Old 02-12-2012   #121
Mark Leasure
Mark Leasure's Avatar
Re: Mark's Evo IX MR Winter Projects
Originally Posted by Pushit2.0 View Post
Its that white one that ran that really low 9/ high 8 at proving grounds.
I need to replace my broken transfer case with 300M gears and see what happens, hopefully all the auto guys don't beat us this year... not for going fast but for the reliability. Haha. I'm still into shifting, but J. bush is doing awesome just mashing the pedal. You going to shoot for 8's this year?
Old 02-13-2012   #122
Hopefully mondale on here can come and run with you 5 spd dudes, almost every platform is going to autos for racing now, word is there should be a pretty quick suby in the mix this year too.
I hope you guys can find the recipe for reliability, 5 spd cars rock.
Old 02-13-2012   #123
Mark Leasure
More cars the better! It sucks when there are 2-3 cars in a class.
Old 02-13-2012   #124
awdxtc
Drives: 90 awd
This car is sick.
awdxtc is offline   Reply With Quote
Old 02-13-2012   #125
santa
Boost Spike
santa's Avatar
Originally Posted by Mark Leasure View Post
I have the non-CDI coil on plug setup. I've seen some posts on EvoM with guys making high 7 and in to the 800WHP dynojet range. It's a weak point, but I'm going to give it a shot! I'm trying not to go absolute overboard unless I'm absolutely sure I need it. I’m still using the AEM twin fire garbage in the 1G, they work great until they fail & never misfired, and you?
Same here twin fire with the coil on plug stuff. But, once the twin fire fails ill goto an m&w box and be done with it. Also waiting on my fuel pump to get back after burning out again. Ill be switching to a wedlen pump probably too.
Old 02-13-2012   #126
v8klla
v8klla's Avatar
I've got a used M&W for sale
Chris Carey, President
Modern Automotive Performance
P: 763-545-3800
E: chris@maperformance.com
Old 02-13-2012   #127
Mark Leasure
What pump are you running? I've actually had good luck with my Fuelab, I think its the 1500HP version.
Old 02-13-2012   #128
Mark Leasure
I'll end up upgrading when it breaks again this summer...Thanks for the heads up, is it out of the RX7? Unfortunitly moneys a little tight these days, well I've spent too much on the winter project. I didn't realize the Evo would turn out to be a full on project.
Old 02-13-2012   #129
Just by simple drag racing math with a 1.5 60' the car will be close to a 8, we will see. The evo looks good.
Old 02-14-2012   #130
Mark Leasure
Thanks!
So are you going to go with some 5 lug hubs and a set of slicks this year? I could see it running high 8's and to recapture the galant record.
Old 02-14-2012   #131
You guys should both run these!
http://forums.evolutionm.net/drag-ra...acemaster.html
Old 02-14-2012   #132
My car will use the BFG comp t/a for the street and have a set of QTP's for track use, if rims are in the budget 5 lugs will be on the car. And I recommend the aeromotive Eliminator fuel pump, in my car its able to produce over 100psi of fuel pressure at battery voltage. And no voltage regulator needed if you are not going on road trips.
Old 02-15-2012   #133
Mark Leasure
Exhaust update:
Finished the exhaust tonight 3" downpipe to 3.5" aluminum with 2 mufflers.
Old 02-16-2012   #134
cmspaz
Walls need hugs too
cmspaz's Avatar
That exhaust is super sexy.
Originally Posted by Trogdor
Old 02-16-2012   #135
nice
Old 02-16-2012   #136
What's left? Just the catch can you were talking about building? Lets hear an idle vid with that aluminum exhaust! Looks awesome man, you sure make some fast progress on these projects
Old 02-17-2012   #137
CornFed2.4
CornFed2.4's Avatar
Drives: You crazy!
Looks like hes charging the battery. Hes gotta be getting close.
Old 02-17-2012   #138
Mark Leasure
Thanks for all the positive feedback! Catch can fab tonight. And yes its getting very close to being finished! This car build was powered by Coors Light....
Old 02-17-2012   #139
Nice work as always! Good eye on the battery charger nick
Old 02-17-2012   #140
This thread makes me wish I knew how to weld!
Great work as always!
