Old 09-12-2018   #1
Deathgrim66623
Drives: 95 eagle talon tsi
Built 95 talon tsi 13,500 obo.
for sale is a 1995 eagle talon with a built engine and transmission and suspension. i have easily over 20,000 put into the car i just do not have any more time to put into the car and have other responsibility that take precedence. the car: built 6 bolt engine (bored 30 over) wiseco rods and pistons, and kiggly racing lower block girdle, had the whole engine and head decked and line bored to be true as possible engine was just broken in. head has 727 cams, 5 angle valve job, over sized valves, beehive springs, 3g lightweight lifters, and lightweight retainers. aftermarket fuel injectors 1200cc, aftermarket fuel rail, new 6an fuel lines all the way to the pump, aeromotive fuel regulator and hi flow filter, duel walbaro 255 fuel pump setup, aftermarket intake with velocity stack runners, larger than stock throttle body (i think its a 62mm), aftermarket exhaust manifold, custom straight pipe exhaust with hiflow 2 port muffler(sounds awesome does not sound like a fart can!), custom inter cooler piping with 4in wide inter cooler, hks (old loud style), tial 38mm waste gate coolant cooled style, holset hx40 turbo with bep houseing for fast spool up and custom billet cold side to take a 78mm wicked wheel to provide more boost and a higher volume of air quicker, 8lb fidanza lightweight flywheel, southbend heavy hybrid clutch, everything on the engine is arp bolts or studs, custom coolant over flow, weapon r foam filter, hid lights and porjector style lenses, eco like v3 for tuning, custom paint job (it's not a wrap or vinal), 18x8 Enkies, brembo brakes and rotors, Tokyo iluima 5 way adjustable high performance shocks, ebaitch performance springs, performance sway bars front and rear, stm mini battery kit with Optima small battery and Optima large 1400cca high performance battries, aftermarket door speakers and amps, innovative l2 wideband, beltronix laser and radar detector with shifter packs bumper and in dash mounted detector (2000$when purchased), 4.4 bar map sensor, 800gal/min maf sensor (for precise tuneing), built stage 3 transmission from jack transmission with quafe life lsd with helical cut gears and center welded dif, engine mounts are solid in front and rear and poly on the sides, engine cradle and drive line carrier bushings are all solid aluminum and have the solid bushings for rear cradle and rear differential, also have a clutch style lsd differential for the rear (needs to be installed). Boost pressure gauge and air fuel gauge need to be installed, large seconed battery and interior need to be installed. Extreamly minimal signs of rust a no rust on the shock pillars car has been stored inside or on concrete pad. I'm shure I'm forgetting some parts if you want a fun and fast car that will turn heads look no further!
Current set up should be 800hp to the flywheel was told the engine and trans would handle it no proable from the engine and transmission builders. Also has nice car cover. E-mail or text
ID:	17231   Click image for larger version
ID:	17232   Click image for larger version
ID:	17234   Click image for larger version
ID:	17235   Click image for larger version
Deathgrim66623 is offline   Reply With Quote
Old 09-12-2018   #2
DSMINMN
Mitsus for days!
DSMINMN's Avatar
Drives: '08 Chrysler 300C
Re: Built 95 talon tsi 13,500 obo.
God bless.
Old 09-16-2018   #3
Alpha D
Got Boost o_O'' m
Alpha D's Avatar
^ lol and he strikes again.
Old 09-20-2018   #4
DSMINMN
Mitsus for days!
DSMINMN's Avatar
Caught me..? Lmfao
Copyright ©2000 - 2024, Jelsoft Enterprises Ltd.
