Old 07-02-2014   #881
Re: Big Brown's Automagic - The last episode in my DSM story.
Nice!
Old 07-02-2014   #882
Hellz yeah dude, so happy for ya!
Now I'm just going to leave these here for you to think about,
http://m.youtube.com/watch?v=CjSquZ5JGVI
http://m.youtube.com/watch?v=vRKWIpXScPE
Old 07-03-2014   #883
Transmission out again on 7/1/14:
New vs old spacer plate:
Note the drilled bolt holes in the old and it doesn't sit flat anymore.
Old crank bushing vs. new
Old one has a bit of rapesauce on it.
Trans back in 7/3/14:
Car is on the ground, I just need to get it tuned and do some small stuff to it at this point.
Old 07-04-2014   #884
evotuner
evotuner's Avatar
Drives: 2004 Evo 8
Badass dude, going to make it to PG.2?
2006 WW IX RS 396/404 - SOLD
Old 07-04-2014   #885
Holy sheyitt! Get on the tuning that's when the bugs really crop up...
Old 07-05-2014   #886
I was thinking about that last night. I need to see if I fit into a class that I will be competitive with. I have a 5857.
Yeah, still working out the bugs, fixed some major oil leaks, still need to install my oil psi gauge, fix a small trans leak, blah blah blah.
Car is set to 28psi and will stay there this year. Carl thought it was "meh".
Old 07-05-2014   #887
carltalon
carltalon's Avatar
Drives: 98 Eclipse GSX Auto
It felt meh till we were next to that truck. It's going to be a beast when you add more timing and boost.
11.35 @ 120mph
Old 07-05-2014   #888
URV8SUX
URV8SUX's Avatar
Can't be competitive unless you show up!
Old 07-06-2014   #890
True that. My pto is low and with the baby coming I will need it.
Originally Posted by blackrosenova400 View Post
What is your timing curve at?
10* I think. I haven't looked at it. I'll start tuning this week.
Old 07-06-2014   #891
blackrosenova400
blackrosenova400's Avatar
That is pretty conservative, Im at 16deg top at 40 psi, but thats with a 20g.
20g Mafia
Old 07-06-2014   #892
carltalon
carltalon's Avatar
9* actually. I'm assuming Nick set up a super safe timing map to use while getting A/F dialed in. 16* is a little scary for 40 psi
11.35 @ 120mph
Old 07-06-2014   #893
blackrosenova400
I admit it does seem high but I have 190 log files and myself telling me its what it wants lol. I am on stock Auto cams and a cyclone intake. It loses steam up top and obviously would want more timing. I could probably back it down a bit. Probably wont make a differance and would be safer.
20g Mafia
Old 07-06-2014   #894
evotuner
evotuner's Avatar
Drives: 2004 Evo 8
Wish I knew what the fuck I was looking at
Old 07-06-2014   #895
blackrosenova400
Top is logged boost, bottom is timing table. If Aarons car felt fast before, hold on to the oh shit handles after he gets it tuned!
Aaron, a word of caution. Please please make sure your driveline carrier bushings, u-joints,motor mount bushings, suspension bushings are in good order. Ive witnessed some carnage wheel hop can cause and its not pretty lol.
20g Mafia
Old 07-06-2014   #896
tehehodi
Braaaaaaaap!
tehehodi's Avatar
Drives: '09 Silveraydo
Edit: chad explained. I was a little off. Wish I could help ya Aaron. Been busy this weekend.
Old 07-07-2014   #897
Thanks for sharing. I really haven't had time to tune it.
Chad, all of those things have been replaced for the most part.
I really need to get a new pass. side axle, I'm still losing a good amount of trans fluid.
Also need to hook up my vacuum pump and shift box before powercruise this weekend.
Old 07-07-2014   #898
blackrosenova400
We definatly need pics of the vaccum pump install. Something I need to do.
20g Mafia
Old 07-07-2014   #899
7/3/14:
So I was all happy that my car doesn't make the horrendous sound, got the car on the ground was ready to drive it around thursday night (7/3) had talk of racing at grove creek the next day, well my oil pan decided it wanted to not be nice.
I had a friend stop by and I was letting the car warm up while I showed him around, came back outside to about a softball sized oil puddle.
Couldn't see what was in the way with the exhaust in the way and the T-case, so I took those off, found a gap between 2 bolts where it was leaking, tried to cheat and hammer it closed, well it would just squirt oil out every time I hit it.
So I pulled it off.
Well I don't usually stay up late, but it was nice to feel accomplished for having the car together when I said I would so I attempted to fix the oil leak coming from the timing belt side of the motor (Thanks Tyler? i think that was your name for posting this fix originally):
RTV'd that crap and left it overnight.
7/4/14:
No more oil leaks!!! yay!!
However I do have badly leaking pass side axle not sealing in the trans, the oil one did just fine.
Oh well, i went for a drive around the block and it got a bit worrying since it started running on 3 cylinders, just a plug wire having some fun.
I left the bumper off because I tried to install a quick release bumper kit and it certainly didn't fit like it should so yeah. I will have to revisit that sometime in the future.
Well I wanted to drive it to dinner, so I got it on using the front part of the quick release kit and using bolts in the fender locations, works really well actually.
Came back home and we had a bonfire, but I really wanted to wash the car quick because it hasn't in about 3 years.
It was terribly dirty, just spraying water on it, it would turn brown as it fell to the ground. I discovered that the hood is starting to grow surface rust on the paint from sitting too. oh well. I also learned that the car looks like a giant POS, between all the paint chips, dents, dings, scrapes, missing paint, spider cracking, missing body panels and of course the middle spoiler piece that makes it look like a bald old man.
All clean (you can see the unused Dzus fasteners on the bumper here):
Yes, while not that impressive the car had 0 shine to it prior to this. I did this in about 10 minutes before it got dark and I made my 1st s'mores ever.
7/5/14:
Feeling pretty confident about getting my car running, I picked up this:
It will be for sale once I get it cleaned up a bit, but its 100% stock and has sat since 2001.
Thanks Carl/Carltalon (Official DSM Tow man) and Phil/Quigs
Back on topic, so talking about the spoiler some more with Carl he told me that he welded a contraption to hold a spoiler on one of his old 1GA cars, now I knew what I was going to do, but I'm seriously not 100% in my ability to weld however my desire to not drive around POS looking car was more that my lack of confidence so I did this:
Some scrap metal i had for welding practice:
New mounting tabs:
How tabs will be placed in spoiler:
Finished tab 1:
Finished tab 2:
New mounting tabs installed:
Finished product, hopefully someone notices how clean it is:
here is a pic of how it has been for about 2-3 years:
Currently it's inside with no pass. side axle, I have the warrantied axle in my DD.
I'll throw it in tomorrow, then I will wire the cooling fans to a switch inside the car (temp.), wire up my color shift box, and wire up my vacuum pump. I'll be happy to get the axle in and have no leaks, all the others will be a bonus to be honest.
Old 07-07-2014   #900
Speedfreak
Drives: four tires
Is that laser awd for fwd?
NSX - S480/Built motor
GSX - 571whp/490wtq
Sienna
