Old 11-04-2003   #1
Alpine TSi
Banana Hammock!
Alpine TSi's Avatar
Drives: Shitbox
Does anyone know of a way to log boost on a 1G without an EMS? I have a TMO Datalogger and was curious if this could be done, like with 2G's with DSMLink and swapping out the MAP sensor. Maybe I should just do a DSMLink swap..!!
1992 Eagle Talon TSi AWD
320awhp/320lb-ft tq
12.772 @ 108.57
1992 Mitsubishi Galant VR-4
678/1000
Old 11-05-2003   #2
john
Business as usual
john's Avatar
I dont think you can with TMO datalogger software. I dont know how atleast. Would be nice though. You have alot more to do before thinking about swapping to dsmlink. When I am logging, I watch the boost gauge the whole time to see if it spikes, falls off, or whatever. I have someone else watch the logger to see if I am knocking or not. If I start knocking around 10 counts, I shut it down. This is when I am tuning though. -John
97 Viper GTS
Old 11-05-2003   #3
Yes you can. You need at least a 3 bar map sensor, 4 bar if you are going over 29 psi. You use the EGR input of the TMO and use these settings as a guideline. I've been planning to get it set up with my pocketlogger but haven't gotten around to it yet.
Name = Boost
Offset = -15
Slope = 9
Units = psi
Precision = 1
Minimum = -15
Maximum = 30
Old 11-05-2003   #4
Alpine TSi
Banana Hammock!
Alpine TSi's Avatar
Drives: Shitbox
Where do I get the sensor and what would be the diff in price between a 3 bar and 4 bar? And also how would I set it up on the car(sorry for the stupid questions, not all of us have the experience you do Steve )
Thanks
320awhp/320lb-ft tq
12.772 @ 108.57
678/1000
Old 11-05-2003   #5
You can do this on the PDA pocketlogger program? or just the other one?
Old 11-06-2003   #6
The map sensors are pretty common, my VPC comes with a 3 bar(2 bar positive pressure, 1 bar vacuum). GM makes a 4 bar sensor, not sure what the part number is, best off to do a google search. They should be under $100 new, much cheaper used.
I know the same thing can be done with a pocketlogger program provided you can write your own parameters for a separate input. I had the info for the MMCD software, but haven't seen it yet for the pocketlogger software.
*edit* I'm sure you won't be going over 29 psi, so here's the GM part number for the 3-bar sensor. It was used on the 89 Turbo TA. part #12223861, retails for $51 on www.gmpartsdirect.com
Old 11-06-2003   #7
I will vouch for GMPartsDirect.com. I've ordered misc. parts from them before and they were received as expected, although if I remember correctly I forgot about my order before I got the parts... Slow shipping?
Old 11-06-2003   #8
LightningGSX
Hellbound
Name = Boost
Offset = -15
Slope = 9
Units = psi
Precision = 1
Minimum = -15
Maximum = 30
Wouldn't you want the offset to be -14.5?
-Nulli Secundus-
Old 11-06-2003   #9
Alpine TSi
Banana Hammock!
Alpine TSi's Avatar
Drives: Shitbox
Another stupid question now, where does the MAP Sensor go? And how does it plug in. Also where do I enter that stuff into the TMO logger?
I hate to sound stupid, but someone here has to.
320awhp/320lb-ft tq
12.772 @ 108.57
678/1000
Old 11-06-2003   #10
LightningGSX
Hellbound
Motorola makes a 6 bar map sensor for around $20.
-Nulli Secundus-
