Old 04-14-2013   #1
cliford_thefast_redcar
Drives: 95 gsx
starting issue
so my car you have to turn the key multiple times to start... some times it takes more time to start... before it starts the car wont even crank over.. when i was replacing the cranks sensor for my no spark it would crank every time while we were trying to diagnos the no spark and and we fixed that it started doing the starting issue again...and ideas?
cliford_thefast_redcar is offline   Reply With Quote
Old 04-14-2013   #2
4seasons69
4seasons69's Avatar
Re: starting issue
So it doesn't turn over? Does the solenoid on the starter click when you try and crank it?
Old 04-14-2013   #3
LingLing
AznKraut
LingLing's Avatar
Re: starting issue
Does it sputter? Might be a fuel pressure regulator.
EDIT* Oops. read too fast. Disregard my post.
Old 04-14-2013   #4
Drives: 95 gsx
Re: starting issue
it usualy does click im thinking maybe a conection problem on the starter
Old 04-14-2013   #5
4seasons69
4seasons69's Avatar
Re: starting issue
If it clicks and won't turn over its most likely the starter. I would probably just replace the starter
Old 04-14-2013   #6
Drives: 95 gsx
Re: starting issue
it does start just have to keep turning the key but some times it takes awhile
Old 04-14-2013   #7
4seasons69
4seasons69's Avatar
Re: starting issue
Ya that's common with starters when they're on their way out. You turn the key, click. Turn the key, click. Turn the key click. Turn the key and it starts. Eventually it just won't start at all.
Old 04-14-2013   #8
dsmghost
dsmghost's Avatar
Drives: 1gb Talon TSi AWD
Re: starting issue
^ yes very common. I've had 4 starters in my 1g over the past 9 months. They all did that same thing intermittently. You could test voltage drop at the starter solenoid when the issue is happening. You should go buy a new starter that has a warranty. I already need a new one, everyday I have to turn the key like 20 times before it will crank, not every time though.
Old 04-14-2013   #9
Drives: 95 gsx
Re: starting issue
sounds like the same problem so i guess i will start with that thanks
Old 04-16-2013   #10
dsmolition
chemist
dsmolition's Avatar
Drives: RR Evo 8
Re: starting issue
Also, check your signal wire at your ecu and the starter, check continuity, your starter grounds. I would do so before buying a new starter and having the same problem. Cough cough 4 starters and has the same problem…
dsmolition is offline   Reply With Quote
Old 04-17-2013   #11
Drives: 95 gsx
Re: starting issue
ok will do
