Old 08-14-2008   #1
twack
It was a auto get over it
twack's Avatar
Electronic humming from alternator
I did the saturn alternator swap and have been driving on it for a few days now. Last night i was doing some things and i heard this really faint humming/whine from the alt when the car is OFF. it is always there and is definatly coming from the alt. What is going on? This is with the car off. No codes thrown.
Old 08-14-2008   #2
HiImBrian
HiImBrian's Avatar
Drives: the girls crazy
Re: Electronic humming from alternator
I swapped a motor on a beetle a while back and after everything was done and set there was a humming I thought was from the alternator. Turns out it was just the water pump. If it's not that, I'd double check your wires.
pics or gtfo
Old 08-14-2008   #3
twack
twack's Avatar
This is with the engine OFF not on. Also if i unplug the alt plug it stops
Old 08-14-2008   #4
Febo
Manic Narcissistic
Febo's Avatar
Drives: IS300
bad altenator?
Old 08-14-2008   #5
HiImBrian
HiImBrian's Avatar
ok, if you unplug the alt and it stops that's what it has to be. But, my issue was the same as far as the car being completely off.
pics or gtfo
Old 08-14-2008   #6
twack
twack's Avatar
It does charge
Old 08-14-2008   #7
Sounds very odd. Might be worth getting that alternator tested (or just replace it).
Old 08-14-2008   #8
twack
twack's Avatar
Ok well i just talked to the guy who made the original write up on this swap and he wrote me:
"The power wire needs to be changed to a switched 12V source."
Old 08-14-2008   #9
4g63tcrazy
is Nashty
4g63tcrazy's Avatar
Drives: Cyborg from Japan
So it's gotta turn on with the key?
-1990 Mitsubishi Cyborg 4WD-
Old 08-14-2008   #10
Febo
Manic Narcissistic
Febo's Avatar
Drives: IS300
easy, just put a relay on the 12v line. Done and done.
Old 08-14-2008   #11
4g63tcrazy
is Nashty
4g63tcrazy's Avatar
You sir are very correct.
Old 08-15-2008   #12
twack
twack's Avatar
so there is a thick wire, and a plug with 2 wires out of it. which one do i have to do this to
Old 08-15-2008   #13
Febo
Manic Narcissistic
Febo's Avatar
Drives: IS300
I might be wrong, but Im going to guess you want to find the + source of one of those two wires. The thick one should be the power out for the Alt. and the plug should be the power in wires.
