Old 03-27-2009   #141
twack
It was a auto get over it
twack's Avatar
Re: Getting the Laser ready for AutoX
Originally Posted by MustGoFaster View Post
Don't try and run more than 35psi. Those couplers will blow off your GM MAF.
mine hold to 30!!!!, god im lazy
Old 03-28-2009   #142
wants to be sideways...
123abc's Avatar
Drives: Loud cars
PVC emits a caustic chlorine gas when heated; you may want to switch to either metal or ABS plastic.
Really? I love my intake. lol I'll probably do something else with it eventually.
If that car sees more than 35 psi, I probably won't be the owner. lol
Originally Posted by Matt D.
Originally Posted by 93GSX5SD
Old 03-29-2009   #143
123abc's Avatar
Drives: Loud cars
I put about 15 bucks worth in the gas tank and so far zero gas leaks. My lower radiator hose gave up the ghost though. Must've gotten bumped or something but now theres a good sized slice in it. It was so old anyways, the rubber was half melting.
I'll replace that today and I'm also getting the bung welded in so I can finally use my nice shiny wideband. From what I drove around yesterday it seems to run decent. Just drove it to get gas and then back.
Old 03-29-2009   #144
twack
twack's Avatar
Word of advise, if one hose blows, the rest are not far behind. Do them all at once and you will have no worries. I decided to wait and fix them one by one. They all went within 2 months what a pain in the ass
Old 03-29-2009   #145
123abc's Avatar
Drives: Loud cars
Whoever had the car before me replaced the upper radiator hose but obviously neglected the lower. I finally found one that a parts store had in stock but it's for a 1.8. I made it work though, it wasn't too far off.
So far so good. No leaks and I've been driving it around for a little while now. Best of all though, NO FUEL CUT!! :-D
Old 03-29-2009   #146
twack
twack's Avatar
I ment re[place ALL of your coolant hoses. Each and every one
Old 04-02-2009   #147
123abc's Avatar
Drives: Loud cars
I did that last spring.
Had the alternator rebuilt due to it leaving me on the side of the highway. Threw it in and I'm happy to say it runs great. Very rich though. Gets down to 10 by 6500. Need to tune it since its still on the base adjustment for 560's on my Translator.
But right now I's happy.
Old 04-06-2009   #148
123abc's Avatar
Drives: Loud cars
Took a couple pics tonight and a video.
Here's the video. 20-135
http://www.youtube.com/watch?v=kKeweSBkLCk
Here's some more pics I took. Show off my shack of a garage. They didn't run electricity out to these things, so I got my own extension cord and run it off our deck.
Here's a shot of the interior. Notice how clean it is (needs a vaccum) and the repaired lower door panels. For those who remember, there were like 4 speaker holes. I took it into work a week or 2 ago and cleaned it up pretty good. I scrubbed the shit out of the carpet and then shampoo'd it. Looks dirty right now, but thats from all the dirt being lifted out and of course I have been daily driving it.
This is what it looked like when I first got it:
You can't see it in the pic above, but I mounted my AEM UEGO inside the stock gauge cluster where the stock oil pressure gauge was. Front and center.
Old 04-08-2009   #149
123abc's Avatar
Drives: Loud cars
So I think my clutch is fucked. I have fluid and my lines aren't leaking. My clutch won't disengage.
Old 04-08-2009   #150
Did you try adjusting the pedal? Can you see the slave rod moving at all?
Old 04-08-2009   #151
123abc's Avatar
Drives: Loud cars
I highly doubt its the pedal, it was working fine up untill I was on my way back to work today from my lunch break. Going down a hill and notice I couldn't get it into gear. So I had to drive it back to work then back home with the clutch always engaged.
I inspected the lines, including the ss line I have for it, and there's no leaks. Fluid level is full. Got down and tried wiggling the fork, seems solid to me. My guess is the pressure plate is done.
Old 04-08-2009   #152
MustGoFaster
MustGoFaster's Avatar
Drives: A big dirty V8
My bet is a spring broke out of the disc and is wedged on a PP fin.
Old 04-09-2009   #153
123abc's Avatar
Drives: Loud cars
Thats the exact thing that happened to me about 2 years ago or so. It was then that I decided to have Mr. Vogel rebuild my engine.
I'm trying to look at this as a positive thing. I can now take the time to pull the pan off, the vc off, and many other things to fix the many oil leaks. Do a compression test, etc.
Last time I did a compression test I don't think any of the cylinders were over 130.
Old 04-09-2009   #154
Sounds like this is probably your issue.
Old 04-09-2009   #155
123abc's Avatar
Drives: Loud cars
Since I'm more than likely going to need a clutch, I'm stuck between two transmissions. I have a nt tranny with shorter gear ratios and a turbo tranny with longer ones. I have heard the nt transmission is a bit weaker, but the idea of shorter gears makes me lean that way. Thing is, depending on which tranny I use, I'll need a different clutch for each. The bellhousing on the nt is smaller, therefor needing a smaller clutch.
Old 04-09-2009   #156
twack
twack's Avatar
seriously, 130? what are all the numbers. is your tester reading low? i would think you would have better numbers. iwould stick with the turbo tranny, its treating you good. if it ever fails toss in the nt. now rip that trannsmission off, and get to work, ill get down when ican. didnt that happen to your last clutch, i thought it did when i saw it out
Old 04-09-2009   #157
I would also stick with the turbo tranny. The gears aren't really that tall, and you'll still be able to wind out first and second in no time flat.
Old 04-09-2009   #158
carltalon
carltalon's Avatar
Drives: 98 Eclipse GSX Auto
I'd check the Master and slave cylinders before pulling the tranny.
11.35 @ 120mph
Old 04-09-2009   #159
123abc's Avatar
Drives: Loud cars
Oh yes, I will. I need someone to help pump the pedal while I watch it. I've been busy so I haven't gotten out there.
Old 04-11-2009   #160
123abc's Avatar
Drives: Loud cars
Everything that I can see from the outside looks fine. I looked inside the tranny behind the dust boot over the fork and can't really see much. So I started taking my tires off up front and broke my 3/8 ratchet. lol Need to get my dad's 1/2 inch drive set.
I did however pull the exhaust side off the motor. I can already see a lot of the oil leakage is from the valve cover and some from the middle exhaust stud that has an oil passage behind it.
I have a wedding to go to today at 1 but when I get back I'll get out there and get some pics and get dirty.
