Old 07-11-2010   #121
96GST16g
livin the dream
96GST16g's Avatar
Drives: 07 zx6r and 04 Rx8
Re: GheyrodX - bigger, fatter, gheyer!
that WRX looks sick! oh and the white evo behind it
96GST16g is offline   Reply With Quote
Old 07-11-2010   #122
rose0529
Who has my man-card?
rose0529's Avatar
Drives: a red car
Looking good! The ride height looks really nice!
Old 07-11-2010   #123
Same place the AMS exhaust rub...rear passenger side lower control arm mount. I'm hoping to reposition the exhaust slightly with the forward-most slip-fit flange to give it the extra maybe .5" clearance it needs. I plan to get under there later today.
Just got out from under the car. It was actually rubbing on the passenger side rear differential brace. I think I've adjusted it enough to not rub anymore, but if not I can simple grind the brace down a bit and that should work. I'm thinking my 3" section that replaced my 2.5" neck-down isn't perfectly straight which is what's causing the slight imperfection. I still am really loving this exhaust though! It's such a smooth and quieter tone. I think the SpecialtyX catback is still my favorite, but I'm not baller enough for that (and some of those have rubbing issues too unfortunately) and it hangs a bit low for a daily driver IMO.
*edit*
The exhaust rattle is 99% fixed. I think another small adjustment and it'll be perfect.
Old 07-11-2010   #124
Thanks, I am 100% happy with these springs! I hit some pretty wicked RR crossings and inclines yesterday over in Fort Worth and didn't scrape once.
Old 07-12-2010   #125
Sexy ride height!!
Old 07-23-2010   #126
Quite the busy day today! First of all, huge thanks to Scheides and Spaz for giving me a hand with the mod installs this morning, and second thanks to Shane @ DB for sending me home with yet another great tune!
This morning we installed the AFE Stage 2 Dryflow intake kit, DB MBC, Nisei 1-piece UICP, and removed the clutch restrictor pill. Then it was off to DB to get a tune from Shane. Yes, Shane is the main reason Janelle and I drove the X up from TX rather than just flying. I'll post up some charts later, but it made 274 whp at 26 psi peak tapering to 18. This is a bit lower than I was hoping for, but still only 4whp below Scheides who does have a FMIC and the WGA arm tightened over my car. Out on the streets the car feels absolutely fantastic and I couldn't be happier with how it feels. Shane also made me a 91-octane alternate map for use when driving between Minneapolis and Dallas since most the country stations don't have good gas. The alt maps are ultra slick, I just hold down the cruise control button for 3 seconds to flip between the primary and alt maps.
As for the mods I chose, I couldn't be happier. The AFE intake fit perfectly as did the Nisei UICP which seriously looks more stockish than the stock UICP did since it's a single mandrel bent aluminum pipe coated in matte black. The DB MBC was coated by Primo in gloss black and also looks good in the engine bay. Although most guys with the X opt for electronic ECU-controlled boost, I chose to go the simple yet effective route. I've had nothing but great lucking using MBC's for the past 10 years so I figured there is no reason to not go with one; especially since I tried all the ECU methods on my IX and ended up going back to a MBC and being much happier. The stock clutch feels much more direct and responsive with that stupid pill removed too. It actually engages when I want it to and doesn't slip the clutch at all during a hard shift. Hopefully this will help my stock clutch live a long and healthy life.
I'll also add that the X is a fantastic roadtrip car, especially with the cruise control and satellite radio. So far I have ~1,700 miles since last Friday and by the time we get home on Sunday I expect to be nearing the 3k mile mark for the trip.
Old 07-23-2010   #127
Murlo26
Murlo26's Avatar
Drives: 17 Honda Accord
I say my buschur exhaust is the reason i am so much higher than you guys, lol. Seriously though, was my car that strong? I made 302 whp with intake, testpipe, catback. Wonder what you guys are missing.
Sorry I didn't get to talk much at DB kracka, I had to try and get back to work, i was already gone for 2 hours for lunch, lol. Nice seeing ya though.
