Old 09-03-2010   #61
Re: Official MitsuStyle Timeslips Thread
Originally Posted by CarPsyco84 View Post
Did you ride in it? I don't even remember anymore. Either way its the only white dsm I've ever had.
That must be the one then haha, yea, you brought me for a rip in it when I took the non-ABS lines out of your old FWD.
Old 09-06-2010   #62
CarPsyco84
CarPsyco84's Avatar
Oh, thought I had it all apart when you were over, guess not. Usually its broken its a surprise when it works.
-When in doubt, Moar RPM.
Old 09-06-2010   #63
santa
Boost Spike
santa's Avatar
10.4@141
1.6 60ft
blizzak snow tires
E85 5speed
Might get some times out of it with the auto in it this year... might!!
Old 03-30-2011   #64
bryce_
bryce_'s Avatar
Drives: Evolution IX
i wanna break 11s this year!
FpGreen Powered. Stock motor E85
11.4
1.7 60ft
119mph
bryce_ is offline   Reply With Quote
Old 03-30-2011   #65
I am in the right lane car #1219
10.06@148mph
1.8 60'
2nd pass on the new setup. Cracked the #2 cylinder wall 2 weeks later in Iowa. This was run on E85, 38psi, 650awhp, and 2450lbs w/out driver.
More to come this year, I hope.
Old 03-30-2011   #66
oops
Old 07-09-2011   #67
badinblack
badinblack's Avatar
Drives: 96 talon, 2.4L & 3582r
Wink Re: Official MitsuStyle Timeslips Thread
10.06@148mph
1.8 60'
isn't it time for an update?
badinblack is offline   Reply With Quote
Old 12-03-2011   #68
I done forgot...
1/4 9.45@156.9mph
1/8 6.3@122mph
60' 1.75
Ya next year I might have slicks and leave the line with power. This run was a blistering 1.75 short time slip launch from 7000rpm. Not much for traction hit rev limiter 4 time until it was up to speed in 1sr gear. Crossing the stripe at 9800rpm in 4th gear.
I had a fun and long weekend up at the MAP proving grounds, my car number was 1616.
We made 2 runs on saturday. The first run was just to see what the boost was at, look at the log, and see if the new tranny parts were happy shifting at almost 10,000rpm.
So we cooled the water to air down with 15lbs of ice, lowered the tire pressure from 28psi to 26psi, upped the boost a little, and I raised my slip launch rpm up to 6000rpm.
The track had good traction and the IAT started at 65deg F and at the end of the run were up to 100deg, boost was about 37.5 psi, but here is the time slip:
60' 1.755
330' 4.435
1/8th 6.469
MPH 120.54
1000 8.198
1/4 9.651
MPH 154.16
http://www.youtube.com/watch?v=dSTJozf3y_Q&hd=1
The log looked good, no knock retard, good clean shifts, there was more in it at the line, the track was still gripping hard, so back to it to try again.
The 3rd run we upped the boost again, we were looking for around 40psi, we lowered the tire pressure to 24psi and I was going to up my slip launch to 7000rpm.
But the oil filter vibrated loose in the burn out box, the track offical was walking up to my door to tell me not to run it was leaking oil, I was like WTF hit the PUSH OFF button and kill the car if its leaking oil all over the track.
Well I launched with the guy at my door I guess and it went straight to revlimiter, so I shifting into 2nd thinking I would just drive slow the rest of the track and then the oil light and the oil pressure gauge showed the worst. I shut everything off and found the puddle of oil on the ground.
At first I was debating just heading home but thanks to Chris I stayed the night and had a great time.
Then in the AM I pulled the oil filter off and put the oring back in place and put the filter back on tight. filled the motor with the 2 quarts I had and 3 from Chris, again thanks.
The car was running good, no bad motor noise. It was cooler out side this morning and it did rain at some point. So I figured traction would be a little less then yesterday.
I made it up to the line and slip launched from 7000rpm, the car spun but was moving forward good, hit 2nd and it just took off. The log later showed the car made every bit of 41psi, air temps were around 100deg because I did not have ice in the heat exchanger, no knock retard, I hit every gear around 9800rpm and it felt like a great pass.
The end result is the fastest and quickest Galant VR4 in the world, that I know of right now anyways.
60' 1.745
330' 4.318
1/8th 6.305
MPH 122.42
1000 8.021
1/4 9.457
MPH 156.94
http://www.youtube.com/watch?v=pHyu1h6xs9Y&hd=1&hd=1
http://www.youtube.com/watch?v=MLS0OoyPU7g&hd=1
http://www.youtube.com/watch?v=pJuieuVoiT4&NR&hd=1
So if I had the track temp of yesterday and the air temp/boost of the run this morning it could have run quicker, but I was happy both days.
And a first for the car going to the track in the last 2 years, I drove in onto and off the trailer back into my garage when I got home, such a good feeling.
We did have a Gopro in the front window for this run, that should be fun to watch later, and Thanks Mark for getting the great HD video at the line.
I would also like to Thank EVERYONE that helped make the car what it is today. Just to name a fewin no specific order: Ryan, Kyle, Josh, Alison, Shane at DB, CP pistons, Carrillo rods, Karl Ramm
KRAMM-LOX, Chuck from HTM, Paul, Dukes, Jacks trans, MAP, Monster, Budlight, plasma cutters, and every one else I can not think of off the top of my head.
I will update with pics as I get them off my camera, and I will edit in links to the videos as they show up on the face tubes.
Old 12-03-2011   #69
munchgsx
munchgsx's Avatar
Drives: 2004 Corvette M6 F45
Hmm didn't know this existed. I'm 747. Still need to figure out how to get it out of the hole. Should have things ironed out by spring. Hoping for a 10.90ish pass in the spring.
Time Slip:
Video:
http://www.youtube.com/watch?v=5XXncZHC1Xw&hd=1
Wife's first video video at the track. Please excuse her.
Converted to LS
Old 12-03-2011   #70
^Nice man! Is your car an auto?
Old 06-25-2013   #71
Polarisamsoil
Drives: 1990 tsi and 1996 gst spyder
12.894
1.81 60ft
Smoked clutch
And bad 4th gear
16g on corn
Will come to pg2013.2 much faster I hope
Polarisamsoil is offline   Reply With Quote
Old 06-25-2013   #72
dsmreck
dsmreck's Avatar
Drives: 98 gsx
13.35 117
2.73 60ft
granny shifting
the black 1g went 14.0 next to me. he beat me in time until 1000 ft
Old 06-26-2013   #73
The only time of year this thread seems to be accepted to be posted in.
