To put in a Z car.
anyone suggested one of these? I'm sure its not cheap but would be pretty unique!
Just a thought...
http://www.h1v8.com/page/page/1562068.htm
Hartley Enterprises brings you the H1 V8 engine. After 4 years of develop-ment and testing, the final product is a robust design with patented features related to it's compact design.
The H1 V8 is a 2.8 liter 32 valve V8 which weighs less than most 4 cylinder engines and is about the same size. Track cars and other lightweight race vehicles which have been limited to 4 cylinder engines for size and weight reasons are the target market.
For more information on this engine, please look through the website. Please check back from time to time for updates.
New product- H2 BUSA engine! The design is complete and manufacturing has begun on the BUSA engine.
The H2 BUSA engine will be offered as a kit or complete engine. As a kit, it allows the transfer of all Suzuki Hayabusa upper engine parts to a robust 6061-T6 billet crankcase designed to be mated to automotive gearboxes like the Ford Sierra Type 9. The engine has a 4 stage dry sump system which enables the crankshaft to be just 116mm from the engine bottom. With the 140mm clutch, 215mm flywheel and compact bellhousing, the entire drivetrain on a 7 type car can be lowered several inches. The engine is estimated to have a fully dressed weight of 140lbs and can produce 175 to 250 hp NA; and much more in turbo form.
Availability to be 1st quarter 2009. Check back for updates on the prototype build and specifications when they are released. (No pricing is available at this time, but it is design to be much more affordable and will be available as a kit) Email jhartleyjr@wi.rr.com with "H2 BUSA update" in the subject line and you will be notified when more information is available.
Old 02-23-2009   #102
I heard about that a while ago, but i didn't find much info. whats the price i can't find it.
Old 02-24-2009   #103
Wow, those 8 throttle bodies would be a major PITA to sync.