Old 07-23-2010   #128
Chim55117
Drives: 2007 BMW 335i Coupe
Impressive #'s! What sort of gas mileage are you getting?
"We are what we repeatedly do. Excellence then is not an act but a habit." — Aristotle
Chim55117 is offline   Reply With Quote
Old 07-23-2010   #129
Murlo26
Murlo26's Avatar
What was your baseline? Hows it feel now?
Old 07-23-2010   #130
No worries, good seeing you again too.
I do think the Magnaflow catback Scheides and I are running are eating up some power since they're baffled and not a straight-through design. I figured that when buying it though and I'm fine with it since it's so quiet for daily-driving which I really like. Your car could also be a freak too like my IX was; nobody has beat my IX stock turbo pump gas power @ DB yet (326whp).
I think my plan for the winter will be to add a nice FMIC (Perrin and AMS are at the top of my list right now, cast endtanks are a must for me), o2 housing and downpipe (Megan? Rexpeed? AMS?), and crank down the wastegate arm a turn then go see Shane again for a retune next summer.
Old 07-23-2010   #131
It feels awesome on the streets. Not as powerful as my IX obviously, but so much smoother and more enjoyable to drive. We sat in some pretty nasty stop and go traffic on 94 afterworks and it idled and drove perfectly smooth.
I didn't get a baseline number since I installed the MBC this morning and arrived at DB only running 11 psi (wastegate pressure).
Old 07-23-2010   #132
Murlo26
Murlo26's Avatar
^Nice. Your car looked good...little dirty from the drive, but looked great, i love those side skirts, I might have to buy some.
Funny thing is how many people online said that i was crazy when i said my car was strong, because i used "rice math" to compare to their numbers. But after seeing lomker with a lot more bolt ons do the same power, scheides and you...maybe my car "was" strong, maybe thats why it blew up, lol.
So do you feel the tune big time? Usually the first one is always the biggest difference, then you get the diminishing returns.
Old 07-23-2010   #133
According to the dash computer, 24 MPG driving from Dallas to Minneapolis with the cruise set at 85 MPH and 26 MPG driving from Grand Rapids to Minneapolis with the cruise set at 65 MPH. I expect the open filter and tune should help me get a bit better mileage so I'll update once we're back home. As a comparison, my IX got 27-28 MPG doing 80-85 and touched 30 once keeping it under 65.
Old 07-23-2010   #134
Oh yeah, for sure. Spool-up is much more responsive and pulls are quite a bit smoother and clean feeling.
It'll get a good scrubbing once back in TX. I left home fully detailed, but all those highway miles, bugs, and rain really made it look like crap.
Old 07-23-2010   #135
Murlo26
Murlo26's Avatar
Gearing! The X gearing is way shorter hence shitty gas mileage
Old 07-23-2010   #136
It's actually identical to the IX GSR gearing (64 MPH at 3k RPM in 5th gear). VIII's are geared longer.
Old 07-23-2010   #137
Murlo26
Murlo26's Avatar
Thats what she said!
But seriously, the 9 5 spds are the same? You sure?
Old 07-23-2010   #138
Yup
Old 07-24-2010   #139
pfft. Shitty mileage. The best my WRX has ever seen was on a road trip to Grand Portage last summer and I got 23.9mpg ALL highway miles. Usually averages about 22mpg highway.
Old 07-24-2010   #140
Woohoo gheyrodX! Congrats hughes, you have a damn nice car once again. I feel like shit that we forgot to do the wga crank mod, but it seems we hardly had time for the stuff we did do. Just think, if you had gone ecu-controlled boost, you wouldn't be able to do it w/o a retune. Now, you can just do it at your leisure, get some before and after logs, tweak the mbc if needed and you're doneski Or just wait till you get back, but I'd say its worth just doing on your own.
I'm still up in the air on your short-shifter. Maybe if I hadn't driven it through dead-stopped traffic I could have experienced it more!
Also, don't forget to cash those lottery tix! Hope you had a good bday man!
