Old 01-11-2013   #1
Swanny
Swanny's Avatar
Drives: 2G Talon
Feeler: Part out: 95 Eagle Talon Tsi
Hello. The time has come, I've waited a long time to sell this car. I'm seeing who is interested in what parts, will it be worth it? how fast will the car parts sell? are their any possible trades for parts? etc...
Let me know what you guys are interested in, If i have a buyer for the Motor and Transmission right away I may start taking the car apart this weekend! We are looking for a winter vehicle! The car is currently running and driving so any videos of the motor running or anything can be had.
Information on the car can be found here:
http://mitsustyle.com/forums/showthread.php?t=30741
Thank you
Swanny is offline   Reply With Quote
Old 01-11-2013   #2
Swanny
Swanny's Avatar
Drives: 2G Talon
Re: Feeler: Part out: 95 Eagle Talon Tsi
Maintenance/Parts/Upgrades:
-Engine-
170,000 on the body.
6 bolt swap/ 7 bolt head combo installed @ 162,070 miles currently with 35,000 miles on the motor and going up
2G exhaust manifold port matched for Big 16G turbo and matching gasket.
Big 16G with 2G o2 housing & 1G oil return line @ 11PSI
New ITM front case and gasket
VR Speed 16G J-pipe.
Stock OEM 450cc injectors and fuel pump combo.
Braided high pressure oil feed plumped to oil filter housing.
New 3G revised lifters. (smooth motor)
ACL racing rod bearings.
New comedic head gaskets.
ARP head studs torque to specifications.
New FIC injectors seal kit.
New Dura last Battery, 800CCA
K&N Air filter
New coolant temp sensor
1G blow-off valve.
Newer Alternator
True 2.5" HKS exhaust with test pipe bolted to a 3" muffler, stock downpipe.
New Bosch front bank 02 sensor.
New spark plugs, NGK iridium 3764 gapped .028.
New Goodyear belts
New OEM timing belt, water pump and accessories.
MAP EGR block-off plate.
-Transmission/Suspension-
Stock transmission
KYB fronts & GR-2 rear struts with Eibach springs dropped 1.3" (rears not installed).
New synchromesh Pennzoil transmission fluid.
New OEM clutch.
8LB Fidanza flywheel locally bought (no receipt).
New OEM slave cylinder.
New OEM lateral control arm with ball joints, passenger & driver side. (warranties)
New OEM axles, passenger & driver side (warranties)
NEW OEM tie rods, passenger and driver side (warranties)
Alignment done at Tires Plus with specifications graph still on hand (might need another one)
BRAND NEW TREAD, 225/50/16 Firestone ovals & 16'' Discount tire aftermarket rims. (Any tire issues are replaced free)
Miscellaneous-
New wiper blades front and back.
New negative battery terminal cable.
10,000k HID headlamp bulbs
Stock Fog lights with H3 PIAA yellow bulbs.
New OEM rotors & brakes front and back
EBay fuel pressure regulator (not hooked up)
EBay JDM tinted A/F and Boost gauges.
35% Window tint
Cruise control delete
-Summary-
Clean title, break-in procedure was done with two oil changes at the first 500 miles, and one at 1,000 miles then oil was changed every 3,000 miles with Valvoline full synthetic 10w-30. The transmission is original which feels and shifts great. That is all the information I am able to provide, I have kept very good care of this car. As you can tell I'm very organized and put a lot into the sale of this car and will reflect the quality and time put in this car, does have oil pan leak and speedo sensor needs to be installed!. Thank you. call/text 763-237-4798 ALEX
Update: car has black hood, Alpine Radio, Newer 2G Throttle body with gaskets & FIAV O-ring.
I have a spare door white 2G door, couple 2G throttle body's, and I'm sure some other random stuff I will be including in the sale.
Old 01-11-2013   #3
DSMINMN
Mitsus for days!
DSMINMN's Avatar
Drives: '08 Chrysler 300C
I dig the car as you don't really see many red Talons. I do know you've been trying to sell it for awhile. It's too bad if you do have to part the car out.
Old 01-11-2013   #4
Swanny
Swanny's Avatar
Drives: 2G Talon
Yes, Ive had alot of "interest" but its been all talk. I just got a newer alternator in it, shes running and driving, I hate to see the heart taken out a running talon.
Old 01-12-2013   #5
import_boi
Drives: ae86,2ga,
How much for the 2g manifold? Any cracks?
import_boi is offline   Reply With Quote
Old 09-18-2013   #6
Boomdeeze
Boomdeeze's Avatar
Drives: 97 GSX
Are you still parting this out? Rear brake setup?
If you can't afford to buy an EVO, might as well beat an EVO
Boomdeeze is offline   Reply With Quote
Old 09-19-2013   #7
awd laser
awd laser's Avatar
Drives: 93 TSI
Will you sell the side skirts?
Old 09-19-2013   #8
CornFed2.4
CornFed2.4's Avatar
Drives: You crazy!
Car has been sold to a guy in Wisconsin months ago.
Old 09-19-2013   #9
awd laser
awd laser's Avatar
Drives: 93 TSI
Ahh damn it, I didn't look at the date haha
