Old 08-23-2013   #1
97gsexx
97gsexx's Avatar
Drives: 97 talon
Pressure plate/flywheel gap
Hey guys, just wanted to verify something before I put the tranny on tonight. I have read that there should be no gap where the pp bolts to the flywheel. I torqued all the bolts to 14 ft/lbs in a star pattern and yet I still have a slight gap.
I have read that if the pp isn't fully seated against the flywheel, you will not get an accurate torque measurement because you're fighting the actual sprung tension of the pressure plate. I didn't have a chance to work on it last night but as of now, this is how it sits with all bolts torqued to 14 ft/lbs:
[IMG][/IMG]
I don't want to torque the bolts too tight considering they're already torqued to spec. I just want to do it right so I can make it to the cookout!
97 gsx (sold)
97 talon tsi awd 🐼
Old 08-23-2013   #2
Re: Pressure plate/flywheel gap
Crank 'er down! It has to be fully seated to work properly. It's possible the heavier ACT pressure plate clamping force is throwing off the factory torque spec.
Kracka is online now   Reply With Quote
Old 08-23-2013   #3
97gsexx
97gsexx's Avatar
Drives: 97 talon
Ok cool, thanks a lot! That's what I thought, I just wanted to make sure before I put her back together. Note that it is a act 2900 pp with 1200 miles/new act street disc/streetlite flywheel with 5,000 miles.
Perhaps the heavy duty pp and thickness of the new disc is contributing to the reason it's requiring more force then the factory torque spec to seat against the flywheel.
97 gsx (sold)
97 talon tsi awd 🐼
Old 08-23-2013   #4
Definitely, good luck!
Old 08-23-2013   #5
97gsexx
97gsexx's Avatar
Drives: 97 talon
Thanks! Definitely pulling an all nighter so I have the whole day tomorrow to tweak some things and get her ready for Sunday.
97 gsx (sold)
97 talon tsi awd 🐼
Old 08-23-2013   #6
mark4g63t
mark4g63t's Avatar
Drives: 95 Talon TSI
Don't get "distracted" tonight
BW8776, e-85
Old 08-23-2013   #7
97gsexx
97gsexx's Avatar
Drives: 97 talon
:P
97 gsx (sold)
97 talon tsi awd 🐼
Old 08-24-2013   #8
If distracted means drunk, fuck that. Do it up!
Old 08-24-2013   #9
mark4g63t
mark4g63t's Avatar
No, distracted by his wiener...
Anyways tranny is in and should be running by tonight.
BW8776, e-85
Old 08-24-2013   #10
97gsexx
97gsexx's Avatar
Drives: 97 talon
Tranny is in, should have it running tonight!
97 gsx (sold)
97 talon tsi awd 🐼
Old 08-25-2013   #11
Lmao
Old 08-25-2013   #12
97gsexx
97gsexx's Avatar
Drives: 97 talon
No cookout for me .... Alarm didn't go off and I am now just starting to work on her. All I have to do is put gear oil in tranny/t-case, intercooler piping, timing, and a few other little things. If I finish soon I might head up but I about 40 minutes away from Rogers so idk
97 gsx (sold)
97 talon tsi awd 🐼
