Old 04-12-2010   #121
4g63tcrazy
is Nashty
4g63tcrazy's Avatar
Drives: Cyborg from Japan
Re: Project Winter Beater
Who will get their car running first? Me or you..?
-1990 Mitsubishi Cyborg 4WD-
Old 04-13-2010   #122
wants to be sideways...
123abc's Avatar
Drives: Loud cars
I'm betting you will. We'll see though, I plan to work on it through most of the day today.
I still have to do a 4 bolt swap....
Originally Posted by Matt D.
Originally Posted by 93GSX5SD
Old 04-13-2010   #123
123abc's Avatar
Drives: Loud cars
Got the trans in, but eventually figured out when I couldn't get the slave on that I have the fwd motor mount bolted to the block. No wonder it was so damn hard to get the trans mount on....
Anyways, I snapped a couple pics:
Old 04-17-2010   #124
123abc's Avatar
Drives: Loud cars
Started taking the wire wheel to my passenger side rocker and it's not looking good:
To be honest, all the metal along the rocker is weak and needs to be replaced in my opinion. I have not tried the driver's side with the wire wheel yet, but on the passenger's side I could cut right through the metal with the wire wheel end on a drill. Not a happy person but what are ya going to do?
Old 04-17-2010   #125
4g63tcrazy
is Nashty
4g63tcrazy's Avatar
That really sucks. One of the main reasons I've stuck with FWD for so long. My shell is mint.
Old 04-18-2010   #126
123abc's Avatar
Drives: Loud cars
My Laser stayed mostly rust free because it never came with the side skirts. The rest of this car is good as far as the floor pans and what not. It's only until you get under the side skirts and look into the rear wheel wells that it's bad. The side skirts are really bad at trapping everything in there.
I'm saddened by it, but whatever. I'll still patch it, even if it doesn't look 100%. If it seals and it's strong, that's all I care about because I'm going with a 94 side and rear end conversion so those side skirts will cover the whole lower side. Not to mention I get a better looking ass....
Old 04-18-2010   #127
123abc's Avatar
Drives: Loud cars
Drove the car back to my apartment! Feels really good to drive it again. Need to bleed the brakes some more, but for the most part it was really solid. Fired up first try.
Twack took a video or 2 I think when he followed me home. Open downpipe ftw!
Old 04-19-2010   #128
twack
It was a auto get over it
twack's Avatar
Old 04-19-2010   #129
twack
twack's Avatar
by vids he means these
Old 04-19-2010   #130
123abc's Avatar
Drives: Loud cars
Took it into school today to swap in the 4 bolt rear.
Need to replace the heater hoses as they piss coolant pretty good when it heats up. Need to set base ignition timing as well, route a vacuum line for the wastegate, blah blah. It's all mostly little things.
Old 04-19-2010   #131
twack
twack's Avatar
well yours ran first i guess andy, but also broke first, so i would have to put it at a tie.
Old 04-19-2010   #132
123abc's Avatar
Drives: Loud cars
The good thing is they both run...
I cleaned out my garage for the first time since tearing into the Laser. Snapped a pic of the Talon from off my deck:
Old 04-22-2010   #133
123abc's Avatar
Drives: Loud cars
Drove it to school today to fab up the rear section of my exhaust. Just need to get a muffler for it and some hangers welded on. Also put it up on a lift and started replacing the inner tie-rods because the stock ones have the jam nuts seized. Also found a driver's side axle with good threads so I can put a nut on it. (thanks Zach)
Felt boost with it for the first time today after getting the CAS adjusted. I need to finish the exhaust though because the knock sensor is picking up the exhaust from the open downpipe....hahahaha
Old 04-22-2010   #134
Cars looking good!
You sure about the knock from just the open down pipe? I've ran open down pipe on my car since I've got it running and it doesn't knock. Maybe yours hits the oil pan or something or it really is knocking?
Old 04-22-2010   #135
123abc's Avatar
Drives: Loud cars
Cars looking good!
Thanks man! Honestly, if it was hitting something I couldn't tell anyway. It's so loud..
It might be really getting knock, I'll have to check it out when I get my logger back from Zach. I feel it was phantom knock because it cleared up quick and pulled good in 1st. It's nothing that worries me at the moment until I actually hook the logger up.
Old 04-23-2010   #136
123abc's Avatar
Drives: Loud cars
Did the first prototype of my exhaust today and it fits, but needs some tweaks. Never mind the shitty welds too, I had large gaps to fill and it was my first time welding in over 4 years...so go ahead and laugh it up.
I was also able to install my inner tie rods, but I need to align it next week because I didn't have enough time at school today. I do have a current interior pic, however:
Old 04-26-2010   #137
123abc's Avatar
Drives: Loud cars
Snapped a few more pics today:
I wanted to get it on the alignment rack at school but some kid was lost and had his Buick on all day. So instead I went about setting idle and boosting around at wastegate for a little bit. I need to revisit my ignition timing as it hesitates durring spool but opens up when it hits. I think it might be a little bit too far advanced. I also need to do a boost leak test on it.
Old 04-30-2010   #138
123abc's Avatar
Drives: Loud cars
My friend brought down the 94 rear bumper and tail lights today. So tonight after work I put them on. I'm hoping with a good wash and then a buffing and wax my car will match the bumper better.
No TSi here...
Old 05-03-2010   #139
123abc's Avatar
Drives: Loud cars
I still need to get the rear tail light harness from my friend so I can have working tail lights and what not but I'm happy with it:
One from the front for shits:
Still have to fix the exhaust but I'm kind of holding off on that for a little bit. Might have a name brand exhaust lined up...
Old 05-11-2010   #140
123abc's Avatar
Drives: Loud cars
Got a flat on the left rear tire so I swapped my stock Stratus wheels over. I actually am liking these a lot better than the 2g swirls:
Funds have been lacking so there haven't been a lot of updates at all. Now that school is out for the summer I'll be working full time so hopefully once I get caught up with bills there will be more progress.
