Old 06-07-2014   #1
dogwhistle
dogwhistle's Avatar
Rear 2g brakes
So I am pretty set on going with RTM racing's VR4 brake upgrade for the front using 13" rotors and such. I will also hopefully be triming my fenders and running 17x9 wheels with a 25 or so offset with some flares to keep stuff covered. My question in, can I keep the proportion of braking on the rear brakes by moving my AWD front calipers and rotors, to the rear or is that not possible? I realize some people use VR4 single piston rears as they are larger too and can keep an emergency brake. They seem hard to find though.
-Adam
aneujahr@maperformance.com
Old 06-08-2014   #2
Re: Rear 2g brakes
Just get brembos for the rear.
Look for +28 or +30 they will sit in side the car. That is why I traded off my 17x9 +25 rims for a set of bbs evo mr's. It got tired of the cutting the tires and always rubbing even rolled and a bit of a pull and a lot of camber.
Old 06-08-2014   #3
dogwhistle
dogwhistle's Avatar
Re: Rear 2g brakes
Thanks for the heads up on the wheel offset man! I will definitely keep that in mind when I get them. What size tires would work with a 17x9 +28 and still be nice and wide without rubbing? I don't wanna roll if I don't have to cause that means trimming carbon up front...
And I'll check out the Brembos, hopefully I can score a decent deal on all 4 brakes instead of two different sets that add up.
-Adam
Old 06-08-2014   #4
Re: Rear 2g brakes
I had 235/45/17 on them since they came on it.
Old 06-08-2014   #5
dogwhistle
dogwhistle's Avatar
Re: Rear 2g brakes
Hm would any wider be better or just be too rolly polly on the side wall?
-Adam
Old 06-08-2014   #6
Re: Rear 2g brakes
245/40
