Old 10-19-2010   #121
mdost03
Sonic Champion!
Drives: VA STI
Re: Project GC8 AKA USDM STi Killer
Looks awesome Shawn! Can't wait to see how it looks after it's completed.
Old 10-20-2010   #122
DoughtCom
It's deluxe son... deluxe
DoughtCom's Avatar
Drives: Your mom
Another update
For the first time in a few months, she's back on the ground and I drove her 2 feet! I'm really hoping my O2 sensor fixes my problems today so I can get an alignment and drive it to Deadmau5!
2010 Evo X GSR
1997 Subaru GC8 STi
Old 10-24-2010   #123
DoughtCom
DoughtCom's Avatar
Drives: Your mom
A lot of you might or might not know my Evo died on Friday. I was leaving MAP to pickup a coupler for this project when I went to shift from 3rd to 4th and, what I believe was, my shift fork in my transmission broke. I managed to limp it back to MAP and they confirmed it's most likely toast so now I have no car. Luckily my wonderful GF can loan me her's for a while.
The reason for this intro is my Evo is going to cost me $2300 or so dollars to fix, which unfortunately brings this project to a halt for this year if I can't figure it out today. I will be working on it until 5PM today and then officially calling it quits as my time and money have now officially run out.
So if anyone is bored today and wants to lend a hand for an hour or two let me know.
All of the hard work is done, the car is put together, rolls, starts and works. The only thing left to do is figure out why it doesn't run well or drive well. The best way to describe the way it runs is it acts like an intercooler pipe blew off.
It's hard to start, once it warms up fully it idles, but as soon as you give it ANY gas over 10% throttle it acts like the fuel or spark shuts down, basically it just stutters. If I kind of spike the throttle to get the RPMs up to 4-5k I can slip the clutch and get her to move.
On tap for today is:
1.) boost leak test, have to make a boost leak tester because the turbo is UNDER the intake manifold basically.
2.) data logging to see what exactly my car is doing, this is where I'll need help because I know nothing really about tuning.
3.) looking at my FPR, because here's the weird part I can swap the feed/return fuel lines and it runs the exact same, not right.
If none of those things pan out... not sure where to go next as my Evo is now taking priority.
-Shawn
2010 Evo X GSR
1997 Subaru GC8 STi
Old 10-24-2010   #124
mdost03
Sonic Champion!
Drives: VA STI
Sorry to hear Shawn, if I was closer I'd be willing to lend a hand. Hopefully you get it figured out.
Old 10-24-2010   #125
shit man, sorry to hear.
I'll hit you up soon and try to give you a hand.
Old 10-24-2010   #126
cmspaz
Walls need hugs too
cmspaz's Avatar
He no longer needs help, the fix is 2 minutes under the hood.
The problem is acquiring the part.
Stemming from sourcing different components from different cars (Legacy GT motor, STi everything else) a fatal design flaw occurred... it ended up without a fuel pressure regulator. The STi unit is on the fuel rail, but the Legacy one is actually on the return line itself at the strut tower. Having looked at pictures of STi engine bays for guidance, we figured that nothing more than the fuel dampeners went on those lines and left them unimpeded. Oops.
Unfortunately it looks like the part is dealer-only, and being that it has hose hookups at both the outlet AND inlet, nothing from any other car I've seen (or that we looked at at O'Reilly) would work. I suggested cutting off part of a fuel rail with the regulator in order to provide an input tube, but that's in no way, shape, or form ideal.
Originally Posted by Trogdor
Old 10-24-2010   #127
DoughtCom
DoughtCom's Avatar
Drives: Your mom
Well said, Spaz. I still have a major issue with not being able to read/write to the ECU. But it really seems like this should fix my symptoms I'm having with the engine running like shit.
Another note, I found a major issue with the PS valve cover. The seal had a chunk missing from it. So I took the whole thing off and re-sealed it with some red RTV for the time being until I can get a new seal and it seemed to smoothing some things out, that was a major boost/vacuum leak and it holds boost now.
I'll keep you guys in the loop but I'll be sourcing a FPR as a last move this week.
2010 Evo X GSR
1997 Subaru GC8 STi
Old 10-24-2010   #128
Sucky on the evo!!
Its 2300 to replace a fork? Why not just yank the tranny and throw a new fork in and not rebuild anything else?
Hopefully the FPR issue is all whats wrong with the subi!
Old 10-25-2010   #129
awesome to hear its a simple fix, hopefully not too pricey from satan.
Old 10-25-2010   #130
ylimert01
ylimert01's Avatar
Drives: Nissian
iff you need a fuel pressure regulator lmk..sned me a pm and I will fill you in on the details.
F Subarus!!!
-Emily
Old 10-25-2010   #131
DoughtCom
DoughtCom's Avatar
Drives: Your mom
I already bought an AEM Plus your's wouldn't work, I need one that goes inline on the rubber fuel lines which yours bolts to the fuel rail.
This ladies and gentlemen was the missing piece.
I got it installed set the FP to 41PSi for now and drove it on the highway and it works!! I have a few bugs to fix but overall it works.
2010 Evo X GSR
1997 Subaru GC8 STi
Old 10-25-2010   #132
mlomker
*Resting In Peace*
mlomker's Avatar
woot!
Old 10-25-2010   #133
Old 10-25-2010   #134
I love that the maiden voyage is just a casual thing, LOL. That's awesome man, and a really nice little piece you got! Now you have the base to start building your 1000whp fuel system!
Old 10-25-2010   #135
TalonFiero
moonshine power
TalonFiero's Avatar
Drives: 08 Saab 9-7x Aero
Glad to see you got it running good enough to drive! Wish I had half the motivation you do to finsih my project.
BTW,
You should yank that tranny and have DB have it rebuilt or maybe just the shift fork replaced if that's all that's broken.
I just had DB have my VIII 5 speed fixed. It got all new synchros, bearings, a new reverse gear and new TOB for around $800. All on basically a one day turn around too.
Old 10-25-2010   #136
Way to go on your first full swap
Old 10-25-2010   #137
Awesome dude!
Yeah as for the tranny, I've replaced forks on DSM's before. Not sure if evo's are any harder/easier, but if that's all it is you could probably do it.
Old 10-25-2010   #138
DoughtCom
DoughtCom's Avatar
Drives: Your mom
LMAO, actually I was scared shitless and listening for noises. The car made it though!! I just have to fix a few things like have a coolant reservoir and the like Also I need to get an alignment and clean a few things up, but I was really surprised the hood went on without me having any fitment issues or anything. So we're looking good!
2010 Evo X GSR
1997 Subaru GC8 STi
Old 10-25-2010   #139
DoughtCom
DoughtCom's Avatar
Drives: Your mom
Thanks a lot man, it was a hell of an expensive and stressful ride.
Awesome dude!
Yeah I'm just at the end of my line with working on cars for a while. After a solid 2 1/2 months of working on cars and the cold snap about to hit... I think I'm done for a while.
2010 Evo X GSR
1997 Subaru GC8 STi
Old 10-25-2010   #140
19TsiAwd90
2stepadepaaadepaaadep
19TsiAwd90's Avatar
Drives: myself crazy
dont remind me i still gotta get my clutch in lol!!
Originally Posted by 311evo
